Everything posted by CDW
I'm going to be using inks and water colors (pencil water colors) to reproduce the plywood look of the Albatros airframe. I've seen master modelers do it and it looks quite convincing. Me?, who knows how it will come out but I'm going to give it a try anyway. I'll first be laying down a primer coat of Tamiya flat white (I already did that tonight and let it dry), then the inks go on second with some fancy brush work, some stray water color pencil, then Tamiya clear yellow, then clear orange, then regular clear. Phew!
And the early version of the modern bomber was the B-35, which is older than the Ho-229. The USA issued contracts for the plane in 1941, long before the war ended and any HO-229's were known of.
Glad you're aboard Denis. Squadron has a surprisingly small inventory in stock for a major distributor. As many know, Squadron is MMD, the well known hobby distributor in the USA. "Just-in-time" ordering is the new normal, so warehouses just don't keep inventory on hand like they did at one point in time. While I've never owned a large business who had to be concerned about things like these, it's my understanding businesses pay taxes on inventory in stock, so they try to avoid that as much as possible.
Maybe you could try some Lycra thread. It stretches without putting a lot of pressure on the plastic parts and easily retains it's tension over time. Plastic ship and aircraft modelers use it all the time.
- 90 replies
- bomb ketch
- pyro
A beautiful model. It's stunning, really. Can't say that I have ever seen one nicer model at this scale using plastic as the primary component/s medium.
- 90 replies
- bomb ketch
- pyro
Disappointing about that poor fit of deck to hull. On a modern, expensive kit like this, that should not happen.
Beautiful work. I've been waiting a long time to see someone make a detailed build thread for the Revell CSS Alabama and you have certainly filled that void. My copy has been on my shelf for lots of years, waiting to be built. Your thread will serve as an inspiration to start mine.
Sig epoxy has become harder to find but can be bought on line directly from Sig. Here is an on line shop I order from a lot. Excellent service and lightning fast turn around time to receive orders from them. Best thing is, they only charge $3 for postage and that's real hard to beat. This epoxy is not Sig, but I've used it a lot in the past with very good results. I recommend the 30 minute epoxy rather than the 5 minute as it gives you extra working time before it kicks off. https://www.headsuphobby.com/search.asp?keyword=epoxy&search=Search
That's odd. I have used epoxy many times on plastic models in the past and never had an issue, although I generally use Sig epoxy and have never used Loctight epoxy. In addition, I like to use one of the faster setting epoxy that Sig makes, like the 10 or 30 minute set variety. It suppose it could be just as you suspect, that there is something in the composition of that particular plastic that has a reaction to the epoxy you are using. I bought some high strength CA from an auto body supply shop that uses as an add-in, metal fillings. That CA gets so hot when it's curing, it would completely melt plastic.
Yes, you are correct. Squadron offers it "for order", meaning they will eventually get you one if you order it, for the discounted price. However, I don't believe they charge your card until they actually ship the kit to you. To do otherwise would be illegal, or at least against the rules for the banks who back the charge cards.
