dafi
Everything posted by dafi
  1. Thank you Jan! But this only was a deadly-horned-ridge-back-bug, 30 cm diameter. I thought it would eat me! Who ever looked at the right hand corner of the ladybird pictures saw already my new ventures :-) Right, it was time fore shake-rattle-and-roll! To add a new shade to the old black-and white discussion, I would like to widen up the discussion. Classically the two colors for the british ships is a neutral pitch-black for the standing rigging or natural hemp for the running parts. As stockholm tar has a more brownish color, I already added a brown touch to my shrouds. The contemporary literature mentions the ratlines as "tarred". Also the hammock netting and the cover over it is mentioned to be tarred. But does it mean that it was black? We had some interesting discussions in our german forum segelschiffsmodellbau.com with the remark, that it was also used to impregnate cloth to wear :-0 So I opted for a shade that is darker than the natural hemp but much lighter than the dark shrouds. So I mixed the two of them. The thickness was already tested out quite a while ago and I found a thickness suitable for both looks and handling. So I took my tart section and placed a template behind the shrouds - have a look at the shortened hair clips - my girly is gonna kill me ;-) The template proved to be to thick in the lines, couldn´t see my lines properly ... ... so replaced it with a newer version where a filmsy line in an apart softgreen trhat proved to be more suitable. Also I used the hint not to rattle up (or better saying down) in one go, but to always half the distances to avoid the curving in of the outer shrouds. So it got slowly more and more full ... ... the backstays I did bend out of the way, there are rumors of modelers rattling them in also ... The lower lines were tough, had to find a logical way to work my way through, remembering in which row they were done on the original. As the ratlines were the last items, so they had to go over everything. But even this mess I managed to clear considerably :-) And then comes the point of taking out the guiding template. Still had to clear the half hitches of the outer shrouds and arrange the sagging ... ... and up they can go :-) XXXDAn
  2. What a dream, thank you for showing, cheers, Daniel
  3. Wonderfully done and shown, thank you! Daniel
  4. Just received two shipyard inspections right now. One itzy-pitzy-teeny-weeny little tiny red spot with 6 legs and two antennas that was racing all over the model in such an incredible speed, that I couldn´t shoot it. The second one I got some nice shots off :-) Looks there were no complaints on the way the rigging was done as she (LADYbird) left without further remarks ... XXDAn
  5. No port (nor rum) - the spirits are just allowed in the night time ;-) XXXDAn
  6. One point goes to Popeye - because of asking for the rope. It is fitted by now :-) XXXDAn Two more hints - no pajamas involved and neither those gentlemen http://m.youtube.com/watch?v=l924olE7ZJU
  7. Going Bananas ? Going Bananas ! Going Bananas !!! :-) XXXDAn
  8. Thank you Sörrs :-) And @amateur ... ... what did I do now ? You are always expecting sooooooooo cruel things here to happen - unbelievable ;-) XXXDAn
  9. So, the good news first ... ... all the lanyards replaced :-) While doing this I felt a bit observed untill I remembered a long forgotten detail :-) XXXDAn
  10. Thank you very much Popeye :-) But if the paths are really correct ?!? I think everybody will have to decide for themselves :-) The truth lies in the eye of the bebuilder ;-) XXXDAn
  11. It is like one of those searching games, one has to know where to look at :-) Victory Endeavour Göthebourg Constitution: It looks like the seizing is used to secure the free end, but I believe having seen those seizings also on the front side. XXXDAn
  12. Hello Tadeusz, if one looks close, you can see the things on the picture of the Vic :-) XXXDAn
  13. Here is a copy of the question I already put in my building report: In an earlier Version I still had added some lashings in between the lanyards as to be seen on todays Vic, Constitution and some literature. See the green arrows. Was this in use already in 1805? Jan already replied: The earliest prouve I found is Nares Seamanship 1862. As the lanyard is officially only fixed with one half hitch it does make a very useful addition. So could it be acceptable to display this about 1805? It is meant for this setup. Here a nive detail to the topic: Götheborg on the way to China, working on the lanyards 3.10 and cutting of the above mentioned lashing at 3.30 :-) https://www.youtube.com/watch?v=oa8Z0Dyigt0 Cheers, Daniel
  14. It started with the unhappiness about a ball of glue ... ... but also the 2 cored 0,15 mm lanyard appeared too thin, was too unstable and did not allow a decent splice without breaking the material. The new 4 cored 0,2 mm looks much better and is easy to splice. That is why I went down the road again ... ... this was already shown, a blackend wire around a needel and cut open for the rings. To fix the rings I used two pointed pliers (less carpetmonster-danger than tweezers!) opened the ring and in the same go - without letting go - hooked into the eyebolt and closed it. Now I continued differently: Pierced the 4 cored lanyard with a sharpened needle ... ... pushed the needle through down to the eye, put the short end through the ring on the eyebolt ... ... and then through the eye and pulled it through. Took the thread out of the needle to be more free, pierced the lanyard from the other side, pushed the needle in down to the eye, introduced the free end ... ... and pulled again and the splice is done. Secured with a drop of glue, cut neatly and things are done. After taking down the old lanyards I realised that the old tube was stuck with glue and junk, inner Diameter smaller than 3 mm, but my smallest drill 3 mm and did not fit. So I sanded a square point onto the drill which worked marvelously on the tiny tubes :-) And things looked much less messy than before :-) Some touch-ups on the paint will follow with time. XXXDAn
  15. Old chaps never change ... ... already looking a long time at the gunport lid lanyards ... ... usually I tend to do the details a tad smaller than a tad too big ... ... but this time it was just a little bit toooooooo much under dimensioned, as I took the thinnest yarn ... ... first looking already much toooooo thin and then on top I got a big blop on the ring as it is too thin to do a decent splice ... ... and here we have mark 1 on the right and the new mark 2 on the left ... ... already looking better. Just eleven more to replace ... ;-) XXXDAn
  16. Wonderful as ever! Or to say better: Wonderful as Evan? Great work and thanks for all the details along the way! DAniel
  17. In an earlier Version I still had added some lashings in between the lanyards as to be seen on todays Vic, Constitution and some literature. See the green arrows. Was this in use already in 1805? Cheers, Daniel PS: On the far right a very first version still using the oob yarn for the tests ;-)
  18. And once things move ... ... keep things moving :-) Set up both second backstays ... ... now just missing the breast backstay. And holy Impatience, wanted to see the anchors in place ... ... the lead is thrown ... ... and *enjoy* XXXDAn
  19. Your Good Greatious, mylord Dubz :-) And, do they fit? XXXDAn
  20. Today we have fathers day in Germany. This means, all man and fathers (the ones to be included) take a small hay cart and 3 dozen bottles of beer (for each person) and stroll off into the wild to get comfortably numb. I love fathers day :-) And this year dafi alone at home, so I take my small hay cart and stroll with my 3 dozen bottles of beer from one room of the flat into the next. That´s why I love fathers day :-) Also I claimed my fathers day present: A hair clamp that I shortened so it is less heavy and less lever action is taking it´s toll. The foremost shroud is served but unlike the Vic in P. the serving stops atop the deadeye so it fits better the literature. The clamps are fixed with a drop of CA and then bound with fly fishing yarn. And here I have a small stage win :-) Cheers, Daniel
  21. Always very enjoyable to catch up with this wonderful build! Well done, Daniel
