Posts posted by Piet
Good evening everyone and thanks to all for your very encouraging comments, so very much appreciated. Also thanks to all who clicked the like button.
Yes, Lou, I looked at steel wool but the cotton was finer and easier to work with. I think I have come up with a method I think will produce a more realistic smoke. I wish you good luck with your wife's Titanic, not an easy scale but you'll do okay with it, I'm sure.
Hey Mark, good seeing you here again. Yup, I looked into the model railroaders but not much on gunsmoke, just chimney smoke using cotton. Looks good at viewing distance.
Hello OC, yes, I looked at those marvelous dioramas of aircraft and tanks exploding, a hard act to follow, especially at my scale of 1:350.
Thank you Jud for your very helpful info, looks like you have naval gunnery experience, like Amateur Jan with field artillery. Now that you mentioned the Japanese used die marker shells I did read about that in the several books I have on the Battle in the Java Sea. Hmmm, food for though adding some red in one and yellow in the other. I could still make the splashes a little higher too. All I plan to do with the gun flashes is some red and perhaps light yellow coming out of the barrel.
Yes, they had a fire control system for distance, direction and elevation. As far as I can determine from reading about the actions there were no broadsides. The photo I posted of "Java" with a broadside was the contest winner's "hurray."
Thank you Nils and no, it's rather difficult depicting smoke at this scale but I tried something yesterday and I may be on the right track with that.
Thank you Marcus for you kudos. Back from Holland? How was your mother's birthday? All's well over there?
Hi John, good to see you again and thanks for your approvals.
Hello Lawrence, thank you as well. I think I lucked out with the bow waves, I'm still tweaking them as we speak. After I walk away from it for a day or so and scrutinize it again I find little things to work on.
Well, no matter what spray gun I use, the paint still seems to make the cotton smoke look unrealistic enough to keep trying. This morning I started to pull one of the pre painted funnel smoke pieces apart and made an irregular ball from it. This seems to come closer to what I think the cordite smoke could look. I have temporarily put them on wooden pins that I cemented to the barrels. These pins serve as the support as well as painting the gun flash on them. When I get additional input from the experts, when I get a yay I can cement them to the wooden pins and shape them into some realistic form.
Working with these fluffy balls without support doesn't work too well.
Below I post a few pics I took this morning before my dental appointment.
The light above the workbench made the dark grey of the smoke kinda washed out. The intend is for constructive criticism as far as form and shape. The one on the left still needs a redo.
Hmmm, the overhead light did cast a nice shadow though.
Next is the funnel smoke.
Cheers,
Hello everyone and my thanks to all who came to visit and clicked the like button, much appreciated.
After doing some shopping and mowing the backyard I took some time to try making gun smoke and funnel smoke from cotton. This is turning out more difficult then expected. No matter what I do it still looks stringy or hairy. I did buy Testor's Battle Ship Grey rattle can paint but using that in the mister mode it made the cotton clump too much making it look like a ball again.
I'm not giving up and continue experimenting. I made a photo of the second try in a closeup. From a standard viewing distance it looks really good, perhaps a little too large but I think I'm on the right track. Now I have to give it a couple of dustings of the grey paint and hope it can hold this shape.
As mentioned yesterday I did a lot of tweaking on the sea. The first area I tackled was the bow wave. It was too small to my liking so I cut some material away to make it thinner and then put a support under it and added more wave making material to make it higher, then let it cure overnight. The next day I trimmed it again and came close to being happy with it, not quite, but close. So I added some stuff to it and let that cure.
In the meantime i also monked with the shell splashes and am happy with them.
Another day later I checked how the bow waves came out and think it's okay. I did add a little blue to the inside as Carl suggested which improved it.
I also removed some of the sea along the port side of the hull, repainted the red and the waterline black stripe, then refilled the hole some. After the stuff cured I added the white highlights.
Difficult to make out what the original bow wave looked like but this is how I made the form. I used baking parchment paper for the non-stick.
The completed bow wave
Another look of the port side bow wave and the shell splash.
The reworked hull and sea port side. Oh yeah, I also added the spend steam water coming out the sides.
Overhead shot. The smoke is still to be redone yet.
Cheers,
Hello everyone and thanks so very much for your very helpful input.
As usual, I have been very busy with other things around the house preventing me from doing much on the model, except some tweaking here and there. It's too late now to add a few pics of the tweaking stuff I've done but rest assured that I'm still working on the smoke issue.
I did read the tutorials on the URL Louie da Fly send me - thank you Louie - , very impressive and realistic. Question is, what scale? Looks like large enough to use chicken wire and EDs. In a scale of 1:350 that'll be nearly impossible.
I did try using cotton day before yesterday but during the airbrush spraying my brush clogged up sending me into the fix it mode and ran out of time. I had to leave things be as is, till I have some time to unclog the brush/gun. I was using acrylic paint, thinned down with water. I get air but no suction and will have to completely disassemble the gun. I have another one but no hose to connect to the compressor.
Thank you Jan for that detailed explanation of gun smoke and nice pic of the artillery shot, impressive. The closest I got to shooting a gun was during my service in the Royal Air Force (KL) shooting rifles. I don't have the one shot of "Java" shooting but do have the one of "deRuyter."
I think I have now enough ammo (pun intended), including the pic below, to create some believable smoke.
One of the problems are in keeping the funnel smoke stiff enough to remain horizontal or a little angling upwards and widening further aft.
I am using a 1 mm wooden pin to attach the gun smoke to the barrels so that's a plus, I think. I may even resort to buying a small rattle can of Testor's dark grey paint to play with, experiment with. This will be an ongoing task till we have it close to believable.
Most of my tweaking was with the sea and have improved on it, I think. I even dug some of the water away next to the hull on the starboard side, painted some red below the black waterline and redid the water there. At least Gwen likes the improvements.
I found a photo of "Java" doing a broadside. This was the last gunnery competition just before the hostilities with Japan, early part of 1941, where "Java" won the Challenge Cop for the third time. My father was just then transferred to "Java" from the O19 and I heard him talk about it. Apparently he was in charge of the #9 gun. There is even a short film about the actual shooting showing him in it but the film was taken off YouTube due to pirating and I don't have it. In any case, this is what prompted me in starting with more roundish smoke balls. Looking at it closely we can see very irregularly shaped smoke but still more or less close to the barrels of the guns. I'll go with Jan's suggestions and try to shape the smoke ball more like these.
Translated as "Remembrance of 3 times Challenge Cup. G.S.O.
Cheers.
Hello folks, I just caught up - again - with your builds. Lovely work Greg and Carl, looking very spiffy. Love the banter between all youns too, very entertaining
Cheers,
Just caught up OC, so sorry to hear about your brother's medical problem. Sure hope the docs find what the cause is and fix it. In the meantime be assured that I'll keep you and your brother in my prayers. Be strong and of good courage.
Cheers,
- popeye the sailor, zappto, cog and 3 others
- 6
Beautiful work on the splice JesseLee. Yeah, stuff happens sometimes but - they say it builds character
Cheers,
- popeye the sailor, JesseLee, cog and 3 others
- 6
Scratch building at its best, one step back and two forward. Looking very impressive Kevin, sitting on them trash barrels.
Cheers,
Thank you all for your input, much appreciated.
Ref the smoke, yes, I have first used some cotton, which is actually a man-made material, from one of my supplement bottles. It's were fine and dense. Looks good but the white coloring has to be painted with either a very thin acrylic or an ink, which I didn't do. The problem I foresee in the paint spraying procedure is the most likely clumping, making it look more like wet hair. I abandoned it for the time being and tried this already died wool, just being lazy and hoping it would work.
I am still tweaking here and there and will go back to the cotton and use the airbrush. In general, I think we are on the same sheet of music regarding the smoke issue. Even though it looks acceptable at arms length does not mean we shouldn't try to improve the looks. The main thing with my request for feedback is whether youns like like smoke added to the display or not and it appears you find no objections I and Gwen would like to see the ship in action, so I'll forge ahead with the smoke.
Ref the bow wave, it looks like you and I are reading our minds Carl. This morning I started on some more modeling on the bow wave. I took my resharpened #11 Execto knife to it and removed some material between the wave and the hull, then added some more material to the top of the wave and further back of it to blend more with the following wave in the water. I had to leave the added material cure before adding more to the wave. This modeling will take a few days because of the curing intervals but I can see a lot of improvements already.
Ref adding blue coloring to the bow wave. Yes, here too I thought about it this morning and will attempt to mix some of the powder die I used for the sea with white to make it light-blue. After I'm happy with the way it comes out then I'll apply the blue and white. It already has a curl but not pronounced enough.
Ref. the 8 inch Jap shell splashes, I also started with two new ones. I used a bunch of unraveled cotton thread and stiffened them up with very diluted acrylic medium. A few more applications and then into the sea for the finalization. I found a painting of the Dutch light cruise Hr. Ms. Tromp surrounded by these shells. I'll try to use that as a guide.
Youns see there is still a lot more detail work involved before we can attach the name plates to the base and put a plexiglass dome over it, which I need to find the materials for yet. Oh by the way, this word youns or yuns is what the folks in Pittsburgh, PA use for "all y'all" in the south Just thought youns may be wondering
Hey Carl, the wipwatermolen will have to wait a while. We have had some major expenses to work on. Being on a rather small government pension and Social Security we have to keep our extra curricular activities to a minimum. However, I will be making a material list and start pricing stuff. Oh yeah, the roofers left a 5/8 inch piece of 4 X 8 exterior plywood. Yeah, we had our roof re-shingled that costs us $30,000 smakkers, ouch Then Gwen's Buick needs new engine mounts and possibly transmission work and my Chevy S110 needed a new ignition system. Ouch, ouch and double ouch.
Hr. Ms. Tromp
Cheers,
Great progress Denis, the deck planking looks good and you can always scribe the plank buts into them.
Cheers,
- Johnnyreg, lmagna, thibaultron and 3 others
- 6
Looking great Kees.
Cheers,
A very beautiful achievement Patrick.
Cheers,
Magnificent Nils and a nice touch with the Arabic name in the banner.
Cheers,
Keep it up Mark, the wood is patient Lovely work overall.
Cheers,
- src, Old Collingwood, Jack12477 and 6 others
- 9
Hello everyone,
As youns already know, I have been busy with "stuff" around the house and a few other things but have had the time to do some more work on the "Java" diorama. I'm still futs'n with it, tweaking here and there, trying things things out.
I'll post a few pics as "Java" now looks. I have a serious request to make and that is, after you have scrutinized the pics I would very much appreciate any comments and or suggestions to fix the things I don't see (the forest and trees thing) or improvements or elimination of things. I have already thinned out the smoke from both stacks after the pics were taken. I am also working on the 8 inch shell splashes I think will add some drama to the display.
I know, I know, I am the captain and should do what pleases me but I am not too proud to seriously consider any input from my friends. Remember, this is really my very first attempt to do a diorama. There is still time for changes to improve the display where possible.
The smoke is from grey died lamb's wool. Closeup it shows the wool fibers but at regular viewing distance it looks acceptable. The canon smoke is not permanently attached yet as is the smoke from the funnels.
These pics were taken inside the garage, aka shipyard, with available overhead fluorescent lighting.
Hr. Ms. Java at 29 knots during the afternoon phase of the battle on February 27, 1942.
Hr. Ms. Java at full speed - 30 knots
Hr. Ms. Java at full speed, 30 knots - closeup. During gunnery practice, note the amount of personnel to man each gun.
Cheers,
Impressive!
Cheers,
- Canute, thibaultron, gjdale and 1 other
- 4
Have a safe and uneventful flight and keep your seat belt tightened around your hips at all times. Enjoy your visit with your mother. 90, wow, a ripe old age.
Cheers,
- flying_dutchman2, Canute, cog and 3 others
- 6
Great going Kees, I just marvel at how you do things.
Cheers,
Beautiful work on the sails Nils and thanks for sharing your method, looks really great.
Cheers,
Happy to hear you had a grand time at the museum and model show. The hammock stanchions look great and so does the netting.
Cheers,
- CaptainSteve, Canute, mtaylor and 2 others
- 5
Caught up again with you Patrick - awesome progress and indeed the lines start to emerge.
Cheers,
Looking good mate!
Cheers,
Hi Lou, I just caught up with you. Sorry to hear about you slow down condition but fully understand. Yep, kit bashing brings a few problems with it but it's challenging and fun. I'm glad you figured out how to manage the problems that cropped up. She's taking shape and that's the main thing.
Keep at it my friend.
Cheers,
Youns better better move over a scotch so I can join in, no rafter seat for me, afraid of heights Looks like a fun project guys and the ship is of the same vintage as Hr. Ms. Java. I'll have to decline the invite to join in though, too many projects going on and besides, there is lack of space in the house.
I'll just watch all youns having fun.
Cheers,
HMAS Vendetta 1925 by cog, popeye the sailor, and RGL - FINISHED - Showcase Models -1/350 - PLASTIC
Enjoyed catching up with yuns. Nice going on the paint Greg. Your paint job looks nice Carl. Congrats on receiving your ship Denis, am looking forward to your version.
Cheers,
