Dowmer
Posts posted by Dowmer
  1. 8 hours ago, archjofo said:
    Hi Bob,
    Thank you very much for pointing out this tiny detail.
    Since the hooks are very small, it will be very difficult to do it properly.
    So I do not know yet if I'll do it.
    Johann,
    Seeing your fine execution of details, I have no doubt you could replicate the mousing. I was noticing the same thing, but Bob was quicker to comment.
    Below is my amateurish and feeble attempt at the same scale on a long boat.  I’m sure yours would be much better.
    cheers
  2. Joe, one of the things I’ve found that helps me with “cutting” moldings is if you are scraping a 1/16” molding to cut a 1/16” slot into the scraper first.  That will channel the strip consistently, then cut the profile into the bottom of the slot.  The depth of the slot you cut obviously controls the depth of the profile.  I hope that helps.
    I typically use an Exacto blade for the scraper.  I can then fit it into a handle to use.  For cutting I use a thin abrasive cutting wheel in the Dremel then finish with fine Swiss files if needed. There are many ways of accomplishing the task, this is the one that works for me.
    Here’s a pic of one I used many years ago.
  3. 26 minutes ago, Chuck said:
    I also think they do this on some contemporary models because they are most readily viewed from the side and by turning the head slightly, you can see the face detail better as models are usually displayed.  On one side anyway.
    Actually, someone else mentioned it before.  I only agreed.  However, that is water under the proverbial bridge.
    I agree with your statement above and probably explains the head turn the best.  It is what it is.  Either way, it’s a beautiful model and I’m amazed at the quality which far exceeds anything else on the market.  So Kudos and keep up the quality and offerings for us meager followers. 😀
  4. Very nice Chuck and Mike.  You guys really know how to build an outstanding model.
    Chuck, the figurehead looks great and the resin casting is a pretty darn good match.  One thing keeps bothering me however.  The head of the figure is turned fairly hard to starboard, as if it’s looking at something on that side.  Most figureheads Ive ever seen are looking forward.  As if they are clearing the way for the ship or looking at the horizon.  In one of your original contemporary pictures of the Winnie the head might have a slight angle but nothing as pronounced as this.  It just looks a bit weird with the figure looking to the side like that.  Just my .02 cents.  Still beautiful work but since you have been so meticulous with every other detail I just wanted to point it out.
  5. 3 hours ago, Chuck said:
    really good example of this is shown below on this contemporary model.
    Chuck, I’m glad you liked and used the pic I took of the Rodgers Collection Frigate. I took it specifically because I liked the planking and stealer in the bow. I guess it was worth while. Interesting note is the hawes holes. It looks like the builder used some lead to line the holes like the full size but you can see the lead sickness.
    The planking is looking great by the way. 👌
