Posts posted by Koppalakki
28 minutes ago, Old Collingwood said:
Any hand painting tips would also be very greatfully appreciated.
OC.
Don't really have any tips for that tbh. I usually only paint decks, I use Life color acrylics for that most of the time and just dip in the can brush on!
Well once you got the quality you like it's hard to go back. I've built one model out of box in 5 years or so 😁
- RGL, lmagna, popeye the sailor and 4 others
- 7
I guess I can setup some tutorial on some small piece when I get the time.
The only problem is to setup the "light booth" to take the photos as I have to dismount it as I don't have space to leave it. And the fact I like to work fast when I'm in the zone so taking pauses for every step slows me down.
- RGL, Ryland Craze, Jack12477 and 6 others
- 9
No worries guys!
Well here they are and in comparison! Judge for yourself, I myself am pretty satisfied with the end results.
I did add some mix and smash to the Infini set. The launcher base isn't provided so I added one from sheet styrene.
Also the front door face got some details cut out from the Veteran ones. I think they look a like now a bit more and should work out ok!
So here's the finished Infini one!
Veteran closed one!
Next to each other!
And in context!
The outside details are pretty on par with each set. I actually put custom PE bits to the infi launchers to get them to look more like the veteran ones. The biggest difference is the infi launchers are a bit bigger than the veteran ones. It's hard to see as it will be open so it extends even further back.
I'm replacing the 4th launcher on the aft platform (just like the reference photo) all else are closed. I doubt they had multiple launchers open while firing anyway.
Planing on using one and it's next to 3 closed veteran ones. Hence why I'm doubting!
- Canute, Old Collingwood, lmagna and 2 others
- 5
They sure do look great, but I'm a bit worried that they stick out like a sore thumb next to the veteran ones.
I try to finish it up later today so we'll see!
- mtaylor, popeye the sailor, lmagna and 3 others
- 6
So some mail arrived!
Like I mentioned, this image made me order some infini launchers!
And some madness did I get!
The infini set is just unbelievable! Though it's not for the faintest of heart! One launcher is about 100 pieces of PE and the smallest ones are tiny. More like new level of tiny I ever encountered! This will put your dexterity and mental toughness to the test. I spent about 4 hour getting everything as best as I could, there's a few bits I'm not too happy about it but the set comes with 2 launchers so if I feel too unhappy about it I can always make a another one.
I carefully mask the lines with masking tape. Starting with all the horizontal lines then after those the vertical ones. Just spray lighter shade then some overspray to tone down the effect.
- GrandpaPhil, Jack12477, pjofc4 and 13 others
- 16
- mtaylor, CDW, Old Collingwood and 14 others
- 17
I know the dry transfers are a bit iffy. The only problem I've had with them is when you need to place them on top PE plates. It always peel off down to the primer. To remedy this as possible as I can is to cut all excess material off the sheet.
On normal plastic I've not had any problems so far.
You might want to weather the draft marks aswell. They would have chipped and eaten dirt just like the hull aswell.
I usually apply them and other decals before any weathering so they will get the same treatment.
- Canute, popeye the sailor, mtaylor and 2 others
- 5
Still finishing and getting the hull ready for some paint operations.
Here's some other small stuff which I have worked on the side.
Finished the aft Mk 38 director.
Pretty straight forward using the Pontos set. Only difference is that I used individual grab handles instead of ladders.
Some attention was given to the aft tomahawk platform.
First some antiskid surfaces were masked with tape then some surfacer 1000 with a brush dappled to give some texture and bring the areas more visible.
A lot of lights were scratch build from styrene, wires and PE.
Bottom recieved some generic detailing with styrene and wires.
I really need to get started on the painting though, but I'm a bit hesitating because I know it'll take me a good 30 hours of airbrushing the damn oil canning effect.
And it's boring
- Old Collingwood, Dubz, BETAQDAVE and 9 others
- 12
- popeye the sailor, Altduck, hexnut and 6 others
- 9
Well I never really care about the colors too much. The way I paint consists of so many layers of shades that using a color match to a certain paint chip would be useless anyway. Also the scale and everything plays a factor. I just mostly make a shade of color that I find pleasing to my eye and go with that.
Not sure how many different deck gray colors were used on the Missouri in 1991 but here's a photo you can spot over 4 shades (could be just weathering effects etc.)
on different sections of the decks and turret tops. So I just look at photos and go with that!
- popeye the sailor, CDW, mtaylor and 6 others
- 9
8 hours ago, popeye the sailor said:
very nice job on the turrets........what color grays are you using?
For the light gray xf-19 lightened with white and the dark gray is a random mix of dark gray xf-24 , light gray xf-19 and blue xf-50.
- Canute, mtaylor and popeye the sailor
- 3
37 minutes ago, tigerdvr said:
The main battery is really looking good (JMHO). Great pictures too. It would be interesting to
occasionally have a ruler alongside the piece being photographed.
Cheers, Harley
Hey, I'll see what I can do with that ruler in the next set of photos!
34 minutes ago, cog said:thanks for your answer. Your weathering is hardly visible, but nevertheless realistic, more so than if done to heavily
Well, in my opinion less is better! That doesn't mean clean look, but in this scale I think being subtle is still the key even though throwing everything and the kitchen sink at it! Doing a lot of layers but keeping everything light. I can also post some comparisons vs just a gray primer on the turret so it's pretty obvious how much all those little subtle details bring it more to "life".
Though in this case the ship looked to be in pretty neat condition. It just came from a refit and it looks like the crew kept her in good condition on the final cruise.
So not much any heavy weathering will be present in the end.
USS Missouri by Koppalakki - FINISHED - Tamiya - 1/350 - PLASTIC - 1991 configuration with Pontos detail set
Ok here's a bit more indepth into painting. Just a disclaimer, some of the shading and weathering are a bit hard to see in the photos as my mobiles camera and my lighting has trouble capturing it all. For naked eye it's way more visible. It is subtle though.
So primed with mr surfacer 1200 thinned down with leveling thinner and a few drops of mr retarder.
Then Tamiya black sprayed. All paints thinned with leveling thinner to about 30/70 paint to thinner ratio. Also low pressure used.
I use an Iwata custom micron CM-B for my airbrushing.
Next Tamiya XF-19 grey sprayed.
After this some overspray to tone it down.
I don't take breaks at these steps normally, just trying to show it a bit clearer.
Then some more white is added to the mix.
Once again overspray to tone it down.
Next I used lifecolors dark gray to paint the base and a blue filter using AKs blue for panzer thinned about 80% with white spirit.
If you see it forming around details like a wash, then it's too heavy. You also don't want to drown the surface, just get some filter into your brush, get excess off to a paper towel, then go around the whole part.
Then a black wash. Dark wash from ammo of mig used, thinned about 80% again.
And cleaned up.
Next some white oils were dotted around. For larger surfaces you can use a bit more varied colors from buff to yellow and blues.
Then blended in with white spirit.
To finish it off a bit of dry brushing with light gray enamel mixed with white oil paint.
And here's a finished Harpoon launcher. Here you can see the same piece, but different angle to show how all the shades disappear.
They do look a lot better to naked eye and all the steps are worth it imo.
