Everything posted by mugje
Really nice, you are doing a great job! Also beautiful lines in this ship
- 11 replies
Just sharing my solution how i've dealed with that little gap between the first layer of planking and counter planking. I used some filler to fill up the gap, also to give everything some strength because it's connected to each other. And at the counter planking I glued a extra 1 mm thick piece of pear so it covers the gap nicely. Now with testing a scrap piece of pear of 0.8mm (the second layer planking thickness) there no height difference anymore and it looks nice level to each other. Also if i'm not mistaking later in the construction the bottom part of the counter piece will be covered with a decorative strip of wood.
That's is truly a fantastic result! Congratulations!
- 41 replies
- Essex
- Model Shipways
Okay...it's time for me now to place the lower stern counter into the right place, but I have a question...let's see if I can explain it. Blue Ensign did a great job explaining how he tackled it, with temporary pinning the rest of the stern pieces. So you can see if everything lines up. Sounded like a great plan, so I did this too. Need here and there a few little corrections, but in general this looked good and on the correct height (if it's not please let me know ) I asume the first layer of planking needs to be on the same height (thickness) of the lower stern counter. One flows in the same height into the other, without elevation? Well that is what I think it should be but if it's not by design, please let me know. Because as you see in the lower pictures, you see that my first layer of planking is a bit lower than the stern counter. In the outer corners not so, but closer to the stem it is lower. I can put some filler to get it more level with each other.
Great result! And like Blue Ensign said...impressive construction speed!
- 233 replies
- Indefatigable
- Vanguard Models
Thanks for the suggestion Chris! I'll take it one step at the time...and see where I end
- 80 replies
- Sphinx
- Vanguard Models
Good luck with your Sphinx journey! It's such a lovely kit...I also toyed with the idea of building it without rigging etc. due to space saving. But I also lack the experience to rig a three masted frigate...so i'm going to rig it just for the experience I think...but I have some time to decide it so nothing is set in stone at this point.
- 80 replies
- Sphinx
- Vanguard Models
Congratulations with finishing this stunning ship! Quite a epic journey and wonderful result
- 364 replies
- bellerophon
- victory models
Well a disc sander with adjustable table (like the proxxon one) made my modellers life a lot more enjoyable. It makes it so much more easy. And a Dremel ofcourse...those two are my essentials...for now
Last update this year I suppose The hull is now sanded smooth and the little cracks/deeper lying planks etc. are filled. Ready for the next step I guess. I will test fit the prow/keel and sternpost patterns to see if it fits right, and maybe there are spots that need a little extra sanding (places around the tabs that are connected to the prow and keel). Also need to test fit the lower counter ofcourse. I think I also need to check if the upper hull side patterns are flush with the gunports inside. I haven't done that yet, but also didn't see it mentioned in the manual. Would be a good moment for that.
And be aware....when you are at the part of glueing it in place....don't put glue on the deck, but only at the false deck below. Because the PVA will moisture the wood causing it to swell a bit. This resulted in that the deck didn't fit anymore because I couldn't get it fast enough onto the false deck, and as a consequence...the deck became fixated in this swelled up size due to the glue that dryed. So I messed this up a bit Totally my own fault due to the inexperience working with thin sheets of wood. So maybe I can warn others to not make these mistakes
American Revenue Cutter – Seahorse – 1:72 – Card Kit
mugje replied to Jsk's topic in REVIEWS: Model kits
Looks like a fun project! Will be interesting to see how you tackle it. And nice review/story -
Yes Sphinx is a good alternative, but not sure how experienced you are. I'm building it now and it's a real joy. Your criteria of decent instructions and materials are met with this kit. I can't judge how difficult it is because i'm not that far into the build yet, and i'm considering myself a experienced beginner. But knowing the designer and prototype builder are here on the forum, that gave me enough confidence for trying to tackle this kit
