Everything posted by Canute
Reminds me a little of Dusty Springfield, too. I vaguely remember that band. C'mon, late 60s college?? NYC FM rock stations were very eclectic in their playlists back then, especially the late , very lamented WNEW=FM 102.7. Very laid back DJs, like Scott Muni, Roscoe and Alison Steele - the Night Bird. <Sigh>
Check out Kombrig. They have the Hoche in both scales. http://combrig-models.com/
There are a lot of aftermarket goodies for these, although finding them can be a long process. Part of it is knowing what each piece is called. And these part manufactures are mostly mom & pop kinds of makers, so can go out of business unexpectedly. If one is lucky, the company assets are bought up by another person or company. The model railroad hobby, like many, has morphed into a "ready to run" one. I admire the zeal to do this up, but be prepared for a long haul if you plan to really doll this up.
Yes, they'd hang a canvas screen to keep some of the weather out of the cab. Good idea for an added detail. I guess they may have used some red knobs, but I don't know too much about wood burning steam engines. One detail you should show is the water sight glass. It'd be a vertical clear glass tube, with brass fittings holding it to the firebox face showing the water level of the boiler. Would be about mid boiler face , both vertical and horizontal. It was critical that the water level was monitored. If the crown sheet (between the firebox and the actual boiler) inside the boiler was exposed and then fresh water pumped in, the water would flash over to steam and could cause an explosion. If that happened the crew would be killed or badly scalded. Railroading was pretty dangerous in the 1800s.
Model Railway Cars by Canute - 1/87 - HO Scale Rolling Stock
Canute replied to Canute's topic in Completed non-ship models
Denis, Mark, the level of detail available is stunning. And as guys get more into 3D printing of parts... The technology is amazing. Some kit makers have such a level of detail, it'll blow your sox off. Boxcars with the oil canning of the sides. Greg Lester is a master doing that on his ships, but it takes time and work. I pulled a resin cast car out of the box and the oil canning is already done. I still have a lot of work on the car, drilling out grab irons, adding brake rigging, putting on doors and running boards, painting and weathering. Denis I will do an actual build soon. I have 3 half finished cars I need to get closer to completion. I'm too far along to get "starting out" pictures. The digital command control we have now is very cool and being able to use the tiny speakers from your cell phone really adds to the effect. The sounds are superb. We have to be very careful with speakers, since the sound systems are in the 2 watt range. Some of the sounds can be corny (station announcements), but I can match the actual air horn sound to the loco I'm running. Find a club in your local area and ask to visit the layout. If it's HO, S or O scale, you'll get the sound effects. The N Scales have sound, it's just tougher to fit all the goodies into their equipment. -
Yes, that is a great airbrush site. Denis, this is all a cooperate and graduate kind of affair. I learn stuff all over this website. I have played with resins and worked some metal stuff, too. Tapping zamac is an exercise, with using a fluid (I use 3 in oil, because it's handy). Nice and easy does it. Ain't no race. Drawing a bath for Batman and Robin? I'm sure they'll like it. Some guys also rub the resin parts with alcohol wipes. I don't know about that. I would recommend keeping your bare fingers off the freshly washed resin, to prevent finger oils contaminating the bare resin. I'd do the same for styrene plastic.
Brass knobs, Denis. Oh and it's the engine cab, not a booth. Engine is looking good. Good thing this is a wood burner. Some early coal burners from railroads in northeastern PA had very wide fire boxes, to help burn anthracite. They had a shelter of sorts at the back of the locomotive. This was where the fireman kept the water level up and the fire going. The engineer rode in a cab in the mid section of the boiler, right over the drive rods and wheels.
Thanks, J. Much appreciated. And all you folks hitting the react button, too. It's a fun hobby. -
Whatever it takes to get the part shaped and glued. Greg, what is the flat round doohickey laying on the surface plate in post #54? Looks like a scraper/shaper tool?
Keith, that's the Tiffany glass I mentioned. One hundred plus years back, the railroads really did themselves proud with fancy work like that. Lou, we run cars around the layout with drone cameras (smaller than GoPros) to give our visitors a view "out of the cab" from one of our locos running around the various sections of the club. Many think we're running videos, until we tell them to wave at the camera car and they see themselves. They eat it up. We ask our engineers to follow their trains to prevent wrecks, but "cornfield meets" can happen. Craig, it is fun. Build up a miniature world and run your trains around in a prototypical manner. Beats working for The graffiti on cars happens when they sit in a yard somewhere for too long a period of time. That big, blue autobox I did was used to haul parts from the parts makers (Delco, etc.) to assembly plants. We had a number of assembly plants in north Jersey (Mahwah - Ford, Linden - GM) It was considered captive service, since those cars were very specialized internal racks for GM or Ford parts. Keeping track of all them needed a slew of clerks, since we weren't into a lot of computerization. Denis, Ambroid and Northeastern kits are available, usually on Fleabay. Interesting kits, although the level of details isn't up to the current capabilities. And they tend to try to make wood look like steel. I have some QualityCraft "steel" cars that show the wood, despite four or five coats of sanding sealer. I have a couple of vinegar and pickle cars (nice wood cars) that I will substitute some styrene parts where they should be steel. There are decals to do graffiti, like Denis says, but I know a few custom painters who study the cars a lot. They tend to take and gather a lot of photos so they can duplicate the real thing. I'm off to a railroad prototype modelers meet tomorrow, down in Savannah, Georgia. A few of those guys may be there, so I'll ask around.. I've got a few kitbashes in the mill, Denis. One is a conversion of a coal hopper to a clay hopper. Chopped the bottom hopper chutes off with my scrollsaw and cleaned up the plastic crumbs. Plumbed the brake lines and started fitting two side channels. Next step is some bottom doors. Another project is a Northeastern stock car with a little modernization of detail parts.
