Everything posted by michael mott
Thanks for all the visits to the log. I set up the jig to solder the stanchions to the top rail I set a piece of music wire through the top hole to align all the stanchions both longitudinally and vertically. I used the rail as the template for drilling the holes I dropped a stanchion in each hole as they were drilled to ensure that there was perfect alignment After the stanchions are soldered I can pull out the music wire and thread the nickel wire. Michael
- 749 replies
- albertic
- ocean liner
Nils the top handrail is brass that is painted. Michael
- 749 replies
- albertic
- ocean liner
Thanks all for the encouraging remarks. Finished drilling all the holes (gave me a stiff neck bending down to line up the first hole in each stanchion) and fitted them onto the deck. Threaded all four wires through that was the easy part. Before that I popped the handrail off the old stanchions And dry fitted it to the stanchions this was the difficult part. Ended up with needing to use the little clamps to gently hold it in place. tomorrow I will modify the clamps so that there is a small metal bar that holds the rail on to the posts. I will soft solder the rail to the posts, this was how the first posts were attached. The wires are the right color with some flat varnish on them so when it is all assembled I will give them a light coat of flat. Slow but its getting there. Michael
- 749 replies
- albertic
- ocean liner
Wefalck, A Myford ML7 which I purchased new in 1970. the spindle hole is a #2 Morse taper with a 1 1/8 x 12 threads for the chucks. In the pictures I am using one of the Little Machine Shop's set of 7 #2 Morse taper collets. I had to make a draw bar for them, The Myford Collets have a special spindle cap which pushes their collets into the spindle. Michael
- 749 replies
- albertic
- ocean liner
Jeff I am glad that this was useful for you. I finished the turning of the stanchions this morning, here is a Step by step of the process. The form tool was used to create 6 bulbs The bulb diameter is .065" and the shaft diameter is .045" the bulbs are on .085 centres. The top bulb was trimmed to its center on the top side to accept the handrail. the form tool was switched for the narrow tool to finish off the bottom, the lowest bulb was trimmed on both sides to create the foot. Next a #4 file was used to create the small taper at the bottom next the stanchion was separated with the jewelers the lathe was stopped for this operation The finished stanchions, a few of the first ones had some minor variations so a few extras were turned up to replace them. I will leave the set up on the lathe until I have made sure that I do not need to make any more. Next comes the drilling. Michael
- 749 replies
- albertic
- ocean liner
Wefalck thanks for the picture, it looks like a tricky bit of slitting, and one needs a good indexing chuck to do that, or a collet block. Keith This is how I accomplished drilling the holes and will use this method for all 28 stanchions I used a #4 flat file to create a small circular flat a little bigger than the diameter of the drill. The boxwood jaws are easy to cut a small rabbet on one of the blocks the distance between the bulbs is a constant .085" I index that with the table travel. stanchion drill.pdf Michael
- 749 replies
- albertic
- ocean liner
Doing more tests to come up with the right color for the handrails on the ship restoration I have been looking at whether the Beadalon and Artistic Wire products could be made to look aged by changing the color very slightly. I did pull the wire through some fine wire wool to see if that would dull it down, before attempting the heat treatment. The silver plating is very thin and the copper wire underneath started to show right away so I stayed with the shiny wire for the tests The method for this test is heat. Using the hot soldering gun to get some inkling of where the temp needed to be i found that the range between 35 -38 to be adequate to get the slight patina. I have been baking some at varying temps beginning at 350c baking for 15 minutes and then upping the temperature and watching for the subtle color change. 380c looks like a close fit. Michael
Wefalck A picture showing this Idea would be really helpful. Michael
- 749 replies
- albertic
- ocean liner
Thank you Wefalck for your detailed comments, The issue of very small collets for square stock is one that I have overcome to some degree using a round hole that has been cut with a slitting saw similar to the Dremel collets. this works well enough to put a round on the end of the small square stock. The comment about the type of brass is an important one, not all brass is equal when it comes to machining. I have found that some of the hobby brass rounds in the propriety hobby metal stands has been gummy to machine and the swarf comes off in long flexible curls instead of the crisp shavings of the free machining brass from the metal suppliers. That said the 3/16 and 1/4 brass that is in the Home Depot local store does machine very nicely. Ed thanks for your kind words, you have not missed the paint restoration I have been letting the paint mature for a while before doing the final sanding and polishing. your suggestion of replacing all the stanchions on that damaged section is in fact the method that i am now pursuing. Just like everything else we do in this hobby it takes a while to get competent at doing a repetitive task. It took about 4 or five stanchions to get the system sorted for making consistent ones, this is now underway. I will be setting them into the deck after getting the colour right then threading the rail wire in situ after it is colored. Druxey, questions such as yours are great because they give rise to considering all the alternatives as to why we choose the options that we do, which often sparks those "why didn't I think of that idea moment" Thanks to everyone who have been quietly visiting as well. Michael
- 749 replies
- albertic
- ocean liner
Kevin One of the gems of this video is the sound of the ocean at the end, that's not to take away from the great commentary of your trials and tribulations of the explanations of your building. Kudos to you for your honesty regarding the areas that caused you the most problems. Michael
- 1,102 replies
Bob I really like the look of this boat it is so Edwardian, would be lovely to build one at a large scale.....Must not let you tempt me....must not be tempted.... must not be tempted.... Michael
Very clever use of a device designed for a completely different purpose, it takes a particularly observant person to be able to see these sorts of opportunities. The winches look really good. Michael
- 1,208 replies
- great republic
- clipper
An interesting question Druxey My thoughts on it; 1 I do not know how much stress would be imparted on the stock while turning, of which I see two issues first the need to hold it in a collet of some type for such small square stock after drilling. And second the need to work as close to the supporting collet or chuck to do the turning, machining square stock always has an intermittent cut until one gets to the round, this in itself is a jarring motion at such small diameters it could be a problem. 2 The drilling of the holes is in my view the least difficult part of the operation. 3 With small diameter parts that are long the difficulty is support, one has a few options i) a cradle similar to the ones that Ed Tosti has used for shaping belay pins, ii) starting with the base diameter and incrementally extending it from a chuck or collet working close to the collet. As the free end gets further away some form of end support from the tailstock end works, this often need to be a custom type extended one because the toolpost and tailstock often interfere with each other. 4 beginning with oversized round stock is an easy option because the stock itself acts like a superb collet as long as the free end gets completed incrementally there is the opportunity to accurately index toward the lathe collet until the work is completely turned, Experience has shown that this method produces the least vibration and chatter with form tools, and as Wefalck has already pointed out brass can be machined with zero rake which makes form tools easy to shape. 5 Some experimenting with the form tool is always needed it seems. I have a clamp for my Dremel flex shaft that I can clamp into the bench vise to form a miniature grinder and using the carborundum shaping block I can shape the green stones easily for making tiny negative curves in the form tool. I hope this answers your question sorry its a bit long winded. Michael
- 749 replies
- albertic
- ocean liner
Very nice Jeff, by the way I have about 25 miles of some AWG 42 copper wire if you need a foot or two Michael
Wefalck I have done the end mill out of broken drills too, in fact I have broken drills on purpose to get a particular diameter of end mill Mostly I have done this with number drills. This drill however I sharpened by eye on my diamond stone like this. And a better pic of the stanchions. Michael
- 749 replies
- albertic
- ocean liner
Thanks to all who have looked in and for the positive comments. Today I made the choice to replace a few of the stanchions which I was not happy with. I cut the ones I want to replace out of the rail this is one of them First I made a form tool to shape the rounded parts, and also used the small parting tool to make them from some 3/16 round stock. The 3/16 is strong enough that I can begin at the bottom and shape the first 1/4 inch or so while the rest is still 3/16 for support. The form tool is then used to form the bulbs incremented .085 at a time along the 3/16 it is pushed in to the finished diameter then moved along the next .085" to then form the next bulb and so on until we get this configuration Then the stanchion is cut off the 3/16 with a jewelers saw, and clamped into the soft wood jaws for drilling with a #73 drill it is short because I broke it some time ago and had to resharpen it, this turned out to be a benefit because I was able to drill accurately without having to spot it first. Before drilling however I used the #6 cut file to give a tiny flat across the tops of the bulbs to give the drill a flat surface to start into. and they seemed to turn out alright. Having done this I have also realized why some of the stanchions are slightly different within one run of the handrail. I think that the stock of stanchions that were used by B&L were made in batches and the tool setting probably done with a screw cutting capstan lathe had very slightly different set ups of the stops with each batch and that from the bin of stanchions they were pulled without much regard for the very minor discrepancies. These are really only noticed when one gets as close to the detail as I have been doing. Michael
- 749 replies
- albertic
- ocean liner
Druxey I was very surprised at how easy the whole drawing operation was. The most fiddly part was filing the end down to fit through the next size smaller hole so that it can be grabbed with the draw pulling pliers. The last draw almost doubled the length of the wire. My friend says that the smaller the diameter the easier it get to pull, she is correct on that score. The first two pulls were the hardest to pull but with each hole after it became easier. Sometimes it helps to use a little wax on the wire but I did not need it. Pat I am not sure if it was typical, the company Basset Lowke used a mix of brass copper and Nickel silver (German Silver) in this model. Brass was certainly a common metal. One of the tests will be to see how well I can put the patina on it so as to match the other wire, I think that the hot air soldering gun will be the tool to use. As I mentioned earlier the stanchions have been painted it is almost like a stain it is so thin and the colour on most of the handrail look like a ringer for the patina on the aged nickel silver. The top flat handrail is brass and painted a brown colour. Once I get the colour right I think I will add enough wire to span a couple of stanchions and but the one end ext to the silver soldered one and feed the other end into the middle of the other stanchion and use the hot air gun to soft solder the end. Its good to explain this because it is helping me sort it all out before I get on with it. Michael
- 749 replies
- albertic
- ocean liner
Jan the pictures are lying. Wefalck, I only made the ball handles on the prototype, they take a long time to make. Actually Nils I am hoping that the ship will look like it hasn't been repaired and looks like it was built in 1920 something. Mark and Denis thanks for you positive comments. I spent a bit of time in the big city today visiting my silversmith friend who just happened to have some .8mm nickel silver pins which I pulled through the draw-plate down to .45mm. so I now have enough wire to fix the melted sections and all other very bent parts. I also noticed that the stanchions are painted which will make matching the discolored ones easier to match. Michael
- 749 replies
- albertic
- ocean liner
Gerald, thank you very much for your detailed explanation I shall check out the tooling on your site. Michael
- 281 replies
- falls of clyde
- tanker
Hi Druxey, yes I need to replace a couple of 1/2 inch sections of horizontal rail wire. which is 22 gauge nickle silver. Michael
- 749 replies
- albertic
- ocean liner
Again thanks for all the positive feedback and for the quiet visits. I set up the soldering area today and put all the broken ends back on the top handrail stanchions. I had a couple of minor issues but they will be solved fairly easily I think. to recap this is what happened to the top handrail, it was bent over and 6 of the stanchions were broken at mostly the bottom rail. I began adding the broken bottom parts of the handrail used the #4 tip All 6 soldered on with a couple of these to add to my work. Next task was to do a quick test fit so I am relatively happy with the effort. Now to clean it up and fix the meltdowns. Michael
- 749 replies
- albertic
- ocean liner
