Everything posted by RGL
The third deck was from Pontos, the first two were Artwox. Maybe it was just a bad batch.
- 75 replies
- scharnhorst
- dragon
Bugger, you could be right. Damn those old photos, I have some from the bridge which don't show it either, but it could be a question of contrast and being below he chain itself, it's an easy fix now I think about it though. I will make a few attempts at rectifying it, but if it looks crap I'll probably omit it.
- 342 replies
- dreadnought
- zvezda
Getting there. Next, the Anchors. The original photo shows no running plates for the anchor chain, but the instructions do. So I didn't do it. The Kit provides a basic bit of blurry plastic, Pontos provides some blackened chain and befitting my OCD I went with North Star, using their patterned chain as is correct, a little bit out of scale, 2 days of pain. Seriously, my forearms and hands feel like a really good session on the heavy bag. At least one complete line is somewhere in my study of individual pieces flying around. I eventually figured out a technique using jewelers pliers, tweezers and back crams that worked, allowing me to close the loops so the thing does not fall to bits. . Next, the Capstans, just plonked on, fit and look OK. Then the anchors again after market (the kit ones are rubbish) joined with a proper metal loop. Next, threaded in and attached to the deck. I had earlier drilled out the holes. I am leaving one sitting at length as it makes sense to have it on the sea floor given there nets will be out. Next the stoppers; Finally, the dandyfunk of vents, hawser covers, brakes and extra equipment boxes. Finally I'm at that impasse where I have to do the turrets and big guns that will go under the rigging and inside the rails.
- 342 replies
- dreadnought
- zvezda
I've completed 2 kits to date with no issues, my third's wooden deck did not like me at all.
- 75 replies
- scharnhorst
- dragon
Have a look at my Varyag, it will show you what can be done with Zvezda. My Emden shows you what kind of work is needed on the early stuff!
- 342 replies
- dreadnought
- zvezda
The trickiest thing so far, the davits, with the canvas straps replaced, rigging attached and the smaller whalers.
- 342 replies
- dreadnought
- zvezda
It lifts fine with a blade (the deck that is). If it pops up use some CA on an off cut of photo etch and slide it in the gap then press down. The really liquid stuff works best.
- 75 replies
- scharnhorst
- dragon
- 342 replies
- dreadnought
- zvezda
Thanks, small boats finished, just have to finish the Davits besides the bridge, half of them will be slung outboard on removable Davits as that's where they sit 'in harbour' not against the superstructure, and as I'm doing the torpedo nets they'll have to be done that way. Next will be making up chain for the anchors.
- 342 replies
- dreadnought
- zvezda
I tried, it looked horrible. It wasn't hard just 2 days work, I always do extras just in case of the carpet monster or random acts of my stupidity. Plonk them on masking tape, glue down one end, then start wrapping.
- 342 replies
- dreadnought
- zvezda
Now, there are a LOT of ships boats. The kit provides some aftermarket and I've added a bit more just to be silly. The row boats need to be hollowed out and some grates and planks added, And finally the davits. The loop shown is supposed to be canvas strap which I'll remove and rig properly (to a point). I am in the process of painting these now.
- 342 replies
- dreadnought
- zvezda
I have added small vents to where the AOTS references them, the rear compass stand, two aftermarket winches (instead of the blobs provided), the coaling booms, affixed the main mast.. A big problem is that a LOT of the deck glue is going, requiring the application of glue to affix it properly. . I have now added all the hatch covers bar one which is going to be sanded right back and re done due to a fail on my behalf, plus I added the breakwaters. Photos of those later once I have done up the ships boats.
- 342 replies
- dreadnought
- zvezda
I've done a heap of very small piecework for all the deck fittings. As you can see there is a lot of prep work to do first. It was two days work just to do the cable drums and add rope to them.
- 342 replies
- dreadnought
- zvezda
It's amazing how much detail and effort goes into etch, and then they throw a few non intuitive photos. I think they assume everyone is a master modeller.
- 75 replies
- scharnhorst
- dragon
Considering all the barrels you have to make, you're in for a world of pain! This is just a whole new world of art, I get frustrated waiting for CA to dry. Does it require paint at all?
- 244 replies
- borodino
- dom bumagi
Thank you all. Lots of piecework to go now, ships boats, ladders, deck fittings, anchors etc. once that is done I'll post again. Then the plan the guns, then rails, large aerials, than finally the fully rigged torpedo nets.
- 342 replies
- dreadnought
- zvezda
Bit like eating an elephant, 1 bite at a time
- 75 replies
- scharnhorst
- dragon
The finalization of the fore mast. Went togeather with great fanfare until some idiot put the mast on backwards, the had to pull it apart and start again. Then the standing rigging. The i added all the back stays, 2 days work as the lines are sooo fine. The of course, that bloke Murphy caught up. The glue on the crows nest gave way. So, as the thing is fully rigged with elastic under tension, I had to hold it in the correct plane and then make sure the yards are parallel to the deck both laterally and horizontally with one hand and glue with the other. Pain in the backside. Then I thought i'd got away with it and the middle yard snapped it's brace to the mast. As above a pain in the butt but using a set of helping hands it was remedied. Finally, the rigging of the mast is complete. It is not as strait as I'd like but I will add stays later.
- 342 replies
- dreadnought
- zvezda
Pretty much, very hard to scratch build the very fine details, unless your eyesight is poor then it doesn't matter.
- 342 replies
- dreadnought
- zvezda
No, none at all on the Pontos fret, they are North Star, and using eyelets for the signal halyards. I'm using the rigging from the Alliance model works as the mast ladders. I'm currently in the process of adding the fixtures to the foremast, including foot ropes from fly hawk. Once added I can rig then paint up the brass by hand as it will block up the holes if I do it before.
- 342 replies
- dreadnought
- zvezda
Man flu aside, I managed to get the main mast finished. I added tiny turnbuckles to allow the stays. Then just a matter of rigging it up and adding the coaling derricks which I rigged up as well. . I also added a small ladder up to the wireless telegraph yard. Then dry fit on the deck. I don't need to glue it down yet but it fits perfectly.
- 342 replies
- dreadnought
- zvezda
Yes mate, hopefully the hot chocolate will allow your bride to think that we're not all strange like my wife thinks. She did not believe we didn't talk about "boat building".
- 342 replies
- dreadnought
- zvezda
