michael mott
Everything posted by michael mott
  1. Hi Dan, I shall be following along. I am expecting those funnel lattices to be fabricated from rods and integrated with the sheet-work at the bottom, contrary to Druxey's comment. Michael
  2. Plumbing fittings do make nice foundations for all sorts of stuff don't they. Nice work on the rim Keith. Michael
  3. Actually each extra hour now I give them money as well..... Thanks for the very nice comments and for the likes. Michael
  4. Richard, interesting difference in price for the little clamps $1:50 versus 4 pounds sterling The other clamp style is what inspired these clamps Apologies I did not mean to hijack your thread. Michael
  5. I noticed the pile of hulls in the background in picture #8 look like you have been busy. Michael
  6. I am enjoying your build log Frederick, I smiled at you comment about the different numbers that you scaled from....been there done that.... more than once. Michael
  7. Looks great, you are going to need a small dental mirror to show the details on the inside of the engine compartment. Michael
  8. Your joinery is superb, I noticed in one of the pictures some small cam-lock clamps where did you get them? Michael
  9. Thank you all for your constructive and complementary comments, and for the visits. The Saga continues. I finished cutting out the parts for the new Davit. The 8x32 thumbscrews make it much easier on my fingers Allows me to concentrate more on following the line than being a human clamp. All the parts cut and cleaned up. And dry assembled I turned down the shaft from some 3/16 which allowed me to start at the small end which is .025" then the long part is .038" and the handle end .081" while it was still part of the 3/16 shaft i drilled the cross hole in the same way as for the sliding collar that moves the davit forward. The picture shows the hole being drilled in the collar which was shaped afterwards in the pin vise with some #4 flat files. The main frame side parts were annealed before folding, I needed to keep reminding myself that these parts were handed a left and a right (made that type of mistake too many times to count.) Set them up in the new clamps in the third hand I am liking the difference between the two types the parallel one holding the side and the single screw one holding the centre plate, it takes a while sometimes to do the set up but I cannot imaging going back to the old unit with the crocodile clips Used the Duz-all flux and a tiny flake of solder the hot air soldering gun and away she went. the next picture shows the other end after it was soldered. After cleaning it up in some hot vinegar and baking soda with a toothbrush A coat of Modelmaster black enamel. Michael
  10. I know, I was just kidding, but you knew that. I do look forward to seeing how you did it though. Michael
  11. Beautifully executed so far. Ed in the last post you had mentioned that a description of the mast covering would be explained. It looks like wrinkled canvas from this height, but are you keeping how you made it a secret......I have my own thoughts about how you made it, which are likely different from what you did. We are a vigilant lot sir! Michael
  12. Amalio Absolutely beautiful work. It would be good for you to answer some of the questions though, after reading through the whole thread again. a lot of good questions remain unanswered. Your skill at the craft is very apparent, and sharing your knowledge would be of a great help. Pictures are fantastic but do not tell the whole story. Respectfully Michael
  13. That looks like a nice bit of turning Keith. Michael
  14. Keith thanks for the link. And a big thank you to all those who have been following adding a like to the posts. Denis I had to do some careful number counting do do the first batch, now that i have modified my leadscrew hand wheel this second lot was much easier to make, it takes a few to get the sequences down but then it is just a matter of following the settings for each tool. I have been plugging away at filling the holes on the side of the hull, I am almost there just a little more on the bottom side then to do the final painting and polishing. befor reinserting the portholes. Michael
  15. Hi Walter, Great to hear that your wife is getting better and that you are able to spare some valuable time for your shipbuilding. regarding the cad stuff I have found like yourself that the 2D works well enough. I too found the learning curve a bit too steep for my liking. Michael
  16. Riccardo, thanks. I sent you a PM Michael
  17. Looking at the wax masters reminds me that there are so many different ways to accomplish the same result. Some requiring complex machinery and even more complex computer programs and knowing how to use them, others requiring thinking outside the box and seeing a wood or plastic bead in the craft bin that is the right size next to the tiny pins in a packet of 500 and the plastic or brass sheet to cut the blades from. And then the old fashioned methods of shaping round stock on a lathe and silver soldering shaped brass blades into milled slots. So much to learn so little time to absorb it all. Again beautiful work Alex. Michael
  18. Nice Patrick, nice, vera nize!! so now fess up where did you get the giant hand and giant fruit bowl that you often have in the backgrounds. Michael
  19. Where do you leave the trash can?.... just kidding. Michael
  20. Your attention to the details and the documentation of them is really very useful and educational Ed. Thank you for taking all the extra time that this takes. Michael
  21. Thanks for the link about the scraper, very interesting video, I have some 1/8th x 2" tool steel plate so might give something like this a try. the steel he is using looks to be about 3/16th thick. The card type (as he calls them) do get quite warm on the finger tips and he is correct when he states that it takes a while to learn how to sharpen them properly. Michael
  22. I have not used a Sherline but this chap is doing some amazing work in metal on one, and has some interesting comments about the handles. http://www.modelenginemaker.com/index.php/topic,6515.60.html the page is talking about machining stainless plates for a steam hauler, if you scroll down there are some pictures of his model ship building, which is very nice too. Overall it looks like a very nice machine. if I were looking for a lathe and mill combination I would seriously consider this machine, Bob's comment about the cutters is useful, remember that you can purchase metric cutters as well. Michael
