Chuck
Administrators
Posts posted by Chuck
  1. As another alternative you could try using hard maple and that is available here in sheets and strips.   Very inexpensive.  the wood is much harder than basswood and I have in fact used it for another pinnace build.   I used it for the frames and keel.   After applying wipe on poly it looks very good and very similar to boxwood.   It is not as hard as boxwood and you cant get as sharp an edge on teh wood but it is leaps and bounds better than basswood.
    http://www.nationalbalsa.com/category_s/232.htm
    Chuck
  2. Yes I know....that isnt your fault...Take a look at the plans,  It may be hard to tell on the paper plans at the actual scale but the bottoms were flattened during laser cutting.  There is a tight curve there and the tolerances in the ME laser cutting is not tight enough to keep the curve you noticed with the pinnace.  Those sharper points were just cut away.   It happens.  They were able to do so on the pinnace I suspect only because of the larger scale.  Even though a tight curve doesnt exist for the reasons mentioned,   it should be there.   When fairing the bulkheads it should probably be sanded into the frames as much as possible. To mimic the tight curve - transition of frames, use the shape shown on the plans body plan.  Depending on the consistency of their laser cutting it may be more pronounced and absent in some kits more than others.  But the kerf they get while laser cutting is just too large to keep this detail.
    Here are some images of those last three frames as they SHOULD appear and the body plan from the plans enlarged.
  3. Bruce ...dont forget to introduce yourself properly to the forum in the appropriate area.  Let folks know who you are.   There is nothing more suspect than folks who sign up and simply post stuff for sale and then leave.    It happens a lot.   Folks here are so much more comfortable with these online transactions if you waited a few weeks and in teh meantime post about your cutrrent projects and your introduction to the hobby.
    Otherwise....it gets a bit scary.
    Chuck
  4. Russ is correct...you can add the keel and stem and even the stern post at any time.   One thing you must remember is that every guide or log is only representing the sequences used by that individual builder.   There are so many ways to plank the hull.  I single planked the prototype also.   I would say that if you had planned on double planking you should wait to add the keel.   Otherwise it would be too short...or not deep enough.   This is why I left it off  until after planking.  The rabbet is only used for the first layer.  A second layer would sit along side the keel and make it look to narrow.
    So for you it wouldnt matter.
    Here is a photo of my finished hull with just the bottom painted.  One layer only below the wales.
  5. I am often asked by folks who buy my rope how they could make it look less new.   They want to know how to give it a more weathered or even just textured look like they see on many contemporary models.   First I tell them to wait 300 years and it will look just like they want it to.
    But then after failing to get a laugh I suggest what I have done for years.  Its quick and easy.  Its not very messy.  But it does take practice.  So I figured I would post it here.
    Model builders have been running their standing rigging (black or brown) through a candle flame for years.   They do this to remove the fuzz.   Luckily my rope doesnt have any fuzz.  BUT.....should you run your light tan rope through a candle flame....it will pick up some nice color.   The soot from the burning candle will give your rope some texture.   Multiple passes through the candle will make it darker.
    Running it through very quickly will create a very blotchy and uneven look so dont be afraid to take your time.   Take as much time to slowly run it through or over the flame.  You will have to practice because obviously if you go too slow it will just catch on fire.
    Once I run it through the candle flame,  I will run the rope between my fingers.  This evenly distributes and softens the texturing.   In the photo below you will see a brand new and untouched coil of rope and behind it....that was after I ran it through the candle flame twice.  If you do it once it wont be as dark but I wanted you guys to actually see the results.
    So if you are trying to figure out how to weather or darken the running rigging,  you might want to give this a try.  I havent tried yet....but I am also wondering if different color candles will impart a different shade of soot.....will have to try that next.  This effect came from your standard average white unscented candle.
    Click the thumbnail for a really big version.
  6. Pops
    Looking good.  You are in a good position to take that cap rail and just thin it down considerably at the bow.   That extra piece you added will not be necessary at all.  Just carefully thin down the caprail to remove what I have shown below.   Then also thin down the frames in that area as well.  Dont be afraid to weaken the hull.  It will be quite sturdy.  Just thin it out.  It will make a huge difference.
    Chuck
  7. Yes its on the plans and you could certainly have a look at those hi-res photos I posted.  They show it very clearly on the contemporary models.  Almost all of the blocks had hooks seized to them and they were placed in the holes of the iron bands.   This made it possible to un rig the boat quickly and store that stuff.  For the kit,  I only showed this a few times because it some tiny stuff.   To simplify it I simply tied the blocks to the iron bands.  But a more historically accurate method is to use hooks.
    Check out these photos...
    http://modelshipworld.com/index.php?/topic/1856-large-close-up-images-of-longboat-rigging-on-contemporary-models/
    Nautical Research Guild Summer Issue is in the mail.
    Become a member and get it delivered to your front door every 3 months.
    Here are some highlights including the table of contents.
    Cover%20NRJ%2059-2%20for%20web.jpg.opt19
    3D Printing and Model Ship Building
    by Patrick Matthews
    USS Arizona
    by Oren Long, Jr
    The East Indiaman Edwin Fox of 1853
    by Ian Poole
    A French War Brig
    by Richard Simon
    Coppering the Fleet and an American Entrepreneur
    by Louis Arthur Norton
    Building HMS Isis of 1776: Highlights of a Multi-Year Project
    by Byron Gore
    Modelers’ Gallery
    Shipbuilding Literature in the Netherlands (1671-1838), Part 4
    by Ab Hoving
    SHOP NOTES
    Making Dowels
    by William E. Sproul
    MODELERS’ REVIEWS
    An 8-inch Shear from Harbor Freight Tools
    by Steve Wheeler
    The 3D Elbow Bender from UMM-USA
    And here is a look at at one of the models featured in this issue.
    Click on that photo to enlarge it and see what a great model Byron put together.  Its stunning.
    HMS ISIS
    by  Byron Gore
    2014 Nautical Research Guild conference
    St. Louis - October 16, 17 and 18
    See the website for Details - CLICK Here
    A new Conference format is being offered in 2014 to help make this event more affordable.  The featured tour will be held on Thursday, and the Technical Sessions, which focus on model making topics, will be held on Friday.  These two events have been switched so that those wanting to attend only the two days of classroom discussions can do so without having to incur the cost of an additional room night.
       At the NRG Charleston Members’ Meeting, a number of attendees suggested that round table sessions should somehow be included in the weekend schedule.  In the past, these talks were conducted on Sunday morning when most were leaving the conference.  The Friday schedule will have three guest speakers in the morning, and five round table sessions in the afternoon.  The General Sessions on Saturday will highlight topics that cover a wide range of nautical interests relating to research and history.
    The Conference Tour will feature a cruise aboard the Tom Sawyer, a 50-year old riverboat. The journey will take you from downtown St. Louis to Kimmswick, Missouri, a quant riverside town known for its historic homes, shopping, and antiques.  The narrated cruise will feature onboard bingo, card games, and riverstyle music.  Upon disembarking from the “Sawyer,” lunch will be served at the Blue Owl Restaurant and Bakery. There will also be ample time to shop and explore the town on foot.  A motor coach will be provided for transportation back to downtown St. Louis.
    While visiting Kimmswick, guests must anticipate uneven walking terrain such as stairs and graveled pathways.  With that in mind, we cannot recommend this trip for those needing the assistance of a wheelchair, walker, or those with significant physical/heart conditions or limitations.
    Friday Technical Sessions:
    Pat Mathews – 3D Printing
    Greg Grieco – Excavation of the Riverboat Heroine
    David Antscherl – Building the Fireship Comet
    Friday Round Table Discussions:
    David Antscherl – Frieze Painting
    Steve Wheeler - Electroplating
    Chuck Passaro – Ropewalk Demo
    Greg Herbert – Making Scale Moldings
    John Vojtech – Unique Modeling Tools.
    Saturday General Sessions:
    Jack Custer – Using images to take off the lines of steamboats
    Dan Pariser – Comparing French & English ship building practices
    Gary Lucy – Researching models and settings for paintings
    Institute of Nautical Archeology – Speaker & subject to be determined
    Banquet Guest Speaker
    Christopher Gordon, President St. Louis Historical Museum
    Topic: St Louis and The Lewis and Clark Expedition
    You can download the registration form from the NRG website page here.
