Everything posted by Louie da fly
New member from Scotland (Falkirk)
Louie da fly replied to Razorbill's topic in New member Introductions
Which one is which🤣 Hard to tell, sometimes . . . Oh, wait! Simple, the sharp end is the bow and the blunt end is the stern . . . Sorry Razorbill. I'll get back in my box now. Steven -
Not that I know of. Contemporary representations just show a 2-shift, with the butts of one strake central to the length of the next, but I think that's likely to be artistic licence and that in the real world there would have been at least a 3-shift. I was trying to get a layout that allowed for the planks to be as near as possible to 20-24 feet, which Mondfeld recommends, while avoiding having the end planks too short, as they seemed to be with any other layout. BTW, to my shame, I got one of the plank shifts wrong, so the two sides other aren't mirror images of each other at one point. But I'm committed now, (planks are already glued in place) so I'll just have to put it down to experience. Steven
Is this your first model? The way you introduced the thread makes it sound like it is. In which case I'm even more impressed - that's some pretty nice planking there. By the way, would you be a Kinks fan by any chance? Steven
- 50 replies
- mary rose
- caldercraft
Yep. If your software enables you to draw the planes (and merge them into the main drawing), it should be possible to do your projection lines perpendicular to each plane individually, and so get what when I was learning drafting was called the "true shape" of each frame. Steven
You've made a very good start on this, mate. Looking good.
- 50 replies
- mary rose
- caldercraft
Kris, I would treat the plane that each half-frame "sits on" in its own right, as 30 separate entities (i.e 2 for each frame marked in red on the diagram). Then project from the front elevation of each frame, one by one onto the appropriate plane, at right angles to the plane itself. Does that make sense? Steven
Does that mean the frames are angled from the vertical? Like a raked mast? If so, there is a way to do it by "projecting" lines on the paper at right angles to the frame itself. I hope this isn't too confusing. It's a bit hard to explain clearly. Maybe a diagram will help: But if the angling doesn't change frame width, all you really need to do is proportionally adjust the frame heights (for example, if the angled frame needs to be 10% higher than it appears to be from directly front-on (i.e. at right-angles), increase the height of each point of the frame by 10%.) Perhaps you can "stretch" your drawing in some program like "paint" or photoshop. I hope this helps. Steven
Good work on the oars, mate. I know how trying/boring it can be, but they look good. Any chance of some photos of the hull? Steven
Welcome to MSW, mate, from sunny Ballarat. Hope you're safe up there. Steven
Thanks for the likes and the comments. Chuck, yes I'm spiling. I've only had one plank break so far, but note that the planks are only about 0.8 mm (0.03 inch or 30 thou) thick, and there are no particularly tight curves. The broken plank broke when I was trying to induce a curve in it - I think I tried too hard too fast. Steven
Having decided to "drop" the drop planks the planking came up higher and I found I had to make higher stem and stern posts. I was fortunate that I had some wood with a curved grain to make them stronger. I needed to keep them the same orientation as the old ones, but I only had a scarph joint to keep them aligned. So before I pulled the stempost/keel/sternpost asembly apart I traced over the old set-up and used it as a pattern for the new one. New planking layout marked out on the plug, with the plank shift also marked. And picked out in red to make it easier to see. Cling-wrap on the plug again, to stop the planks adhering to the plug. The planks of the garboard strake. Dry fitted Glued in place. I was fortunate to find a set of tiny clothes pegs made out of plastic instead of wood, so the glue didn't stick them to the ship. The scarph joining two planks didn't quite work, so I glued in a bit of wood to fill the gap; to be sanded off later. And here's the sequence of planking so far: I used push pins to hold the planks down - the plug was made of pine, but it was rather tougher than I'd been expecting, so I needed to drill pilot holes in the plug so they'd go in far enough. And I used scraps of wood to spread the load, or concentrate it as needed. That's it so far . . . Steven
Well, I've been offline for awhile but I haven't been idle. I've made a new buisine (trumpetty thing) with a finer shaft, so it looks more like a trumpet than a bazooka. And a second one. Terribly worried I was going to cut the shafts so thin they would break, but they turned out ok. And I've carved the second buisinier, so now I have both. So here's the three figures so far - A and B on the seal below - (the helmsman isn't finished - I won't finalise his arms till I have the steering oar made and in position) The next people to carve will be the guys amidships (C on the seal). And looking carefully at them for the first time I realise they are working a windlass! It turns out this seal is not just a picture of a ship - it's captured a moment in time! This ship is getting ready to set sail: The helmsman (A) is in place to steer the vessel, and two buisiniers (B) are announcing the ship's departure. The windlass (C) is raising the yard , two crewmen at the bow are weighing in the anchor (D), another crewman (E) is climbing a backstay to unfurl the sail when the yard is fully hoisted. Steven
Hello from Texas Longhorn Country
Louie da fly replied to Glen McGuire's topic in New member Introductions
Glen, Welcome to MSW. Just looked through your build log. Very impressive. Steven -
Glen, that's a really impressive model, particularly as a first build! A couple of points for future models - the standing rigging (shrouds, stays, ratlines) were tarred to protect them from the weather (actually the ratlines probably weren't but would have absorbed tar from the other ropes) and would have been black - or actually dark brown. The running rigging wasn't tarred, as it had to pass through blocks etc, so would be the natural colour of the rope (though it tended to fade and was closer to off-white than tan). You might like to investigate the use of silkspan for sails - it's much closer to scale thickness and fine-ness of weave (in fact it's not woven at all). See and And for sail/steam ships, you might like to look at Banyan's brilliant scratch-build of HMCSS Victoria - see Congratulations on completing a very impressive build! Steven
Please Glenn - at least use the correct terminology - "Sharp end" and "blunt end" On a more serious note, welcome to MSW, Razorbill! Take your time - it's not a race - both deciding on what you want to build, and building it. I'd second the comments above - start simple, but don't be worried about making mistakes - we all do - the more experienced modellers just make more interesting ones. Good to have you aboard. When you get started, begin a build log - not only so we can see your model as you progress, but it's also a great way to ask questions and get help and advice from other members, who may well have encountered the same problems. Steven -
Could I persuade you to start one now? Do you have progress photos? I, for one, would be interested in seeing them. Steven
Thanks for the likes and comments, people. I'm now in two minds about the drop planks. What I was working off was this drawing of a knarr - unfortunately, I didn't make a note at the time where I got it from and now I can't find the original again. But the Winchelsea seal does show considerably more sheer than this knarr (though of course it may be due to artistic license). Now I have to decide which way to go - if I increase the sheer it might mean that I have to make new stem and sternposts so they come up high enough above the top of the planking at the ends of the vessel. Time to do a bit of thinking . . . Steven
I discovered a small problem. Due to the shape of the hull, I've had to include stop planks, but I was "stopping" them as though they were carvel planks - with both the plank above and below the stopped plank taking its place. But that doesn't work with a clinker built vessel. The overlapping of the planks means that only the plank above the stopped plank overlaps. So instead of this: I had to change the overlap to this: Which means I had to take off the clingwrap and start again. The first buisine player is complete except for removing him from his bit of wood. And I experimented with the buisine. I first thought of making it out of wood, but wood painted to look like brass doesn't look like brass. So I decided to try making one out of brass. Found an old piece of brass welding rod and put it in my "poor man's lathe". And worked it up, bit by bit. To keep the thing from bending uncontrollably I kept my working surface close to the drill chuck, only letting it out bit by bit as I needed to. Pretty happy with the way it turned out. The only problem is that I seem to have made it too thick - more like a bazooka than a trumpet. And now it's been cut off I can't fix it. So I think I'll have another try and see if I can make a thinner one. I hope I can make it work this way - otherwise I'll have to go back to wood, which I'd rather not do, for the reason above. Steven
