Everything posted by Baker
Welcome to MSW. Greetings Patrick
I'm glad I could help you. greetings Patrick
- 740 replies
- Tudor
- restoration
(and 4 more)
Welcome to MSW and good luck with your build. Patrick,
Short update, The rudder is cut loose from the hull and the bolts are placed. Now can be started with the further finishing of the hull
ps I also use google translate
hello Steven, If I see it correctly on the photo. I think your first frame on the upper right side is not in line with the rest.
- 740 replies
- Tudor
- restoration
(and 4 more)
New member from Maastricht, The Netherlands!
Baker replied to Anna's topic in New member Introductions
En groetjes uit Belgie. -
Danny, Tracks on a scalemodel can always be a bit too long or too short (Unfortunately, I have already experienced this a lot...) Do not glue the tracks before you are sure that the length is correct. I would first place the front and last wheel (bottom rollers) then you see if the tracks have the correct length. The track tension is controlled with the idler wheel. Nice work.
Thank you, In the meantime, a cautious start has been made with the fitting of bolts. These must be carefully sanded later And an attempt to imitate the "nails and planks" "bolts and nails" are made of stretched spreu
And good luck with your first wooden ship
Nice work! The bee wax and brass wire are great ideas
- 236 replies
- artesania latina
- kitbashing
Groeten uit Belgie
update Both hull halves are glued together with the deck. All molded on details on the inside are first sanded away. The round cannon ports are made square and all holes in the hull that are not needed are closed. The outside of the hull is now being cleaned up. Thanks for following
Welcome to MSW and greetings from Belgium
Welcome on the build of Revell's Bounty scale 1/110 I got this kit for free from friends who cleaned up their attic. My first idea when I opened the box. Was oops .... On closer examination, it turned out that the model design probably dates from 1956. The mold is from 1978. Therefore the "lesser quality" of the details to current standards. First, i wanted to throw everything away. But it had some trouble with this idea. So why not start on it and try to add some extra details. This will not be an exact copy. My biggest challenge to make this model a bit nicer than what can be made with the contents of the kit. I am not going to buy extra parts, only items and plastic sheet from the parts box will be used. My only experience with plastic ship models dates from my younger years. I have only experience with military models in scale 1/72 So we shall what the future brings. Main goals are : making of a good model and have fun. Info about the ship and voyage https://en.wikipedia.org/wiki/HMS_Bounty Royal museum Greenwich https://prints.rmg.co.uk/search?q=bounty&type=product Info about the Revell model https://www.revell.de/en/products/modelmaking/ships/sailings-ships/h-m-s-bounty.html the deck is equipped with molded on details. Removing all this and making them new is impossible. That's why I make a new deck first Engrave the deckplanks on plastic sheet Add hatches and "grating" (This grating may be replaced later by something else) Opening for a ladder. I dont throw plastic leftover parts away .... A first test to see if the deck fits. and... it fits With 2 Bradley's in the background to be continued, thanks for following.
