Posts posted by Peter Bloemendaal
Thanks Bossman, Chuck and PRS and also thanks again for all the likes.
Well, the speaking tube with tube bases, mizzen mast coat, ship's wheel ropes, hanging and lodging knees and second bulkhead are in. Before I can continue I need to get the next 4 sets of gun tackles done (sigh) so it's a good opportunity now for some photo's.
Here she goes...
- CiscoH, GrandpaPhil, CaptMorgan and 7 others
- 10
Thanks Vladimir and thanks for the likes as well.
I ended up deciding to add the gun tackles as well. So the break in working on the guns and doing some deck fittings must have helped...lol.
I have started working from the aft and doing them in sets of 4 or 5 so I can continue building up the gun deck following the instructions.
As this point 4 sets of guns are done and I have added the aft bulkhead.
Here are a few photo's.
Another small log entry. I am undecided if I will add the gun tackles or leave them off. While mulling this over I decided to spent some time on the deck fittings. I needed a break from the cannon build anyway because it was quite a marathon effort.
The rudder trunk are capstan are finished and I made a start on the ship's stove. The photoetched and brass bits on the left are all blackened which I prefer to painting. I has a better "metal" look in my opinion. And the painting option is still there if the surface gets scratched or damaged.
Here are some photo's.
- Ekis, WalrusGuy, Edwardkenway and 3 others
- 6
Hi WalrusGuy,
All is well, thanks for asking. I lost my Mojo for a while and noticed I started to make silly mistakes. So I took a bit of a break and covered the model up for a few months. When I got going again with building the 12 pounder cannons, I didn't take a lot of photo's, so this log entry is a bit of a jump from where the model was at with my previous entry. I'll try to create more regular entries again.
- JpR62, WalrusGuy, Edwardkenway and 3 others
- 6
16 hours ago, Ekis said:
A particularly neat and precise shipyard: bravo! 👋
Thanks Ekis.👍
15 hours ago, Bossman said:Very nice work! As for the brick work, which looks fine, once the stove and drip pan covers 60 % of it and you are looking down through beams and planking, anything you think “is not nailed” will disappear.
I wish the progress on my Confederacy build was behind yours. Your log might have given me the discipline to slow down. You are making a beautiful ship model.Very true. I did actually have a look at the stove coverage and the location in relation to it's surroundings and gave it my own thumbs up. I'm sure the brickwork on the actual ship didn't look 'new' as well after a few years worth of cooking (just aiming to be authentic here.....cough, cough)...lol
I can't believe how fast you are going. I'm already past the one year mark and expect to tack on at least another 2 before I finish. Yours looks almost finished after only 8 months. And the speed hasn't diminished the quality at all. It's a beautiful ship...
Thanks again for the likes and comments. Time for a progress update with a few photo's.
I added some red to the bulwarks (makes a big difference to the appearance of the model, almost feels like I'm getting somewhere...., for a little while.), added the margin planks and the waterways.
The extra bend to the margin planks made the fit a lot better.
Next was the checkerboard floor panel. I have been concerned for a while about getting the strips accurately cut with a scalpel only and have been playing with the idea of getting a cheap or secondhand 4" table saw. In the end I didn't trust the cheap Chinese options, couldn't find a secondhand one and end up just going for it with the scalpel....lol. I shouldn't have stressed as the result in my humble opinion is quite acceptable.
Here are some photo's (in random order).
- Ekis, JpR62, Edwardkenway and 8 others
- 11
Here is an update on the progress with chapter 9, the planking of the Bulwarks. WelI..., maybe a bit more than just progress, I have basically finished them. I only still need to paint them red.
When starting to look ahead at the next step, the margin planks, I noticed that the curve of the most forward plank doesn't match my model, there is quite a gap. So I used Chuck's jig to laterally bend the hull planks to give the margin plank a bit of an extra bend. I added a photo. I'll find out tomorrow if it worked or not.
The last photo I just added to show my work setup (in it's un-edited messy state...);
- JpR62, Edwardkenway, chris watton and 5 others
- 8
Again, Thanks for the likes everyone.
I have added just 3 photo's this time with not a lot of progress. I decided to add the ropes to the stern port hinges, try to simulate the bolt heads to the pintels, gudgeons, keel plate and horse shoe plate with some CA (with mixed results).
I also added small pins to try to accentuate the stern port hinges a bit.
After I took these photo's the rudder has gone into "storage" until the end of the built. A pin came off one of the pintels when putting the assembly back into my working cradle. The rudder was slightly angled, didn't make the slot and jammed a bit.
So to avoid future mishaps, while using the cradle I won't have the rudder assembly fitted.
- oneslim, JpR62, CaptMorgan and 9 others
- 12
Here is the continuation of the rudder efforts. I did try soldering for a bit but this was a big fail. Too flimsy to hold the parts in place and I couldn't get the solder to adhere to both parts. So CA glue was used as the next best option. I'm pretty happy with the result. I managed to be able to take the rudder assembly on and off the stern post as intended.
- GrandpaPhil, Tigersteve, Dwight and 12 others
- 15
A little progress on the rudder. I remember I had a lot of problems with fitting the pintels and gudgeons on my Syren build so I plan to take it slow. I might try soldering the pins onto the pintels this time. Using CA glue on the pins isn't very strong and gets messy when things don't fit 100%.
Here are some photo's. All dry fitted up to this point.
- Duanelaker, Edwardkenway, BenD and 8 others
- 11
Thanks John,
I pretty much use Gorilla PVA wood glue for everything (except rigging of course). It glues more than just wood, takes long enough to cure to move things around if necessary and any excess can easily be cleaned or peeled off while it's curing.
Up to this point in the model I only used superglue to help glue 2 parts because I needed the instant "hold".
Peter
11 hours ago, Bossman said:
Peter, that is sweet! Excellent work. That’s as good as it gets.
Thanks Bossman..
10 hours ago, svein erik said:hi Peter, the model is nice and you doing a wondeful job as always😊
svein erik
Thanks Svein...
Well, first a big thanks for the compliments and the likes.
I have completed Chapter 7, the Stern and quarter galleries. Like most I struggled with finding the right color for the castings and photo etched details. Please don't ask how I got to the color I used. I mixed that much that often, I wouldn't have a clue. In the end I just settled with what I got and hoped for the best.
I have attached some photo's. A few to show how I added a small "spacer strip" to help align the letters CONFEDERACY and a few how I raised the back of the model so I could better align the castings (I didn't like to do that upside down). And a few of the final stages. I used "Micro Kristal Klear" to create the windows.
Peter
To start off, thanks for the likes everyone.
I must honestly admit that this has been a bit of a scary part of the built with lots of (luckily small) breakages and creative ways to "clamp" bits together. In a lot of cases my fingers were the 'clamp' where I patiently listened to songs on the radio hoping my fingers wouldn't cramp up. I also started using superglue and PVA glue together. Superglue for the instant 'grab' and PVA for the added strength. Considering all that, I am happy with where I am at the moment. Not perfect, but not too bad either...
Here are some photo's....(which have been loaded in reverse order.....)
- JpR62, tommay1953, Edwardkenway and 7 others
- 10
I took a break from sanding a bit and did some work on the stern. I added the cap rails and the first shell layer that closes the galleries. I decided to bend my own cap rails and not use the laser cut parts. I wasn't sure the staining of the laser cut parts would be consistent and bending them didn't cause any problems.
I do believe that earlier in the build I might have made some mistakes as the shells supplied in the kit weren't even close to the area's they needed to cover. To get a start on how to start shaping the shells, I made some dummy cardboard shells first and added the windows at the most visually logical position and used this assembly to shape the wooden one. The photo's will show what I mean. Maybe this way I'll get away with it. Definitely a challenging part of the build...
Just plodding along here...lol
- CiscoH, Edwardkenway, JohnB40 and 6 others
- 9
Thanks John,
Yep, you will need plenty of sandpaper. Its tedious work, the thinner the bulwalks get the less pressure you want to apply, the less you take off. It's the old "the final 10% takes 90% of your time. I find it difficult at times to judge when enough is enough.
I have a loyal black Labrador always laying down at my feet in front of the worbench. If I stand there sanding for too long he slowly seems to change colour....
Peter.
I have been happily creating saw dust by reducing the inboard sides of the hull. When I took the following photo's I thought it was pretty much done but while editing them and checking Chuck's manual again I realized I still have a little bit more to do, Especially a bit more thinning out is required at the deck level.....sigh...
Still I think it's OK to show the photo's, so here they are....
- Dwight, Dubz, Edwardkenway and 8 others
- 11
On 5/26/2020 at 7:46 PM, Bossman said:
I think you have it in the short rows Peter. She looks great.
On 5/27/2020 at 9:41 AM, Voyageur said:Beautiful work, always impressive.
22 hours ago, Rob S said:Very nice planking work; she is coming along nicely.
18 hours ago, JpR62 said:Superb ! A pleasure to be able to follow this build log !
The Confederacy is really a beautiful ship model.
Thanks everyone. I certainly appreciate the comments.
- Peta_V, Edwardkenway, VTHokiEE and 8 others
- 11
3 hours ago, Bossman said:
Nicely done Sir! The planking looks great.
Thanks Bossman.
Time for another update. Thanks for the likes everyone, they are certainly appreciated.
Planking the hull is finished and the treenails have been added as well. I decided to not paint the planks below the wales white but to just coat them with a sanding sealer and clear varnish. With the stain I used above the wales there is enough colour contrast. The stain didn't give a uniform finish as I feared but it is what it is. I don't think its too bad and the busier it gets in thore areas the less noticable it becomes.
Next stage will be the Stern and quarter galleries. Fingers crossed on that one.
- WalrusGuy, BenD, Tigersteve and 9 others
- 12
US Brig Syren by WalrusGuy - FINISHED - Model Shipways - Scale 1:64 - Second wooden ship build
An absolutely stunning model. Hats off to you...👍
