Baker
Everything posted by Baker
  1. Next step;, mark where the waterline comes As previewed earlier, the depth is approximately half the width First i clamp the hull and level it. Middle deck and aft deck are ok The for deck is a little bit not ok I made a tool to draw the waterline. Where old lego can be used for. For a few moments I felt 50 years younger.... Apply masking tape. And we are ready for painting.
  2. It looks like your red frame is mounted too high Glue a strip of wood round the frame I once had a frame that was too low at the top
  3. EJ, Best carver or not the best carver. It looks very good to me. Well done
  4. Great start Hartmut, I'm happy to see another scratch build Golden Hind on this forum. The book "Risse von Schiffen des 16. und 17. Jahrhunderts" is indeed very helpful to build this ship. I will follow your build Michel looks like a friendly guard
  5. welcome, In the Netherlands they already have experience with this Google search : drijvende huizen nederland https://www.google.de/search?q=drijvende+huizen+nederland&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwj13bzkq_DYAhVFSq0KHUpmCKQQsAQIOA&biw=1153&bih=483
  6. Hello, All the treenails have finally been done. There are about 4300 treenails in the hull. Earned I think I'm first going to put a color on a part of the hull now (red brown and white) thanks for following Index : see post 1
  7. And greetings from Belgium
  8. Well done ( the boat, and your building log) I'm looking forward to the further posts
  9. All treenails are done on one side of the model. I have tried to follow the structure of the futtocks and filling frames as much as possible Source the Gresham shipwreck Sanded and wiped off with a wet cloth (Still about 1000 treenails to do) I have also done a first test for a brown and whit color on the hull Greetings Index see post 1
  10. Amati has 22mm figures also I ordered 35 mm figures and some other parts at cornwallmodelboats last month and they have been already delivered to me. http://www.cornwallmodelboats.co.uk/acatalog/amati_crew.html
  11. Well done Jeff But my opinion about replicas of the Golden Hind : beware of them. There is very little known about ships from this time.
  12. Greetings from Belgium
  13. Hallo Bontie The best advise i can give you is to read these articles first before you start planking. I did thid too first, they are very helpfull. And yes, Your log is better in the forum for ship model kits. You will find more help there http://modelshipworldforum.com/ship-model-framing-and-planking-articles.php
  14. Nice work EJ And i hope you get better soon. Greetings
  15. This post is double (error from me) If a moderator reads this, this post may be deleleted. I am worried about deleting too much myself and erasing the entire building log Thanks Michael and Steven. In the meantime, I decided to apply trenails to the entire hull. Knowing myself : If I do not do this, then I will regret it later.
  16. Thanks Michael and Steven. In the meantime, I decided to apply trenails to the entire hull. Knowing myself : If I do not do this, then I will regret it later.
  17. Good luck with your build. Swedish breakfast, with herring, is indeed very tasty.
  18. Thanks Zappto, I use ramin for the hull. This was a leftover of wood from when we built our house 25 years ago. I do not think that this quality of ramin is still available. What is now sold as ramin is much softer wood. Al the other wood is cherry.
  19. Welcome from Belgium
  20. Greetings from Belgium
  21. Planking the front side of the for castle. Everything went according to plan. Until I discovered a mistake. How could I miss something as stupid as this? On one side I'm 3 mm (slightly less than 1 / 8th inch) out of center. Fortunately, the adhesive was not completely cured. So, cutting with a Stanley knife and breaking apart was still posible. Sawing the frame so that it can bend. gluing and clamping Back to planking again and treenailing. Ready Thanks for following
  22. Greetings, and welcome back
  23. The stempost is also reconstructed. To be honest... The first attempt was not really a success and did not survive the construction process of the hull. He was broken off and is now made new again. After sanding and put into the right shape (planking of the forcastle is started). Thanks for following
