Everything posted by michael mott
Need some (lots) help...
michael mott replied to Moab's topic in Metal Work, Soldering and Metal Fittings
Hello Moab I used a Stubbs Olympic #2 flat file with the wide sides ground off I spotted this set on ebay I would say that the #2 cut will do the job but you will need to get the sides of the file safe by removing the teeth to get the sharp edge. Obviously this is going to change the file for anything but the narrow edge cut. Michael -
Hi Moab I am wondering about the file that you used I thought I would try what you did and chucked up a bit of 1/16 copper rod in an old dremel I have and used an old flat needle file that I had ground off the side teeth so that only the edge teeth cut, the tricky part was keeping the file steady, I ran it at the lowest speed on the switch Then I cleaned the ends off with some flush cut side cutters My that is a tiny piece. I think the file might be the suspect. I hope this helps. Michael -
Home made Drill Press Vise
michael mott replied to RichardG's topic in Modeling tools and Workshop Equipment
A nice looking vice Richard, I'm guessing the moving jaw is also a slide fit on the base. Michael -
Thanks for the comments and interest. I had to make a start today....sort of like playing with a new toy. first the raw material I taped the lines drawing to the drawing board as a rough guide, and chose some Albalene drawing paper and set it over the drawing. next the baseline and the station lines, and diagonals were drawn according to the stated dimensions, using the table of offsets working out from the center line. Beginning with the sheer line, and marking off on the station lines I used a stick of clear pine 1/8th square as the stick for the ducks. These are slabs of 2" diameter steel with some shelf liner double sided taped to the underside to stop them sliding with some 1/16th steel rod shaped and pointed to grab the stick. As is clear the drawing is close but not as accurate as my line marked off from the table of offsets. The diagonals are off a bit on the print as well, of course this is all due most likely to the printing and paper stretch all the usual suspects. I am using a 4H for these lines, the trick being to keep the pencil sharp. This is so enjoyable, nice instrumental lute music playing in the background, a great way to spend the Saturday afternoon. Once the lines are drawn I will be able to plot the frames. Michael Michael
It was like an early birthday gift! The six drawings arrived today I opted to let them be folded because of the difference in the postage costs, as it was they cost $27 postal fees. Although the drawing state that they cannot be reproduced, I think that the obligatory picture of the plan chest drawer that they are now safely nestled in wont be infringing any rules. So with the table of offsets and the drawings as a guide I will be able to prepare a set of model building plans including the sawn oak frames. Still lots of preparatory work yet though. Today I am a happy camper. Michael
Hi Dan, I just came across this log, Hats off to you sir! what a super job you are doing with a very challenging restoration. Given my very limited experience working with bone, I would not be able to take on such a project, As Druxey mentioned the smell is apparent, and for me the game changer. Very interesting work on the "cooked " rigging lines. Michael
- 95 replies
- POW
- Bone model
It is always nice to use wood that you have prepared for yourself, and by air drying it it retains a particular character that kiln dried wood does not. Good luck with the stickering. I have used paraffin wax on the ends, the same stuff used for canning, just heat it up in a saucepan and paint it on with a pastry brush. If you cut it into thinner slabs than 1 inch it is good to put some weight on top or straps around the bundle to help with the drying flat. Michael
Bob thanks for the detailed information regarding the through hull outlets and the siphon loops. I had not really thought about this aspect of our modern small cruise boats let alone the older craft. I agree...But.... but my grandaughter would not. Seriously though The idea is to be able to show what can be seen relatively easily and a few things that need a little searching but still visible with perhaps a small dental type mirror. I do want to move on to the next project before I am too old to have fun. Thank you to everyone who is following along and showing their appreciation in one way or another. Michael
- 2,214 replies
Your work on the masts and rigging so far is looking really great nice and tidy, Im sure you will have no trouble with the ratlines. Michael
- 950 replies
- syren
- model shipways
It depends on the thickness of the material and the number of teeth. The coarser blades are generally easier for the wood. In this case the blade was fine enough to also cut the copper because it was sharp and had not become dull from cutting metal before. This graphic representation shows the .031 copper and the #1 jewelers blade that has 47 teeth per inch next to the edge of the metal there need to be at least 2 teeth engaging with the metal or the blade will catch and there is a possibility of ripping off a tooth and or snapping the blade. I hope this answers your question. I also have some #8/0, #5/0, #3/0 The #8/0 is the finest. Michael
- 2,214 replies
I'll have to wrap my head around this one! Just a never ending list of details...will it ever end?😉 Michael
- 2,214 replies
Well here is the truth about the new sink. First task was to start with a new former And cut a new sheet of copper .031" After laying out the cuts use jewelers saw. Then without any annealing begin the folds At this point I needed to do some cutting and used a small nibbler Then the trimmed edges need to be cleaned up this was done by first unfolding the metal a little Then using a bit of wood as a guide filed the edges. The refolded and wired the seams together and used easyflo silver solder to join the seams. My silver soldering skills still leave a lot to be desired but I am improving. and it looks better than the first one. I would do it differently if I had to do it again, making only clean corner joints...... but that's for another boat. Michael
- 2,214 replies
Yes this is interesting, The model is really a vehicle for my learning about model ships and boats. And in reality it is just that, because I am using materials and ideas from all sort of times and styles. I spent some time today discussing the bashed up sink with the owner and he said "well I know we are on a budget but its not that tight, cant you find a better sink than that." So looking around I found this one Michael
- 2,214 replies
Hi Vaddoc, I was not able to avoid "dog ears" as you say. I had to trim the edges a few times to remove excess material as it closed up Also I used some heavy needle nosed pliers a fer times to flatten out a couple of areas at the corners that were beginning to fold. I do not have the proper tools for serious metal smithing in a jewelers sense, so the final form is a bit crude. Sorry I did not take a few more pictures of some of the steps especially the trimming, to remove the excess, it was a lot of concentration during the work. Oh yes lots of stuff, And that is what is so great about this site I learn so much from all the wonderful things that the other members do. Oh oh.... I see another gauntlet.... I was looking at the web regarding stoves and it seems like the one in Integrity is a Taylor Stove there are some good photographs, it was also interesting reading about the pros and cons of the different fuel types, Old Style Alcohol, New Style Pressure Alcohol , plus the kerosene /diesel types and the LPG gas ones. Michael
- 2,214 replies
I had a long chat with the owner and he reminded me that we were on a budget with this refit so I mentioned that I would try to find a used copper sink, I found one on MYBAY it was the right price. Checked the fit Ok so here's how I did it Cut out a bit of copper sheet made up a former from some scrap maple 2x1.5x 3/4 then sanded it smooth. Annealed the copper and started bashing Many annealings and bashings later with a leather mallet and more bashings couple of different hammers but mostly with a too big ball pein. A couple of clean up hammerings and then cleaned up the top and dropped it into the pickle . I picked up the gauntlet Druxey you have a habit of dropping it.😉 I'm not going down that other rabbit hole Greg I think I read an article about that Model in a Scale ships or similar magazine I seem to recall it had gold and silver fittings. Eberhard, I have not figured it out yet I will be doing a bit of searching to see if I can find some better pictures of the type that is in Integrity. Michael
- 2,214 replies
A little more fiddling with the design of the kitchen/chart area with some card mock ups. Not much to say about these pics other than it is fiddly work putting these card bits in and out, but they will help me build the wooden equivalents. I think that I will drape mold the sink out of styrene then spray it silver. My silver smith friend would cringe if she hear me say that. Michael
- 2,214 replies
Wow! that is beautiful clean work. Michael
- 257 replies
- young america
- Finished
