Jonesey
About Jonesey
  • Birthday 08/15/1954
  • Gender
  • Location
    Bristol, UK
2,095 profile views
  1. Mark, your health is far more important than building a ship! Get yourself well before you even set foot back in the shipyard
  2. The pink tube you can see in the vice is from an old vacuum cleaner. I cut it down, applied a dozen or so layers of gaffa tape on the end to seal it, put red hot water in it for plank softening
  3. I can't believe it's been so ling since I posted, or indeed worked on the model Anyway, I've reached a milestone of sorts - the first layer of planking is now complete The hull is riddled with errors & mistakes, some avoidable, some entirely of my own making and some due to a total lack of experience This is my first ever attempt at planking See what you think
  4. And as luck would have it, my usual supplier - Cornwall Model Boats - are out of stock 🥺
  5. Thanks all. Looks like I ordered #1
  6. Can someone tell me what the difference is between these 2 blades? I need some more of the larger ones, but the ones which arrived are the smaller ones Thanks
  7. I believe you make these from one of the rounded dowels, cut in half and the centre portion cut out (it alludes to this in the diagram)
  8. Hi Eugenio Progress has been very slow this last year - work & life always get in the way However, I've moved the shipyard from the garage to our old kitchen area which doesn't get any use and intend to carry on in the warm throughout the winter. My first layer of planking is progressing - I'm hopeful this is the most complex part of the build, but time will tell!
  9. Yep. Corel instructions leave a LOT to be desired. It's sometime quite unfathomable exactly what you're supposed to do and crucially, in which order
  10. Personally I think you'd be better off planking the deck yourself Colour one long edge and one short edge of each plank with a black felt tip (one that doesn't run!) to simulate the calking before applying glue
  11. Looking good David! Patience is definitely the key
  12. Yes, regarding that Elmers link on Amazon UK, it says "product currently unavailable" which is a shame
  13. Your build looks absolutely fine so far, well done I'm delaying the option to fit copper tiles until I see how the first layer of planking turns out. I'm more or less at the same point as you on my Corel build but the really challenging parts are up next - lower hull/stern/bow I'd post some pictures but I'm currently soaking up the sun in Gran Canaria 😎
  14. Had a bit of an accident tonight. I snapped off the top of one of the bulkheads 😕 After sanding the edges down there was a gap of about 2 mm which meant the piece I intended to glue back on was 2mm lower than it should be, so I had to make a small filler to raise it back up If it all sticks ok, it shouldn't be a problem as the top deck isn't glued down yet and the offending piece will be hidden on the outside by the hull planking and on the inside, it's covered by the top deck Set me back by another evening though.
  15. Thanks for the pictures mate, just what I was after
