Everything posted by Baker
And greetings from Belgium
I'll tree nail the deck with 0,5 mm walnut (the planks are 4 mm wide). right decision (in my opinion) Robin, Are you really sure about this grating??
- 91 replies
- kolderstok
- duyfken
Billings 50ft. HMS Renown Steam Pinnace - Need some help
Baker replied to grsjax's topic in Wood ship model kits
This is all I can find beautiful pictures : http://sudwall.superforum.fr/t1520-identification-d-un-canon http://www.fortiffsere.fr/artillerie/index_fichiers/Page2775.htm http://asmrb.pbworks.com/w/page/115688596/3 pdr QF Hotchkiss Gun here you maybe will find some dimensions http://atf40.forumculture.net/t2701-canons-de-47-ex-marine a 3D model https://nl.3dexport.com/3dmodel-47-mm-hotchkiss-naval-gun-124509.htm -
Looks to be a "Hotchkiss 47mm L/40 M1885" or a QF 3 pounder. Until now, I have not found a plan yet (maybe later) https://en.wikipedia.org/wiki/QF_3-pounder_Hotchkiss -
Nice work Robin. The untreated walnut is very realistic. And, after treatment with oil or varnish it becomes indeed a red / dark brown color. Most finds of remains of ships from this period have rectangular gun ports. Reason : The greater the height of the gun port, the higher the elevation angle that the cannon can have.
- 91 replies
- kolderstok
- duyfken
Welcome back. And greetings from Belgium.
And good luck with the build. Greetings from Belgium
Thanks Steven, Robin and GL Robin, I first made a test board / plank. My treenails are actually 0.2mm too large in diameter (1mm while they should be 0.8mm). At the test, 1 mm looked good. And a 1mm drill is stronger and breaks less quickly. Therefore, 1 mm treenails are used. I also discovered that the treenails are almost invisible under 2 layers of white paint (below the water line). Perhaps I also provide treenails here , or maybe not. Applying about extra 1500 almost invisible tree nails ??? pfff...
- 756 replies
- galleon
- golden hind
Small update The treenailing "adventure" continues. I also discovered that the wales were not blackened in the time prtiod that this ship was sailing. The whole idea of painting the wales black was partly based on a translation error from me ( my knowledge of the English language is apparently less than I thought). I also found, somewhere on this forum, a topic that confirmed this. On one side, most of the black is already removed. Treenails and bolts need to be added to the wales.
- 756 replies
- galleon
- golden hind
Robin, Some builders paint the edge of the plywood frames black. Before applying the fillerblocks. This way you can see better how far you can sand. As long as black paint remains visible on the widest part of the frame its ok. Dutch, Schilder de zijkanten van je spant zwart vooraleer je de balsa blokken aanbrengt. Als je daarna begint te schuren moet er nog zwart overblijven op het breedste deel van je spant. Altijd juist, en nooit te veel afgeschuurd.
- 91 replies
- kolderstok
- duyfken
Great start Robin Balsa next...lots of saw and sanding dust I spose. When I have to make a lot of dust whit sanding, the admiral sends me out into the garden There i can make dust as much as I want
- 91 replies
- kolderstok
- duyfken
Robin, As promised, I will follow, If I can help, just ask. The first interesting link :
- 91 replies
- kolderstok
- duyfken
I searched in google for : "kriegsmarine rettungsfloß farbe" And found this : http://www.forum-marinearchiv.de/smf/index.php?topic=5660.0 They speak about 2 colors Start WW2 : auf einigen Farbfotos zu erkennen, ein fahles Gelb fahles gelb = dirty yellow In 1941 : Schlauchboote waren Taubengrau Taubengrau = pigeon gray Hopefully, this will answer your question
" boring" : Has indeed complete different meanings in Dutch and English. "Boren" in Dutch : Drilling a hole in something Example : Drill a hole in a plank or a wall, drilling a tunnel "Boring" in Dutch : There is already a hole in something. Example : The diameter of a cylinder in an internal combustion engine "Boring" from English to Dutch = vervelend, saai Like : annoying, something you have to do but do not like doing it. Help the admiral with the dishes (therefore she has a dishwasher )
- 756 replies
- galleon
- golden hind
Christian, Thanks. At 1/64 scale the treenails will indeed be small and almost invisible.
- 756 replies
- galleon
- golden hind
Robin, Congratulations with your finished model. Very, very, very beautiful. Well done.
- 473 replies
- greek bireme
- dusek
Steven, Great to see that this problem has been solved. Ps, I work in a chemical factory. And Iso Propyl Alcohol and Ethanol are 2 complete different solvents for us.
Patience and time. And if the first attempt fails. keep on trying again. That helps me
And thanks to google translate Without that, I was not here either
