tkay11
Everything posted by tkay11
  1. I am looking to adapt my Proxxon DB250 wood lathe to accept ER16 collets because although this lathe comes with some collets, there is a gap between the 4 and 6mm sizes. The Proxxon lathe has an M16 spindle, and I already have a 3/4-16 adapter for ER16 collets on my Taig Lathe which uses an ER16A clamping nut on the adapter. So the question is: does anyone know of a supplier of an adapter (a) from M16 spindle to 3/4-16 nut, or (b) from M16 spindle to any kind of ER16 collet holder or to an ER16A clamping nut? Another question would be if there is anyone willing to machine such an adapter for me, for which I would willing pay the fee. Thanks Tony
  2. Well said, wefalck and Dr PR. Another way of looking at it is to say that if you can hardly see them with your eyes 5-6ft away on a real ship, then at 1/64, with plugs 0.5mm diameter, imagine trying to see them 5 x 64 = 320ft away. There are so many conventions in building models of models: the framing of Admiralty style models for example. But in such conventions there is another consideration: the beauty of the model itself, which is perhaps what people try to replicate. Tony
  3. Thanks, allanyed, it may indeed need to go below the thwarts. Unfortunately while in the real world the thwarts were removable, I've just realised that I didn't think ahead for the model and I have fixed the thwarts very firmly in, knees and all. I tried putting it under the thwarts and then spent a good time trying to extricate it again -- a bit like one of those 3D puzzles. @wefalck: I can see that I may well have to follow that idea and hang it over the rail. The 20 oars are also going to have to work out where they'll occupy space or else be wrapped and carried on either side. Tony
  4. I am making the various accessories for my build of the Chaloupe Armée, a 42ft 1834 French Armed Longboat. I have made the grapnel anchor as per the picture, but, having done so, wonder how and where it would have been stowed on the boat as it has such an awkward shape and was clearly quite hefty. It's 40mm long at 1:36. I'd be really grateful for any advice or comments. Thanks, Tony
  5. Treenails on a deck are barely visible on a real ship. Check this out with some photos, e.g. of HMS Victory where you can just make out the slightly lighter shade of the plugs covering the bolts in the deck. Typically they're about 32-38mm, so at 1:64 about 0.55mm wide. At 1:64, you have to imagine yourself staring down at a deck from 64 x 5ft = 320ft and thinking how visible those treenails would be. Some modellers manage to do it in a very subtle way by lining the holes with a gentle edging of lead pencil and filling with some very similar-coloured filler or wax. all you have to do is practice on some spare planking until you have found the level of visibility that pleases you. But there's no shame in not demonstrating them. Tony
  6. L'Egyptienne of 1799 also had them, according to the new monograph by M. Delacroix. Tony
  7. The Proxxon DSH scroll saws come up regularly on eBay for about £100. I bought a refurbished one from Axminster for that price on eBay and it works fine. The only thing is that you really do have to finish off with a sander, or careful sanding, and I now tend to use a coping saw much more now that I have built my own jeweller's bench pin. The problem I have with the coping saw is that I still find it difficult to make perfectly vertical cuts all the way round. But I suppose that's something that comes with experience. Tony
  8. Welcome to the club of self-inflicted errors of which I am a member. I am sure there is a very large (though uncounted) membership. It's one of the best ways of learning as such errors burn so deep. And take heart: it reveals an independent or perhaps an experimental mind. Some of the world's most remarkable discoveries have been made by ignoring centuries' old advice, though admittedly such discoveries are very rare. Tony
  9. The idea of laying one plank from front to rear may be part of the advice to lay strips that will guide the division of bands. I don't think this would be for permanent use. Normally model makers would use string or thread to do this, but in real life the shipbuilders would place planks along the hull for this function. Tony
  10. I don't really understand your question about the first plank that goes against the bulwark, but there isn't a plank that goes all the way from bow to stern. Hull planks were generally 20-24ft long (@1/64 = 4.5" or 114mm). The Sherbourne was 54'6" long, so would have 2-3 planks per strake. Planks are indeed curved at the bow and the stern, and Chuck's planking videos demonstrate how to do this using heat alone. Normally (as you'll also see in the various planking tutorials) you have to calculate the width of the planks at each bulkhead, either using a fan of lines (the easiest) or by arithmetic. It would be very difficult just to use the full width of the plank and adjust the width as you go. One immediate problem would be how you would work out how to shape the first plank you laid. You would then get into real difficulties as the number of strakes increases, unless, of course, you don't mind your planking to look a real mess which you would hope to cover up with paint. As you will have seen from the videos, the easier way is to start by working out in advance how many strakes of planking you will need for the hull. At its very simplest, this is done by measuring the distance between the top of the largest (midpoint) bulkhead (at the position of the first strake) and the keel using a piece of string or thread along its curve. You then take the width of the planks you have (I think the kit ones are 5mm) and divide that into the length you have found. So if the length of the bulkhead is 100mm, that divided by 5 would give you 20 strakes. So you now aim to have 20 strakes at the bow and 20 at the stern. This may be impossible as you can't have planks that are too narrow at their ends, so this is one reason why you may be forced to add a stealer. The determination of the number of strakes allows you to take each bulkhead and divide its curve length by 20, and mark off each width accordingly with a pencil on the bulkhead. Most people divide the hull into bands, and plank each band in turn to help avoid problems of 'cutting creep'. You also have to take into account that the garboard plank will be wider than the others. It may be a good idea to look at the printed guides to planking provided in the resource centre on this site, in addition to the videos, as that may allow you to absorb more fully the various ways in which planking can be approached. I hope this helps and that I haven't muddled things even further! Tony
  11. I seem to remember the main difficulty was with the carriages and trucks, especially extracting the carriage wheels. The other difficulty was ensuring the correct height of the gunports as they vary along the side. I had to cut cardboard outlines of the guns in their carriages in order to ensure they fitted properly in the gunports. Ideally, this should be checked before you plank the bulwarks. Tony
  12. Good to have another Sherbourner! You've probably seen them, but if not, I strongly recommend the Dubz, Gregor and Stockholm Tar builds for interesting discussions as well as hints and tips. Dubz (Dirk) put the keel, stem and stern on after the first planking and before the second. That allows you to use them as a kind of rabbet -- although it might be best to leave the sternpost off till after the second planking as there is no rabbet on the stern and you can cut off the planks absolutely square without a problem if it's not there. Why not have a look at the state of the model after the first planking and then decide? I wish in hindsight I had not placed them before any planking, or at least had protected them with tape, as they ended up with lots of scratches from sanding. Tony
  13. I wouldn't regard the build logs as master works, more as guides, hints and tips as to how to approach the various problems you definitely will encounter. Of course some of the builders may have more builds to their name than you have, but I, for example, had as my first kit the Sherbourne and immediately was given a great deal of help by others (some of whom had never built a Sherbourne). I benefited hugely from reading the logs in detail and then deciding whether I could have a go at some changes to the kit or not. I very quickly came to the conclusion that it wasn't that hard to modify the kit in various ways and in the end the only bits of the kit I used were the internal bulkheads, the first layer of planking, the keel, stem and stern, the rudder, the nameplate and the anchors. I had no previous experience other than assembling simple plastic kits as a young boy, and had never done anything like a wooden kit. Others prefer to stick to the kit. Whatever you choose, you'll end up with something you're proud of and you'll have learned a lot. The end result was nowhere near their perfection, but I certainly had a great time learning! So my message is, don't be frightened of what you see as others' perfection. Everyone on this site started as complete novices some time, and they all have experienced the same problems and mistakes that you will. The members are a really helpful lot, so don't be afraid to ask questions. There really isn't any question that is too stupid to pose! I hope that helps a bit! Tony
  14. A good start. Watch out for the height of the gunports above the deck so as to allow the cannon to go through without a problem. You can make a card cutout of a gun in order to do this. Glue stains on wood have a nasty habit of poking through, so you may need more than one layer of paint. It's worthwhile thinking about how to use the minimum amount of glue to avoid spill. If you're using PVA a quick wipe with a damp cloth on any excess will do the trick. Another way is to use a toothpick to pick up excess from corners immediately after gluing. CA glue is much harder to hide or wipe, so you need to be much more careful with that. I'd also protect the stem, keel and stern from further damage as you plank and sand. Some people put these on after planking in order to avoid the damage, but putting tape over them will also work. As you know, luckily there are lots of excellent build logs of the Sherbourne on this site which really are worth studying. They will help you with such details, will point out pitfalls to avoid before you get to them, and people no doubt will also pop in to help you as you progress. It's an excellent model to start with, and allows you many possibilities for improvement as you get into it. Tony
  15. Sorry to butt in, Vaddoc, but I'd like to ask a question. I've enjoyed this thread as it has gone into the difficulties of 3D design. It makes me ponder all the more at the work that goes into the various 3D designs on this site based on old plans (the fully rigged Swan class 3D model being one amazing example) which seem to have all the right parts in the right order in the right places (with acknowledgements to Eric Morecombe). Like some others, I also use 2D CAD a lot to replicate parts of plans, design my own parts, double check dimensions etc., but I have often wondered how to use a CAD programme to 'straighten out' the planks to provide their accurate flat dimensions before bending. This seems a very useful function of CAD in order to be able to predict (albeit roughly) the width of planks to cut and therefore of amounts of wood to order. So, as an aside, would you be able to provide a quick tutorial on how this is done, or point me to somewhere I could find out about that? Thanks Tony
  16. I forgot to say I still struggle with the planking myself, but, as you suggest, every time I do it I get a bit better! At least I think I know how it should be done! Tony
  17. I don't know if you've read the various planking tutorials on this site, but just in case you haven't they're really worth studying. If you go to the forum for "Building, Framing, Planking and plating a ships hull and deck" this points you to the planking tutorials. Chuck's tutorials are particularly good on spiling and bending with heat alone (i.e. without soaking the wood or using steam). Tony
  18. Just catching up with a few months away from following build logs, so sorry if I'm butting in a bit too late. I've been considering whether to build a Triton full build, so it's been interesting to follow your own progress. With regard to your comments about the difficulties with your planking, it may be an artefact of the way the photos are taken, but I can't see the pencil markings for your plank widths on the last two bulkheads. The width of the planks at the stern seem to be wider than the marks on the third last bulkhead would suggest. Might that be a source of difficulty? Tony
  19. Thanks, Frankie and Gregory. I'm really glad I could share the photos and that others have found them useful. Tony
  20. Aren't fiddle blocks only found amid the mast tackles? That would reinforce the point if so. Tony
  21. Very nice, Dave. I have had the same experience. After making several parts in what I have thought to be exactly the same way as on a previous model, somehow, magically, they seem to come out better than the earlier ones. Tony
  22. What a nice model! Thanks for the many ideas you've provided in terms of paintwork and metal work in addition to your usual lovely craftmanship. The flintlock cover is a clever addition. I also like the simplicity of the base. Is it stone? What's next? Tony
  23. Wonderful to see your work on this. I also appreciate the shots of a similarly-sized boat to show just how big it is. Thanks! Tony
  24. Nicely executed. I'm impressed by the speed at which you have been able to work. Congratulations! Tony
  25. There are some very simple jigs you can make to ensure the deadeyes are all in line (though on real ships they quite often were not that straight, so this is more of a model-making convention). I made mine with paper clips. See the following, a few paragraphs into the post: By the way, I strongly recommend the late Hubert Sicard's site Wooden Ship Modeling for Dummies. This is now maintained by his family. A lot of it is free, but you can get a lifetime subscription for $40. I used it extensively. It has plenty of free videos and focuses on using the most basic equipment with the minimum of power tools. Tony
