Everything posted by ccoyle
I got around to starting the landing gear. First, a photo of the gear doors. The left one is finished; the right one is still in its "frame." So, the main difficulty in building these stems from the fact that the doors are not flat -- each has a pronounced curve that goes around its strut. The way the kit tackles this is to start with a two-sided "frame" from which the central portion is removed. Then six curved panels are added, three interior and three exterior. Finally, the finished doors are cut loose from their frames. I'm satisfied with the results. Cheers!
Russian T-62A Tank by CDW - Tamiya - 1/35 Scale FINISHED
ccoyle replied to CDW's topic in Non-ship/categorised builds
Just saw the Tank Museum link. I've watched many of their videos -- a great resource. -
Welcome aboard, Rich, from your neighbor to the north. All of the kits you mentioned are great projects and should set you up well for enjoying this great hobby. Cheers!
No problem. I was really making more of a snide comment on the unfortunate design flaw of the original. 😉 -
Does it come with uncompartmentalized ammo storage racks inside the turret? -
Looks great!
USF Essex by mtbediz - FINISHED - 1:50
ccoyle replied to mtbediz's topic in - Build logs for subjects built 1801 - 1850
That is a very handsome model, Mustafa, and one to be proud of. Congratulations! -
This is why you need to have a maritime gallery assess it, not a random model builder. The price range can vary considerably depending on the type of model, age, and condition. What you need to do is take a good set of photos and then Google search for "maritime art gallery"; one or more of them may be able to give you a preliminary assessment based on your photos, but to firm it up they would probably want to lay eyes on it. Tell them you have a ship shadow box diorama.
So, I am now ready to start on the main landing gear, and this I can tell is going to be really, really fun. 😧 First, there is a ton of parts, including many tiny ones. Second, these parts are scattered across the parts sheets instead of being in one place together. Third, the bay doors have a curved surface in them, and just the main doors alone -- sans all of the strut attachment points, consist of five parts each; the curved parts are supposed to go in an area cryptically marked "cut out after forming" -- and I'm, like, "Dudes -- I can't see how the curved parts are supposed to fit unless I cut that portion out first." The instructions do not help on this point at all. I translated them into English, and this is what I got: "Refer to the assembly drawings to make the chassis shave. Particular attention should be paid to the precise and solid construction of the G12-G15 chassis leg suspension." That is the sole instruction on how to put the main gear struts together. Beats me what a "chassis shave" is. 🤔 The diagrams shed very little additional light on the assembly process. Pray for strength!!
Models in any medium are welcome here. Enjoy your stay!
Hi, Shane. First word of advice is don't do anything to this model until you have had a knowledgeable maritime art dealer assess it. These things can have some collector's value depending on their age and provenance, and the patina of age may even be a desirable characteristic. The subject appears to be a bit fanciful. The ship has the masts and secondary battery of a pre-Dreadnought, but the American Civil War had demonstrated the superiority of turret-mounted main batteries, and casemate-mounted main guns were largely a thing of the past by the mid-1870s. AFAIK, all British pre-Dreadnoughts carried their main armament in turrets. Have fun unraveling this mystery!
It turns out I overreacted a bit to the molded canopy issue -- it is apparently formed slightly over-sized on purpose. By gluing the framing to the portion of the canopy that it actually fit instead of presuming it should have followed the molded "edge" areas, everything works out. Of course, by not being able to follow the "edge" areas of the molded canopy, some guesswork is involved on where exactly to glue the frames in relation to the canopy's curvature, but that worked out, too.
Welcome aboard!
Welcome aboard, Rob!
What?? 'NMM' was a perfectly serviceable acronym. Now I have to unlearn that one and memorize a different one. 😜
- 488 replies
- Indefatigable
- Vanguard Models
Hi, Gizmo! I had a look at your uncle's models and posted a comment there. Thanks for sharing!
