Trussben
Everything posted by Trussben
  1. I decided to double check my DOF drawing against the Mylar plan for the next set of frames, everything lines up well except the aftmost timberhead and the top of the rail line is slightly higher on the Mylar. Im also cross checking on the actual NMM Pegasus side draft. Ben
  2. Hey Greg, Yeh, the more I think about druxeys idea the more I like it, if only one side of the filler is glued then it allows for some movement, and if a gap appears it could be filled with a very thin sliver of wood maybe. I'm still going to leave a full frame gap every 8 frames as well just in case. Ben
  3. Thanks David, Everything that could be saved from the old hull is on now, everything to fill the gap has to be made new going forward. I really don't want to take the chance of using parts of the framing that were subjected to the warping that I encountered. Ben
  4. So here is the last remaining saved section from the old hull installed along with a frame fore and aft which have no floor fillers. Ben
  5. That's another idea David, I guess there are a few ways to skin this cat, I'm just gonna try this way and hope to hell it works as I cannot see myself recovering if it goes bad on me again! Ben
  6. So a small piece of rising wood has been added before the aft section for frame 10 fore to be mounted to, then the next surviving section of 8 frames will be installed. Now I'm thinking of leaving the floor fillers around 10 fore out, this will give room for the wood to move and hopefully help avoid the issues I had on the original build. I shall repeat this every 8 frames so it will look consistent and it works out to be the correct amount for the amount frames left to complete the framing. Ben
  7. Thanks Albert and AP, I will reveal how I'm going to continue this build tomorrow after all the saved sections from the old ship are installed. Ben
  8. Old forward section has been installed and reinforced with copper wire and epoxy the same as the aft section. Ben
  9. Thanks for all the likes. Old stern section has been installed, and reinforced with 18ga copper wire epoxied through into the keel. Next up will be installing the old stem section in the same fashion. Ben
  10. So before attaching the original stern section onto the new keel I made and installed the filler pieces under the transoms, three on each side had to be made. This was completed and checked for symmetry on both sides, tricky little pieces. Ben
  11. Thanks Mark, The reason for no sawdust in view is that I now have proper dust collection systems, a dust devil and big shop vac to connect to the tools and a big Jet ceiling mounted air filter for the fine stuff, there has been some dust produced - trust me! Ben
  12. Awesome build Albert. Ben
  13. Thanks David. So the new framing squares and overhead gantry are completed. Next job will be to do some work on the old stern section before mounting it to the new keel. Ben
  14. So some new frame squares are in the process of being made so as to be able to utilize the t-tracks for securing them in position, Also new fore/aft holders were constructed out of Poplar just like the squares. While doing these small jobs the build board layout drawings were split into 3 using autocad so as be able to be printed on regular printer paper, great pains were made for accuracy and alignment of these. Now I'm making the overhead gantry which I hope to have done in the next few days. Happy Holidays to all on MSW. Ben
  15. Thanks Druxey, Funny but I got up to a drill bit equivalent to 4" at scale and it started to cut a little noisy with some vibration with the angle and wood grain, so I decided to quit there and will finish with pin taper reamers by hand, I really don't want to tear out the timbers and have to remake them!! Ben
  16. Hey Greg, Yep, it's a 2000 DRO 8 axis. Learning it as I go. Ben
  17. Thanks for the likes. Fun was had today setting up the mill and drilling the hawse holes at the correct 10 degree angle as measured off the plans. They were only drilled out to 4" at the moment, the rest of the way will be done with a tapered reamer, but this has given the correct position and angle of the holes.
  18. New Keel is being drilled for its bolts on the Sherline mill using the sensitive drill attachment. Gives nice accurate placement. 7/8" Bolts will be simulated using 24ga copper wire that will be blackened later with LOS. Ben
  19. So on vacation for a few weeks and hope to get some good progress on Pegasus, wishing all on MSW happy holidays. Ben
  20. Very nice work on your Confed so far, I will enjoy watching your progress. Ben
