Ronald-V
Members-
Everything posted by Ronald-V
Soaked the wales yesterday for the first time. Only the part at the bow, but that felt insufficient. So today gave the whole wales a bath for the second time. If I try to follow the line it needs to run in the middle of the ship it wants to come of a little here and there at the bow. That's why it felt better to soak the whole thing. But will still need plenty of nails when the final install with glue happens I guess I'm toying with the idea of having the wales start just off the rest of the planking at the bow, as if the wales were in the rabbet. As they are in real life, but I'm not sure if it's worth it, or if it'll even be noticeable. Will decide that when they are dried.
Thank you for your very kind comment! Well Chuck created the tutorial for planking, I just followed it. I have read articles about planking before, but I never really understand it well. It wasn't until I saw Chuck's videos that I started to get it. That's why I haven't really written a detailed report on how I approached the planking, because that already exists in the form of the videos. Thank you so much! Yes that detail of the horseshoe is pretty cool. Still need to add it though. That's what I love on these Vanguard kits...there aren't many manufactures that include all these nice little details Thank you all for your very kind comments and likes! Really nice to read 💫
Congrats with your health! That's terrific news 💫
- 207 replies
- vanguard models
- Duchess of Kingston
Lining help needed
Ronald-V replied to Smok_Baltazar's topic in Building, Framing, Planking and plating a ships hull and deck
Just step by step and you will learn a lot here on the forum -
Lining help needed
That looks smooth! Well done -
Update: Finished with the WOP, so here are the final pictures of the result. Used 4 layers of WOP with sanding after the first two coates. I used 400 grid sanding paper, but would advise other people to use some finer grit. 400 felt a bit to coarse for the job. I'm quite happy how my planking turned out, also the color has a nice warm tone. Now onto the wales Btw...glad MSW is back online!💫
Maybe a bit easier would be hairs out a stiff, cheap paint brush. Then you also have a little more hair than the cat has whiskers 😁
Lining help needed
This will help: https://www.youtube.com/@chuckpassaro7634 I would recommend you to watch part 1-4 of the Winchelsea video's Chuck Passaro demonstrates a really easy method of edge bending wood with a travel iron. Works like a charm! -
I use a local brand CA that has sort of the same application bottle as the Gorilla one and that worked fine for me, but everyone has his own preference with this. So I would experiment with it. Don't have experience with Gorilla, but don't think it's bad also. For PVA I buy empty bottles with a fine tip that you need to cut of yourself, so you can determine how big the hole needs to be. You can find those on Amazon.
- 177 replies
- Sherbourne
- vanguard models
(and 3 more)
I use both glues for the second layer of planking. About 2cm or an inch of PVA with dots of CA in between. Worked great for me, just experiment what's most convenient for you. Your Sherbourne has already found its form!
- 177 replies
- Sherbourne
- vanguard models
(and 3 more)
Ah thanks Glenn. I thought I had to sand between each layer, but it makes sense that the wood absorbs a lot of varnish first and that you can sand after a second or third layer. Your tips in Delf his "DoK" building log helped me to understand how to apply the WOP, so thank you Thanks everyone for the likes and nice comments! I appreciate it a lot
Congratulations with your fine Lady Nelson, excellent result! And nice how you displayed all the used tools, it shows indeed you can build a lovely model with limited tools.
- 34 replies
- lady nelson
- amati
