Everything posted by tkay11
@0Seahorse: Another lovely model, Tomek. I just have one question, which you may have answered before with your other models, but I cannot find it. I apologise if I missed it. Could you let me know how you make the effect of grain in your 'wooden' planks lining the hull and on the decks of your other models? You seem to have developed this to a high degree with this model and with Sao Gabriel. Do you print them out simply from a printer? If so, how do you achieve the effect of the wood grain? I know other card modelers have used a foil for this purpose, but you indicate on other models that you just print it, or simply paint. Thanks for any hints! Tony
- 17 replies
- Vistula barge
- card
AAH! OK. I also bought an adapter from MicroMark and imported it from the US along with a couple of zero kerf blades. Thanks for the clarification. I hadn't realised that that's what you meant. Interestingly I have hardly had to use them, using the Proxxon blades instead for all but a few jobs. Tony
@bruce d: When I first saw this post, I briefly wondered what you meant by a spacer/adapter. I have used a number of jigs when cutting with the thin slitting saw, but haven't thought of them as spacers or adapters. Could you let me know what you meant? I'm intrigued in case I'm missing a neat trick. Tony
Does anyone know of a supplier of Black Hornbeam timber in the UK? The regular guys here don't seem to advertise it, other than the normal pale hornbeam. It seems to be commonly used in Eastern Europe by modelers, and it does look very nice! However, I can't find its qualities on the usual searches and so don't know anything about its working qualities. There is some available from the Ukraine on eBay, but I wonder about risking that at the moment. Any thoughts or suggestions, anyone? Thanks Tony
@Ondras71: Thanks very much. Excellent video and ideas. Looks like he modified the Proxxon saw table a bit as well. Tony
I am intrigued, BE. How do you drill holes at right angles when I would have thought the drill bit alone would be far longer than the space allows? Tony
- 855 replies
- Sphinx
- Vanguard Models
I wouldn't be so hard on yourself, George. It was a very useful book for me as it started me thinking about how to make the kit better. This led to very good discussions with others who were building the Sherbourne. As you say, whether, with hindsight, there are things you'd like to change, it is a guide for the beginner, and the only one I know of that puts it all together in one piece. Tony
- 10 replies
- Sherbourne
- Jotika
(and 5 more)
Pieds and pouces, anyone? Converting those from the French to anything is another concern. The Ancre publications refer to both metric and ancien when providing measurements. If you use CAD, though, it's fairly simple to draw the plans at full size in whatever measure, then reduce to whatever scale needed and then take the measurements off those plans using either metric or imperial. CAD doesn't yet do pouces and pieds, though. How about the length of one of the mediaeval kings arms or feet, though? That might prove fun. Tony
George, I remove the cellotape before gluing. I am using a paper template glued to the deck to make sure the planking is correct, and as the paper is only 0.13mm thick the final result is only just over the ideal 0.5mm. I had the idea from Frolich's book on the Art of Ship Modelling, but had forgotten it until a few days ago. Tony
You're right, wefalck. I've discarded card as an idea (I suppose I could have just said I've discarded). I've found I can cut and form these planks using individual plank templates and a cellotape backing to prevent splitting. It's a bit fiddly and takes a long time, but that's the essence of the hobby. And the enjoyment if it turns out ok! Thanks for the continued thinking! Tony
Thanks, George. I agree totally with the sentiment. I, too, often go beyond scale, especially with ropes -- as I will on this model should I ever get the masts up. All the same, I am treating this model as another way to learn about handling wood and how far I can go in following scale and plans. I may well discard it once the hull is finished. The problem is that the edges of the waterways go right to the edge as the deck has no bulwarks other than at the bow. They are the same thickness as the deck planking. The real scale thickness is 0.5mm. However, as you suggest, I am tinkering with the idea of going ahead with 1mm, and sanding that down a little in the recognition that few would ever notice that the scale was not correct. None of my family would ever look at plans, as they would just appreciate the lines of the ship, which is pretty much what I like to do. My next option is to print on cream-coloured card, though I don't like the fact that it doesn't look much like wooden planking (even though it is made of wood!). Thanks again for looking in with your usual wise words. Tony
Thanks, Bob. Very helpful, and thorough in your reply as usual. The trouble I face is that I am trying to stay to scale, and that means that even with the smallest veneer I have (0.48mm) it would still provide a plank 1.8" thick. The plans of the Jacinthe and those of all the other French ships of the same type that I have studied from the period have the same approach to the deck planking. I had considered most of the options you suggest, and I do understand spiling (which I was preparing for), but was worried about the various options that would mean cutting the planks with a scalpel rather than planing the sides, especially with with the rolling taper of the planks which looks as though it is slightly different on each side. I was thinking that might end up without the perfect curves necessary. I am also prepared for edge-bending the planks as I am quite used to that with thicker planks. I haven't yet tried it with thin veneer, though. I certainly can try. In terms of the options, I'd been thinking about preparing the deck flat on a card or paper base (as you suggested and which indeed is the option used by Lloyd McCaffery in his book Ships in Miniature). Lloyd says that for a rolling taper such as the one I have, he uses trial and error, but after having glued several planks together. With my 0.48mm veneer laid on top, I could try this but am still worried about getting the curves right as the curvature seems to differ on each edge of the planks. It may well be that gluing the veneer to the base will help prevent the splitting that I find often with such thin veneers. Another possibility is scribing a sheet of veneer through a mask, but that would require me to buy some wide sheets of veneer, and I would still be worried about scribing it perfectly. Another possibility is printing the deck on to card as do the card modellers, but I have tried that with the Allège d'Arles at the same scale, and couldn't get the paint or card colour to really mimic a wood deck. A very expensive option is to have a sheet of veneer laser-etched, but although I've seen that done on thicker sheets, I'm not sure that that can be done on such thin sheets. What may help is to use a harder wood such as castello or holly. I'd been thinking of lime, but it's harder to cut without splintering. I think, in the end, that I'll just have to experiment a bit, as I nearly always do, and see what I can come up with. I have learnt to work through imperfection and some day it might come out right! Thanks again for your vast experience and helpfulness! Tony
I continue to experiment while learning the art of scratch building. The latest stage is figuring out how to taper and size deck planking that is curved to the lines of the hull, as in the following diagram from the plans of La Jacinthe at a scale of 1:96. I can see that from the middle to the stern it might be a simple job with a plane, but the taper does seem to be variable, thinning mostly at the stern where the planks go down to 1.25mm width. The same goes for the forward end where the nibbing of the planks makes it more complicated. I don't want to waste a lot of wood with endless imperfections, so would be grateful for any suggestions or hints from those with experience of doing this. I have seen many examples of this in build logs, but none that have explained the technique of doing it. Thanks in advance for any help, Tony
Proxxon compound table KT 70
tkay11 replied to Dziadeczek's topic in Modeling tools and Workshop Equipment
The short answer is no, it won't fit that table if you want all holes to fit in the table slots. However if you just use the two front or back holes using appropriate bolts and square nuts, it will fit one slot, although this might be a bit less stable. I have the MS4 vice, but I found it to be very poor for precision work and not suitable for the KT70, so I bought the excellent Proxxon PM40 precision steel vice (part 474981) which I use both on and off the table. This has exactly the same slot fixings as required for the KT70. It should cost around US$40 in the USA. I bought mine for round £35 seven or eight years ago, and it has remained my favourite small vice. Good luck! Tony -
Romme, whose dictionary of 1804 I mentioned in another post, has the following: RENARD, subst. masc. (Traverse board.) 1°. Instrument de pilotage. Morceau de planche coupé en rond, avec un petit manche, sur lequel on a figuré les trente-deux aires-de vent de la boussole, le Nord étant désigné par une fleur de lys, &c. Sur chaque rumb, sont percés huit petits trous, pour représenter les huit demi-heures que durent chaque quart. A chaque demi-heure, mesurée par l'ampoulette, ou horloge de sable, le timonnier met une cheville dans l'un des trous qui sont percés sur le rumb où il a gouverné : le premier trou, vers le centre de la planche, sert pour la première demi-heure ; celui d'après, pour la seconde demi-heure, & ainsi de suite. Ce renard, ainsi marqué de huit chevilles à la fin de chaque quart , sert à l'officier de quart à écrire sur le journal la route que le vaisseau a faite ; & ensuite tous y prennent les renseignemens nécessaires pour calculer cette route, ou faire leur point, ayant égard à la dérive, à la variation de la boussole, & autres circonstances. Cette pratique est sur-tout fort utile par des vents mous & variables, & contraires à la droite route du vaisseau, pendant lesquels on change souvent de direction, & on cherche continuellement à se rapprocher de son véritable chemin , à mesure que le vent le permet; & aussi lorsqu'on louvoie à petites bordées. Voy. la Fig. 340, Planche XVI. 2°. RENARD. (A dog , or cant-hook.) Croc de fer qu'on enfonce dans le bout d'une pièce de bois, pour aider à la tirer & traîner sur terre , pour la transporter d'un lieu à l'autre, par le moyen d'un cordage frappé sur ce renard. Voyez x , Fig. 3 19 , Planche XV. Tony
I love my FET. I have had it for 9 years and it's still going strong. It is very much used by other European modellers too, including the prize winners and the most accomplished, and you'll regularly see superb builds on this site where the FET has been used. You can get lots of blades for it, especially if you buy the MicroMark saw blade adapter (item #83515) for the size of the bush. And the accuracy is very high once you have learned all the quirks of its main parts which are best done in a sequence. I can easily get mine to a tolerance of 0.1mm. Of course, that alone doesn't make you a great modeller, and I am still learning. But it won't be because the saw doesn't work properly. Proxxon's backup service is also great. Tony
Thanks everyone for the hazardous guesswork. You'll note that the tille (hatchet) , couteau (knife) and hausard are all linked by a bracket saying they belong to the barrelmaker. This makes it look very much like the hausard is a tool, rather than a report. Keep the ideas coming! Tony FUTAILLES ET USTENCILES DE TONNELIER.pdf
