Posts posted by Overworked724
1 hour ago, WalrusGuy said:
I think I just got lucky with it. I remember when using the smallest drill bit I almost messed up and had to try drilling a new pathway with a bigger bit. I also remember it was very tricky and scary 😬
RIght!??? I mean...come ON! New modelers need to have some idea of next steps after all the hull and deck planking, painting, etc. Suddenly....here...stop what you’re doing and drill four HUGE holes in the bow of your ship. Oh...and be symmetrical and don’t screw up. Enjoy your hobby. Peace out! ✌️Really? 😳
When I built my Sultana it was a smaller model and easier to gauge. The Syren is bigger...
Nope...I’ll leave my note for posterity. I made my attempts and still screwed up...I’ll repair (hopefully soon), and move on. And here (above) is what I did...so you can learn from my mistakes.
Hawseholes should be drilled as you plank the exterior. You can SEE what you are doing. If I knew then what I knew now...as soon as I laid down the wales, I’d drill the exterior holes. Once I laid down the interior bulkhead planks (lower layers at the deck level) I’d take into account the height of the deck/waterways and mark/drill the guide holes for the hawseholes on the interior side.
Done.
(I know...painting/etc. later can make predrilled holes difficult to work around. So what?...Tape/etc. deal with it. Better than drilling blind after you’ve done all the detail work on your stem!).
- Keithbrad80 and WalrusGuy
- 2
1 minute ago, Justin P. said:
Agreed, thanks for sharing. This is also another future step that's been occupying my thoughts. And its true, they do just magically appear! I was thinking so far to do the same, start small and work up... Are you planning to line them?
Nope. Following the practicum. Will paint and include the wood veneer once I start building out the stem. -
16 minutes ago, WalrusGuy said:
Yeaup those will be hidden, but I am sure it must have been very annoying and frustrating!!! In my log I went into a bit of details where I drilled pilot holes (very small diameter) on the inside and outside parts of the ship, until they met. Then increased the diameter slowly after
I read your log. LOL. Actually, those little oopsies WERE my guideholes. 😞Im not very good at measuring apparently.
Yeah...hawseholes. They suck. Most of the builds, and the practicum, really don’t go into any detail. The holes just magically appear somewhere in the pics.
Well...I call BS. This part was what I was dreading. The idea of getting the knees and detail work in on the stem and realize I need to open up four huuuuuge holes in the bulkheads at the deck level...hoping I can do a decent job of it...ugh.
I marked the holes for the anchor cables on the interior side and opened the guide holes...calculating my angle of attack at 15degrees based upon my rough measurement. The problem was the exit holes...
Ok. So I got them in...but I got the angles wrong on BOTH sides. &$@!?!! I under and over compensated the angle on both sides. I like symmetry...at least I screwed up once on each side! 🤣
In the end, these two oopsies are easily masked by the knees. Which is why I wanted to open these holes up now....
And I can patch them easy enough once I’ve opened up the holes, painted, etc.
Moving on..
- Keithbrad80, abelson and JpR62
- 3
I couldn’t help myself. Decided to see the afterglow of all that work after a coat of natural stain.
You can see I stayed with one trunnel at the butt joints and on the adjacent boards. Frankly, I could have easily done 2 per board but think it would simply have been overkill.
I’m not unhappy with my efforts! Not bad for the slowest Syren build in town.
Moving on....
- schooner, Keithbrad80, abelson and 1 other
- 4
I broke up the waterways into three parts. Stern, midships and bow. I put the butt joints where the sections meet directly beneath the gun ports so they’ll be hidden by the carronade sled swivel brackets. The bow section of the waterways needed some shaping and a slight twist to get it to fit comfortably. I didn’t go all the way to the stem since I plan to put in a wooden hawshole guide (he said to himself hopefully).
One bonus is that my measurements were good this time...the carronade swivel brackets all fit (although some by only a hair) as they should and the waterways do not impinge on their alignment level with the gunport sills! 👍🏽
Will save my staining the deck for tomorrow as a nice ‘attaboy’ gift.
Pics below...
Moving on...
@CPDDET @Keithbrad80 @WalrusGuy Thanks, guys! Much appreciated! It’s not ‘perfect’ and as you can see the hypotenuse (facing edge) is not perfectly edge to edge as there is still some bevel left after sanding...but it’s the closest I could come.
The jig only took like 5 min to make. 😎
And I can say it works like a charm...about 5 min to make one 24” triangular strip. 👍🏽
Waterways...was a bugbear for me on the Sultana since I couldn’t figure out how to make them. Well, I’ve seen a couple folks show their method (kind of)...and frankly, I didn’t want to over think this on the Syren this time. So here is my method...and it works for me, and very very simple.
The waterway strips are 1/16” square. I cut about 6 of them (24” long) from boxwood so I would have spares...and just for giggles.
I made a simple jig using some 1/8” copper rods (6” long sections) ... but 1/8” wooden dowels would work just fine, too. Then I used some CA gel to attach them to a support base (1/8” basswood scrap about 8” x 2”). Then I bordered both sides of the copper rods with 1/8” square basswood dowels...since sanding will stress the glue joint and I wasn’t sure how much I could trust a metal-wood CA joint.
Here is the jig...
Here is the jig with a square dowel sitting in the seam between the two rods...
And then I simply used a 180gr emery board to shave off the exposed 1/2 of the square dowel.
The dowel remains tightly locked I place and the sanding is easy. You can see by eye where you need to sand more...but you can’t over sand (provided your dowel is close to square).
Ok...that’s how I’m making my waterways sections...which is like 90% of the challenge...trying to make a good triangular section can be a real head scratcher.
Moving on...
14 minutes ago, desalgu said:
I'll look into doing a build log of my version of Syren.
I think you'll find that having your own 'center for your build' will be invaluable. I find myself going back through my build looking at the input of those modelers who 'follow' my build and offer advice when I have questions. It's like a treasure trove. Also, it has the advantage of keeping all the feedback in one place which you 'own', rather than have the feedback spread through a number of build logs.
Really looking forward to seeing your build log. Lots of folks here building the same ship really gives you some wonderful team feedback!!
- 2
51 minutes ago, Red Rhino said:
Patrick: Your Syren is looking superb! You mentioned you got some new LED spots for you workshop. What style or brand did you get? I need to improve my lighting as well.
Dave
Got 4 of them put in the ceiling attached to a dimmer switch. My shipyard literally shines like the sun now...these were installed by a friend who is an electrician. Great lights. 3 different light quality selections!
I’m seriously thinking of getting the hawseholes drilled before setting in the waterways. Doing it after working on deck fittings and stem details seems like it would create a bit too much pressure for me. So I’ll plan for them after I’ve trimmed and sanded the deck trunnels.
- Keithbrad80 and Justin P.
- 2
- Keithbrad80, Gahm, WalrusGuy and 5 others
- 8
Sweeeeet...
Make? Manufacturer?
My extremely slow motion build continues! I've learned a lot about wood, using a table saw, margin planks, nibbing/joggling, and beer - since I started this portion of the build on New Year's Day.
Wood: I had originally cut Castello boxwood planks for the deck (and had made the faux deck from this) as it was clean and uniform. However, a buddy had offered to sell me some old boxwood he had in stock. He had some aged English boxwood which had been sitting in his basement for 16 years and I could not help but mill it and use it for the deck. It has some figuring, but the warm yellowish tinge is beautiful. The problem was that I failed to consider the fact I had no way to mill pieces wider than 1/8" (which I found I needed when planking near the bulkheads). So I ended up having to use the same Castello boxwood I used for the margin planks for these last couple of planks near the bulkhead...no biggy, but it does stick out to my eye. I hope when I stain/tung oil that the different woods don't contrast too harshly.
Margin plank: The symmetry and alignment of the margin plank in relation to the center line is critical to ensuring the joggling pattern is symmetrical (aligned bow to stern) as you joggle/nib port and starboard. Mine was not...whether this is due to asymmetry in the bulkheads between each side, or whether the margin was slightly thicker on one side vs. the other...the fact was I could see after I completed my third joggle that the two sides were started to drift...had I continued, the joggling would not have been even (aligned) between the two sides and it would have driven me crazy. The pic above shows the disparity between the two sides - the last plank at the bulkheads was 4mm thick on starboard, and 5.5m on the port side...so you can imagine the joggle 'creep' as the joggling progressed down the margin plank. My solution was a (nautically inaccurate) compromise...I simply stopped after 3 joggles on both sides and shaped the remaining planks to fit against the margin plank - which is not easy. It's funny - I started this part of the build terrified of cutting the margin and messing up - and the procedure I described in the earlier post really gave me confidence...good procedures instill a sure hand - but in the end, I found my joggling curtailed by my lack of symmetry of my margin...live and learn. The same reasons I stopped joggling the bow were why I avoided joggling the stern portion of the margin. Pic below...
I still have sanding and trunneling to do before I can put on a layer of tung oil...and that will take some time. Here are the remaining pics of the deck, such as it is - unfinished, but not a bad result.
So now I have some considerations. The waterway is easy - but I think I might want to drill in the haws holes for the anchor cables before I do that...but I have not seen any real good descriptions on how those are done - even in the practicum. I've looked on other ship blogs but no one really goes in detail. If I can't find a reference - I'm problem solving again. Waterways themselves are easy - and I already have the boxwood strips ready for install - but I want to make sure I don't make things hard on myself later....
While I'm doing work on the trunnels/sanding the deck, I will start banging out my copper plates and thinking about how to attack my pintles and gudgeons. I might also start finishing up the basic work on the carronade sleds to get them ready.
So...that's my update! Moving on.....
- WalrusGuy, Keithbrad80, Gahm and 6 others
- 9
Well...my deck planking will be done this weekend. Thank GOD!!! Work and family stuff really got in the way these past couple months...and work is stressing me out so bad I’m taking muscle relaxants prescribed by my doc! 😴. But these days, every day is something new, but yesterday my shipyard had 4 new LED spots installed! Oooooh...yeeeeah!!! Light!!! 😎
Pics of my imperfect yet completed deck planking to come.
- CPDDET, Justin P. and Keithbrad80
- 3
1 hour ago, Justin P. said:
Very clean! I wish mine came out like that. Seems like no matter how hard I try I can never get my cuts or joins that clean! You've got it!
Wish I could say I did....stopped after 3 joggles. But I get the process and the limitations in setting the margin unevenly...bad medicine! LOL
Thought I’d post the obvious thing. Nibbing and joggling is actually pretty fun if you have a good method. But the two sides are only as good as the symmetrical alignment of your margin plank. Which is why I decided to stop after 3 joggles. I knew I couldn’t keep the port and starboard sides evenly aligned as I proceeded down the margin plank. Next time I do this I won’t be so nervous...but I will take additional care in laying down the margin.
But...it’s not to say I didn’t learn something. I got a good reference from a shipmate...so here’s how I attacked the whole process.
1. Made a stencil using 2 planks. Trimmed down one edge to a needle point and glued them together. This allows to slide one edge as close as possible to the edge of the margin to be cut. Made one for port and one for starboard.
2. Make but don’t glue the two planks adjacent to the joggle to be cut. It will ensure when you cut your joggle you won’t end up bruising/cutting the adjacent plank. Slide the template up against the unglued plank until it meets the edge of the margin. The proud side of the template will slide over the margin Where it meets and will form a squared edge. Trace the top and side of the edge with a sharp pencil.
3. Remove the stencil and the unglued adjacent planks. Then mark the exact center of the top line. This is the 1/2 plank width.
4. Using a square Exacto chisel blade, slowly cut from the 1/2 plank mark to the bottom edge of the stencil mark. After the cut, simply use a fine eraser to remove the pencil lines.
5. Cut/sand the top end of the plank (nibbing) to fit the joggled cut.
So...it’s a bit easier than I’d thought. But my margin plank kind of screwed me. If I were retired and could spend more time, I’d have gone back and repeated the margin..but as I want to build my ship (it’s my release) I’m not really looking for perfection. I can keep the lesson learned in a box in my head and can use this for my next build.
Moving on...slowly.
Love mine. I’d be lost without it.
9 hours ago, Redshadowrider said:
You ship is looking great and I am wishing mine could be as clean looking.
Your build is looking fantastic! I find myself sometimes comparing my work to other builders whose work I could only dream of...it doesn’t stop me from loving this hobby or the modelers on this site! Everyone is so supportive and the feedback always positive and constructive. It’s the community of builders who will always help you progress...and put wind in your sails with a kind word! 👍🏽 I think you are doing great.
US Brig Syren 1803 by Overworked724 – Model Shipways – Scale 1:64
I was using a block as a drilling guide with a hole set at a specific angle.
Correction...3 blocks! 2 were wrong angle. 😳
