Moab
Everything posted by Moab
  1. Tony; WOW! Really beautiful. If you're looking for some reference on masting and rigging you might want to check out the Panart Armed Launch. I think there's a build on this forum or go to Google Images and input "Panart Armed Launch...Moab
  2. Beautiful craftsmanship! Your "step by step" of the planking is very helpful to this rookie...Moab
  3. Thanks SpyGlass. Yup! Across the grain or perpendicular to the grain. I'm going to try the microwave first. Thanx again...Moab
  4. Can someone point in the direction of how to bend planks across the grain. ...Moab
  5. I too have the same concern mentioned in Kurt's post about Li-po batteries. Has anyone had problems with these batteries?...MOAB
  6. I may be the last to know about this. I purchased the Dremel Chuck Adapter and like it. I no longer need to change the internal collet adapter when I use a different size bit.....Moab
  7. Can't say I disagree with anything above. I use Titebond whenever possible but I guess too often I want to get things done more quickly. A couple of suggestions which I know have been mentioned elsewhere: I use a sewing needle with the top cut off and the other end placed in a short dowel so it looks like a pencil. I dip the needle into a small container of ca and carefully place the glue where I want it. I think a toothpick can also be used. No matter how careful I am some ca always ends up where it's not wanted. I've found that if I carefully place some debonder on the ca and let it work into the nasty ca it will soften and can often be scrapped off. But in the end I admit ca can be evil evil stuff.
  8. First, a happy, healthy and peaceful new year to all. i just tried my first bottle of Mercury Brand ca glue (medium). The glue itself works as well as any other glue I've used. What sets it apart is the material used for the closuer...it works "incredibly" well!!! I used the entire bottle and never had any clogs, etc. They offer the basic range of products plus epoxy and have a website for more info...Moab
  9. I use glue sticks (Elmer's, Scotch, etc) 80 percent of the time. Inexpensive, clean and I've never had a glue-up problem with them...Moab
  10. Thanx to all. If I move ahead I'll do a build if possible. Thanx again...Moab
  11. I'm considering building the BlueJacket "Spray" kit. I've built other BlueJacket kits and am always impressed with the quality. Does anyone have any information about this kit or better yet building the kit?...Moab
  12. Fantastic! Please give us some updates as you begin working with it...Moab
  13. Guys and gals; my apologies for the last post. Not sure what I did wrong. Perhaps indenting doesn't work...Moab
  14. Beautiful knife. I'm not sure I have a top four but: -Lee valley low angle block plane. -Violin makers plane. These are very small and rather expensive but fantastic. Not sure what type of steel they use but the blade remains very sharp for an extended period. I think Lee Valley sells them. -I get a great deal of use from my digital readout caliper. I've tested it and it's very accurate. -I consider glue a tool. I use Loctite gel glue (not the gel in the black applicator) for many applications. To achieve a bond it only requires a "very small" amount. A tip I learned somewhere is after you can't squeeze out any more glue cut off the exterior plastic housing (very carefully...try not to puncture the inner tube). The remaining tube extends the amount of usable glue. This technique yields almost twice the amount of this "pricy" glue.
  15. Guys; thanx for the feedback. I'll checkout the options....Moab
  16. Tony; just caught up eith your build. I've tried to scratch build using a mould and reading your build really helps. Love the jigs you made. I look forward to following your build...Moab
  17. GL; the progress really looks great. I've tried many methods of prepping wood for planking. I haven't tried the ten minute in boiling approach. Is this your "go to method" when you do planking? Does it work for those tough bends?...Moab
  18. Thank you all for the feedback. There's a lot to consider! ...Moab
  19. A wonderful looking ship. I've learned many techniques "I should have used" on my Virginia build......Moab
  20. Guys and gals; I double checked this with Jim. Because the sander used a "capacitor start motor" you can't use a variable speed controller with the sander. Bummer...Moab
