GuntherMT
Everything posted by GuntherMT
  1. I'm going to sand my little wooden a-frame down a little more to expose more of the wheel, and also try to clean up the casting a bit, I haven't touched it yet. On to other modifications, I was reading through Dubz Syren build (still only a bit over half-way through that, it's magnificent), and saw how the bowsprit was mounted into the bitt, and a light-bulb went on in my head. My kit instructions just show the dowel, still rounded, glued to the hull and ending at the bitt, but after seeing how it's actually supposed to work, I've re-done my bitt (or is it bitts?) with more wood inside so that I can square off the butt end of the bowsprit and give it a nice tight home in the bitt. Also continue to shop for flat black paint and am having a horrible time getting any for some reason. I got a can of Humbrol from across town, and it's almost a solid chunk in the can when I opened it. I bought a couple different acrylic's from Hobby Lobby today, and they are both pretty bad on a sample piece as well. I'm at the point where I need to mount all the cast pieces on the hull, and they are all supposed to be black (I assume they used iron?). On the brass parts - eye-bolts and stropping the blocks and deadeyes, the kit has all of this as brass wire, should it all be blackened, or was it actually common to use brass fittings around 1850? I got a bottle of blackener so I can do it either way now. Maybe I can just use the blackener on the cast fittings?
  2. 2 years without TV in November Keith. Don't really miss it, and I certainly don't miss sending that $75 per month to the cable company for something I rarely used. Not a huge amount accomplished in the last couple of days, but - First mast! This assembly has reminded me to check the measurements on the plans - for *everything*, as I built the crows nest thing (not sure what the platform is called on this small ship) with the measurements in the instructions, instead of the measurements from the plans. So the openings for the masts are too wide and I had to carefully put a 'step' in the sideboard things to fill that gap. A better man would have deconstructed to start over probably. One of the things that has been bugging me about this model for a while now, is that the ships wheel is not only a terrible looking cast part that appears to be completely out of scale: ..but it's also 'per the instructions' just mounted to the rear bulkhead directly with a nail. Like so... This just didn't seem right to me, so I spent a long time going through pictures of every sloop and schooner build I could find in the build logs here, in the tips and tricks, finished kits, and books and online. I finally found a fairly simple ships wheel that was mounted to the rear bulkhead like this, with no rope showing, but it was mounted with a large barrel/shaft coming from the bulkhead, and the wheel was supported to the forward with an a-frame arrangement. So, I sanded down a piece of dowel and drilled a hole in it, and then spent some time with a little piece of basswood, and came up with a first-time scratch build thingie on my ship I swore I would build 'out of the box' for this first time. It's nothing compared to the amazing scratch build stuff on many of these builds, but after everything is stained and painted, who knows, might look halfway decent, and can't really help but be better than the little wheel stuck to the bulkhead. I figure I can replace that cast part with something better someday if I decide I want to as well.
  3. Beautiful work indeed. Looking forward to pictures as this goes on.
  4. Very nice painting. Look forward to more updates as this progresses.
  5. Just caught up on this build. I just wanted to say that this is simply spectacular work. Thanks for sharing it!
  6. Fantastic detail and scratch work there. Hat's off to you.
  7. Thanks for the mast advice. It seemed kind of obvious to me that it would be better to have a clear deck to do the mast mounting, but thought maybe I was missing some important reason to mount the deck stuff first. I'm using 95% wood glue (Titebond original). I only use the Jet superglue when bonding a metal piece to wood or other metal. I typically use the tip of a flat toothpick to apply the glue, and occasionally get about the right amount, but still have a tendency to feel like I'm not using enough glue when in fact I'm using too much. Doubt that the applicator will help with that, only time, as I am slowly improving. Edit: Also got a response to my email from Constructo already, and indeed I am not missing any plan sheets, they just give no details of these parts. Getting out of the plastic model mindset and shifting into the 'figure it out and make it yourself' system that seems to be the norm for wooden ships is something that isn't coming naturally for me.
  8. Yesterday I worked on the cabins, so here are a couple of pictures of that process. I was worried that they would look very bad based on what I started with, but I think they ended up turning out alright, and will look better after finishing. For the port holes in the cabins, I used some parchment paper and traced the plans, then held them to the side of the cabins and used a punch to set the center point of the holes for drilling. The more I looked at the plans problem mentioned in my prior post, the more I began to think that there are probably no plans missing, Constructo just expects you to 'figure it out' without proper detail diagrams. I also came to realize, that for these parts (bitts, pin racks), if the heights of the cross pieces weren't exactly right, nobody would ever know, so I traced them out as best I could from the plan views I had, and got to work. The plans/instructions give no indication of what size hole to use for the pin racks, so I measure the belaying pins at their thickest point with calipers, and then used a slightly larger sized drill (1.7mm). I was ridiculously pleased with myself when I finished my first piece of pin-rail. It was about as perfect as I could have hoped for (pictured here next to the bitts that wasn't quite so perfect, but is ok). My smugness ended abruptly after coming back from a dinner break, looking at the parts remaining to assemble the rest of the rack, and realizing that I'd used the wrong piece (too long) between the uprights. Doh. Set my pretty little pin rack section off to the side and started over. The completed pin racks didn't come out perfect, but I think they are good enough for this first run. Here everything up to this point is set onto the deck in the approximate final locations. Nothing is glued. Pretty happy with how things are looking. Once varnished, should fit right in. Things I've learned over the last couple days: - I should have purchased stock in Micro Mark (and Amazon) the day I bought this kit. - I ordered a Dremel drill-press/work station that will be here tomorrow or Friday. It would have been *really* helpful for the pin racks, I think I ruined about 5 pieces trying to get the holes drilled acceptably. - I need to find a source for some scrap wood to make jigs and crap (and a building board in the future), and to drill into instead of using a perfectly good basswood block. - The flexi-shaft attachment thingie for the Dremel is the best bleeping thing. How did I ever use a Dremel tool without one of these? - One skill that has remained intact after 25+ years of not touching a model; I'm still really good at using too much glue and getting it all over everything. - Buying drill bits from #80 to #60, and from 1mm to 2mm (in .05 and .1mm increments) was a very good thing. Should have ordered metric bits from 2mm up also, those are on order. Looking a number of steps ahead, the instructions have the pin racks and other pieces set onto the deck and glued in place permanently prior to setting the masts. It seems to me that it would be much easier to set the deck stuff in place with the masts set, than it would be to set the masts with all that stuff in the way. Thoughts on that? Advice welcomed. Oh yea, the bitts (that's what the instructions call it anyway) where the bowsprit will mount - should it be vertical in relation to the deck, or vertical in relation to the waterline when it is mounted? The deck has an upward sweep in that area, which would give it a slight backwards slant if mounted vertical to the deck. Thanks for visiting, and please feel free to throw advice, comments, or whatever else my way.
  9. First off, Keith, that book is fantastic. Thanks again! It seems that I've run into a bit of a stumbling block. I'm at a point in the instructions where I'm building deck furniture (fittings?) and the instructions say - "Cut out the bitts no. 71 and make the recesses as shown in the centreline plan." The only problem is, that as far as I can tell, I don't have a centreline plan. I could try to put these together from the pictures in the book, but without decent measurements I am not sure how well that will work. I don't have much extra of the wood sizes used for these pieces for do-overs either. I've sent an email to the email address I found elsewhere on the forums to a guy at Constructo (diset), but I understand they take a while to respond. I'm not sure if I'm missing plans, or if they really expect me to figure the recesses out from a single overhead deck plan that doesn't actually show the recess depths or heights. I have finished up both cabins, and they came out ok, if nothing special. There are other little bits I can continue to work on, as these pieces can be placed later (but must go in before rigging starts, as it ties off to them). In other news, my "30 day back-order" on the AVS shipped later on the same day I placed it, and the website now shows that kit available instead of back-ordered. So I guess I have an AVS in the mail about a month sooner than I expected.
  10. That's incredible. To be able to create that 3d item from simply looking at some pictures is amazing to me. Fantastic job. Now if I understand correctly, you are going to put all of this amazing work under a deck? The mind boggles.
  11. Thanks Keith, I'm downloading that book now. Luckily I don't need to read it right now, as they throttle free accounts to old-school modem speeds. Thanks for the kind words Alistair. Your build of the AVS was one of the ones I went through and will reference when I get to this a couple months from now, and I'm following your Fly build as well, it's looking great so far.
  12. So as I've worked on this kit, I've done a lot of thinking about what I liked about it, but also about what I would look for in a first kit if I knew a few weeks ago all the things I've learned since starting. Things that I came up with: - Larger scale, but not necessarily more complicated. - Better instructions and plenty of reference works to use for assistance. - Single mast preferred, not square rigged. - Double planked. - Guns to learn that aspect, but not very many of them. - Something that appealed to me (the Carmen does fit this bill, it's a pretty ship). I kept coming back to the same model, over and over again when looking through models offered by many different companies, and that model is the Armed Virginia Sloop by Model Shipways. I finally decided this weekend that I was going to get that as my next kit, and when I visited the Model Expo website this morning, discovered that it is on a 30 day back-order, which seems like pretty good timing to me (I figured another week or two for shipping for 5-6 weeks total to be delivered), so I went ahead and ordered it. Next project confirmed!
  13. So one thing that did not come with my Carmen kit was a parts list. Did yours come with a parts list, and if so, does the list say how many sheets of plans it should come with? Mine only has a single plan sheet (plus the instruction book), and it seems terribly inadequate at times, so I'm wondering if I might be missing something (like sail patterns might be kind of nice). Thanks,
  14. Next up in the instruction book, take that hull you've been painstakingly working on for who knows how many hours, and drill holes in it. Wait.. what? Nooo... Didn't get them quite perfectly aligned, but looks pretty decent in the dry test-fit. After the 2nd coat of urethane dried, I took the steel wool to it, and I'm pretty content with how it turned out, and will likely leave it this way. Now, on to.. drilling more holes in her. Spent a lot of time measuring and comparing to the plan sheet to locate these, think they are pretty close to what all the pictures and plans show. Time to assemble the dead eyes to the chain plates. Per the pictorial instructions in the book, this is how Constructo says to do it. I'm sure there is a much better way, but for this build I'll stick with the kit components and they turned out ok. Next I mounted them to the hull. Another time to spend lots of time in measurements, and I think it worked out, they seem to be even, raked properly, and match up with the plans well. I framed up the doors (windows?) in the two deck houses, and am about 75% through planking them. Tomorrow should get them planked and trimmed, and hopefully they'll look much better than they do now, as the base structure is fairly ugly!
  15. Rich, your Connie is looking great. Things like 100 hammock stanchions are why I started out much smaller.
  16. That's a nice little workbench there Nick. The ship is looking pretty nice as well. I think at your age I was probably making terrible plastic airplane models (my work was terrible, not that plastic model airplanes are terrible), so it's great to see such nice and patient work you are doing.
  17. Thanks for the likes everyone. Keith - the plan for the finish is to follow the recommendations, which are light sanding, another coat, light sanding, a final coat, and then the steel wool buffing of the final coat. I'll do the sanding and the second coat this morning, and hopefully get the final coat on tonight. Thanks again for your support.
  18. So while I was waiting for the urethane to finish for some photo's, I finished up the basic stand that comes with the kit, and started on the cabins (jumping ahead of the instructions here). And as promised, some photos of the urethaned ship now. Seems shiny to me, we'll see how it goes after sanding and another coat. I can always dullcoat it. I'm really happy with the replacement of the putty with the sawdust filler. There are still some places where I didn't get the putty removed, but it's not bad, and I'll just pretend it adds 'character' to her.
  19. Thanks for the terminology correction. The Constructo instruction manual calls the bit that attaches inside the bulkwarks a 'knightshead', and the part extending over the bows a 'davit', so that's what I went with. Always good to learn new things while I'm having fun. I've looked ahead and understand how the rigging works on these and attaches to the anchor, but I'm befuddled as to how I'll get a soft cotton line that's barely smaller than the hole to thread through them!
  20. I really like that cradle you built. Looks like it provides great support.
  21. Time for the nightly update, today with a bonus side trip into redneck lamp repairs! Blackie, I ended up using an X-acto blade to get the glue off of the brass, and just sanding the wood. Seemed to work ok, and I was (am) more than a little frustrated with the dumb rudder design so I'm not going to spend any more time on it right now. More later in this update. So yesterday I said that I had tried to tear out most of the putty-filler from the hull, and re-filled with sawdust/glue mix. The results were pretty good, although certainly not perfect. Rudder assembly from yesterday. Frustrating as heck, as there is not enough wood to do what the instructions show, and you are somehow supposed to attach the brass with the 'nails', which are the planking tacks that are 4x as long as the wood is thick. I also broke the bottom of the rudder off making the lower notch for the hinge. The chunk glued back in nicely, after I clamped it for a while. For attaching the hinges to the rudder, I used super glue, and on the top nail, tried to make it just long enough to go through and then hammer down the other side like a rivet. That didn't work very well at all. You can see how I made a huge mess with the super glue also. The lower hinge, I just cut the nails super short and they are basically decoration, and the brass is held by the superglue. I don't really care if the hinge is functional, it's a display model after all, not a R/C boat, but even after all my messy glue application, the hinges actually worked at this point. Here you can see where I've filed down the brass on the top hinge since it was trimmed too large originally (picture with all the super glue mess above). Next, I took my plank samples out and use three different finishes on them to test. I tested on both the deck and hull planking. Ordered left to right (on both sets): Cabot satin spar varnish, Minwax Helmsman spar Urethane, Minwax Polyurethane. I decided based on the test to go with the Urethane finish. While the samples were drying, I headed out to the Lowes in town, to get some different clamps and some drills, and while I was there I decided to get some stuff to fix my dumb swing-arm lamp. This lamp is the best lighting I have at the work station, it's got a daylight LED bulb, but the provided clamp is just terrible crap. It won't hold the weight of the lamp unless it's clamped in place with a C-clamp, as well as a second clamp reinforcing the base itself where the lamp goes in. Ship building stuff to the rescue, along with a couple of conduit clamps. Chunk of basswood I picked up at a hobby store the other day, dremel tool, various drills, and a bit of clamping for vacuum action. I destroyed the first attempt, as I went the wrong direction re: the wood grain, and the big drill caused it to shatter. Second attempt worked out pretty well. Back to the ship. I put in the bowsprit reinforcements, and the knightsheads. Then I made the davits. I have absolutely no clue how I'll actually get the rigging through these dumb little holes when that time comes. The instructions don't even tell you to drill these holes, let alone give you the size they should be. They just have a picture of the davits showing that the holes are there, and then later on have the rigging going through them. The rigging is "Small beige yarn", which isn't terribly helpful for sizing either. Using the calipers, the yarn seems to be around .025~.028, so I drilled .031 holes. I was afraid to go much larger given the tiny piece of wood I'm working with here (4mm x 4mm). I ended up placing the davits twice, as I wasn't happy with the angle the first time. They aren't perfectly symmetrical to each other, even though I measured the points on the deck from the forward mast hole with the digital calipers 3x before setting the knightsheads. Oh well, I'll work on getting that better on the next build. After drilling the hole in the transom for the rudder to go into, I discovered that it was too short to actually fit into the hole, so I tried for a couple hours to make an extension to the rudder work, but I just couldn't get any piece I made to stick. No idea what the deal is with the top of that rudder, but super glue, wood glue, and even 2 part epoxy failed to make anything stick well enough that it wouldn't come off with the slightest touch. I stuck the rudder in place with the extension on it eventually, but it fell off into the hole (it's captured there between the rudder and the keel) while I was mounting the rudder. Maybe I'll come back and try to do something with that later, but I'll probably just leave it since it won't be visible on the finished model without turning it upside down. As with the rudder itself, there isn't enough depth to actually use the nails to mount the rudder as the instructions say, so it's held on with super-glue, and the nails are cut off very short and basically are decoration. I've now coated everything with the first coating of Urethane, and I may take pictures and post them in a few hours when it's dry (4 hour dry before sanding on this product). Until next time!
