Sorry about all the clutter behind the model...it's just too big to move around all the time for images. I have to make sure I pay close attention to getting all the mast hoops for the spanker sail in place before I mount/step the spanker mast. So too for all the other masts that will be having pin posts added to their bases. I probably won't secure the masts till they are totally complete. Clear skies and smooth sailing ....... Rob
- 1,208 replies
- great republic
- clipper
Well after lots of quality time working on the build...I finished up the spanker mast....oiled it and the jimboom..tinkered on a few other minor details..I think I'm done for the day. What's next..... Well I still need to rig the top deadeyes and futtock shrouds on each mast and then rig the topmasts and so forth till I'm done with the masting. Here's a couple more pics. Rob
- 1,208 replies
- great republic
- clipper
Amazing!..How you do it is besides me...... Working through that little opening. Heah..I found a ship in a bottle in an antique shop the other day...I think it is the Charles W Morgan...there is a whale along side the ship splashing. What do you think?
Well..I'm almost there. Here are a few images to bring ya'll up to speed. I finished the tops and rigged them with their eyebolts...now I'm focusing on the spanker mast. Rob
- 1,208 replies
- great republic
- clipper
Finished the foremast top. I had to make 3 sizes of eyebolts for this build and set the medium bolts for the clew/leach line blocks. They were probably painted....because black iron rust horribly in salt air. After I finish all three masts..I will add the deadeyes and futtock shrouds. Rob
- 1,208 replies
- great republic
- clipper
Amazing story...thank you for sharing. Rob
- 281 replies
- falls of clyde
- tanker
OK..I see what direction you are headed. I wasn't sure of the sling design Webb's mast crew used. Slinging from underneath the top via an eyebolt to the yard sling band is probably the easiest method anyway. Earlier clippers may have used the sling that goes up and around the mast head with a leather sleeve. What I do, is make a measurement of the length of the chain sling and mount the chain to its eye bolt up between the cheeks...and then let it hang until I am ready to mount the trussed yard. I will then make adjustments to the sling length(If need be) before making the final connection to the mast sling eye bolt. This way...I can have the mast finished, stepped and ready for yards without trying to add the tedious sling later. Any way...that's my way. I really appreciate following your build...it motivates me and sets a good example to follow. Rob
- 3,618 replies
- young america
- clipper
Just so no one is confused(especially myself)..... the Fore/main/mizzen lower masts doublings will be painted black as will the top mast doublings. I left them white and was waiting till the mast is fully assembled before painting them. The top masts and topgallant masts will be Varnished...only the doublings will be painted black. More later....as later gets closer. Rob
- 1,208 replies
- great republic
- clipper
Thanks Russ. Before the top gets mounted on the mast head...I still have to mount all the eyebolts for the bunt/leach line blocks. Rob
- 1,208 replies
- great republic
- clipper
I was noticing Ed...how will you be attaching the chain sling to the mast....is the eye bolt hidden? Beautiful work. (Upon further study) I was wondering if the YA design called for an additional thumb cleat aft to support the chain sling that ran up through the lubbers hole to the thumb cleat...or will the sling stay low down near the bolsters. Will you simulate leather sheathes? Rob
- 3,618 replies
- young america
- clipper
Thanks Russ and everyone for all the likes..... I worked about 40 minutes on the GR and finished the first top...2 others will proceed in similar fashion. Rob
- 1,208 replies
- great republic
- clipper
Thanks Patrick.....The masts are temporarily stepped...so I can remove them to finish the tops and add all the hardware and eyebolts I hope to finish up all the tops this weekend. Rob.
- 1,208 replies
- great republic
- clipper
Fantastic work Ed......I'll be building the tops for the GR this weekend myself...thanks for the fine example. Rob
- 3,618 replies
- young america
- clipper
Pandora by marsalv - FINISHED - 1:52
rwiederrich replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Good night Nurse! Fantastic work on the mass production of the blocks....very nice indeed Rob -
MONTAÑES by Amalio
rwiederrich replied to Amalio's topic in - Build logs for subjects built 1751 - 1800
Simply amazing....almost baffling. So much detail that can go un-noticed by the less then discriminating viewer. Stunning! Rob -
Cast your anchor has some scale boats that might work... Rob
- 453 replies
- thermopylae
- sergal
- 1,208 replies
- great republic
- clipper
- 1,208 replies
- great republic
- clipper
After lengthy searching I found the appropriate version that nearly represents the Great Republic as she sailed down from Boston to NY. One item that will be altered is the lower spanker mast which was not painted white, but was varnished to permit free movement of the spanker sail mast hoops. As depicted in lithographs of the period and described by eye witnesses(Such as Duncan McLean) she had no sail higher then Royals forward and aft. This a good representation of how I will depict the beautiful Great Republic. It is prudent to mention that most images and paintings of her show her with 6 sails per mast...this was her final representation after she was rebuilt...this was because her overall sail plan was reduced(doesn't look like it when you go from 5 sails per mast to 6)...but the size of each sail/yard was reduced significantly...so in reality she actually lost several hundred yards of canvas. No wonder she was originally called the *Behemoth*. She was HUGE with the largest main yards (120ft) ever placed on a sailing vessel. Rob
- 1,208 replies
- great republic
- clipper
Looks fantastic...but if I may suggest...try using some bees wax on your lines...it covers up all those frizzies and smooth's out the line. Cotton line is notorious for frizzing. Super attention to clean detail.... Rob
- 130 replies
- mare nostrum
- artesania latina
Your carving skill is second to none...coupled with an acute sense of balance and symmetry...I'd say nothing could really be a challenge for you...unless maybe you choose to build something like this... Looking forward to your next adventure. Rob
- 728 replies
- le fleuron
- 64 gun
Green/White....that all depends on what stage of her life you want to model her in....I guess..... Rob
- 453 replies
- thermopylae
- sergal
No...I was building the 1/96 scale version. I reversed my direction on her and am turning this kit into a kit bashed version of the West Coast built clipper the Western Shore...build in Coos Bay in 1874,,,the last wooden clipper ever built, anywhere in the world.
- 453 replies
- thermopylae
- sergal
What stage are you going to build her? With green hull or white...when she was cut down to a barkentine? I started the Revell Version first painting it.
- 453 replies
- thermopylae
- sergal
