Everything posted by Trussben
So very busy life has me out of the workshop at the moment, but I did receive the figurehead carving I commisioned from David Antscherl yesterday - As with any of his work it is simply outstanding to say the least. Thank you David for accepting the commision. ben
- 889 replies
Gaetan So you had issues with the dye bleeding into other areas, I was thinking of using fiebigs dye when the time comes, but you have made me think now. Ben
- 728 replies
- le fleuron
- 64 gun
Sweet Chris, post some more pics when you get that workshop setup. Ben
- 290 replies
- confederacy
- frigate
Thanks Rusty, Mark and Grant for looking in. Ben
- 889 replies
- 889 replies
Here are all 5 pieces of the keelson scarphed together and installed. They were also bolted down through every floor timber with 1 1/4" "bamboo" bolts. Now the Stemson needs to be made. Ben
- 889 replies
- 889 replies
Thanks for all the likes. Patterns for the remaining framing have been made to help with this area, they had to be juxtaposed in ACAD as the DOF plan is from Cygnet and doesn't exactly match the Pegasus plan or the TFFM Mylar.
- 889 replies
And here are both counter timbers installed and reinforced with a cross spall. I will now start building the framing from the DOF plan to fill in the sides. Ben
- 889 replies
Thanks Greg, I'm thinking of glueing in a couple of temporary spalls across them for a little bit of security. Ben
- 889 replies
Thanks Druxey, I haven't sanded the bevel into the aft outside of the timbers, I thought I'd wait until all of the counter timbers were installed before I do that to make sure they all fair together. Ben
- 889 replies
The side counter timbers are being installed in the next picture, the wooden square you see was made to be exactly 12"3' wide and the same height as the toptimber height from the plan, this was then taped down to the build board exactly 5"3' back from the aft perpendicular as per TFFM. I am hoping that doing it this way will ensure the these counter timbers are in the exact right place. Ben
- 889 replies
Good Grief, even using 80 grit paper and course blocks this really is taking some time. I'm am going to go to a final grit of 220 below the Wales which won't be planked but I'm thinking of leaving the framing at the Wales and above at 150 grit so the glue to hold the planking on will have a bit of a tooth to grip to - anybody else do this?? Ben
- 889 replies
I'm sure your stove will turn out superb. Ben
- 1,449 replies
That's a beautiful figurehead Danny, Janos did you proud. I think I will be getting a commission done for my Pegasus figurehead as I'm not a carver either. Ben
