dgbot
Gone, but not forgotten
Everything posted by dgbot
  1. Impressive joinery. One small mistake and you have to start all over again. Bravo on your patience and steady hand. David B
  2. Having a small mill can be nice. But if you do not have the training it can be a very expensive drill press. If you know what you are doing it can do many things. David B
  3. I also use Elmer's I find that it is the easiest filler to use.. David B
  4. A couple of years ago I bought this kit at a good price. I am looking at it again and I wonder of anyone has built it. David B
  5. Model Shipways and Blue Jacket have the best instruction manuals as far as I am concerned David B
  6. There are several tutorials about planking. Several of them can be found here. A single planked model means you have to take a little more care when laying your planks. Try to plan ahead and double check your runs. This will involve bending and shaping them to fit the hull . David B
  7. I have experimented with windshield wshing solution with good results. However if you can use the thinner recommended that is the best way to go. David B
  8. Two books come to mind that should help you. Tabletop Machining by Joe Martin and The Home Machinist's Handbook David B
  9. Does the Proxon run at a higher RPM to compensate for power? If so this mght be the problem. The jim Byrnes saw is a powerful beast. David B
  10. You can buy these blades from Thurston Saws, Or try MSC International. or Enco. David B
  11. I have to agree with all of the rest. Great job. Kudos! David B
  12. Great work Toni. what kind of finish are you going to use when you get to it? David B
  13. Great work on your A frame. And I like the look of your dredge guards. A great way of thinking outside the box. David B
  14. One of the things about this boat is all of the various models there were. You are going to have a lot of fun detailing and outfitting it. Keep up the good work. David B
  15. This book is a must have for anyone wanting to build a fishing schooner from the late 19c to 20c. David B
  16. As Wefalk said you need a dead flat surface for honing an engraver. I made mine from HSS tool steel and drill rod. After grinding them to the disired shape I made a fixture and used that to hone them. I turned down some dowels and used them for the handles. They are very easy to produce. and fun to use. David B
  17. For metal turning of brass I have made my own out of tool steel and put them in a handle. They do come in handy every now and then. David B
  18. I use both. metal to wood for CA and pva glue for everything else. PVA in my opion works better for wood. You might have to clamp the part but the end result is better and stronger. A CA joint has little shear strength and can be difficult to clean up if you use to much. David B
  19. I looked at the hotels website and by default they seem to have nothing but double rates for $119. I will probably have to phone them to get the single rate. David B
  20. Great work. To bad you do not own the real thing. David B
  21. Not at all. Over the years I have replace the ply bulwarks many times. As for a solid sheet or a built up it will depend on your patience and the model you are working on. David B
  22. I use a Smith's Little torch and am glad for the investment. As a result I can do small joints as well as large ones. The secret is using the right size of flame for the job. This will be learned through trial and error. David B
