Jeffb
Posts posted by Jeffb
  1. On 1/23/2024 at 5:18 PM, LER said:
    At the bow of the boat there are two lanterns, and you mounted them on small metal tubing to allow led lights to go up into the lanterns. My question is how did you bend the tubing without it crimping?
    Lee Richards
    Hi Lee,
    Another method you can use is to thread a solid wire slightly smaller than the inner diameter of the tube through the tube before you bend it and removing the wire after bending the tube. I have done this with stainless steel tubing used for HO scale (1/87 scale) lights. It is the method used for Ngineering LED lights for railroad models. Provided the bend isn’t too sharp it works well.
  2. It's been a while and I've been slowly making progress.  I am almost finished the running rigging.  Does that mean I'm finished if I'm not doing sails or do I need to rig the sail tackle?  It seems to me of the sails are not on the ship that the rigging for the sails would also be off.
  3. Thanks for your comments, everyone.
    The anchor is next.  There isn't much about the anchor itself in the instructions, just the rigging is covered.  This is where the small library of references I have been building has come in handy.
    After blackening the anchor and fabricating a ring, the stock was made:
    Bands were made with black construction paper:
    The ring was blackened and an inside cinch tied the rope to the anchor:
    IMG_3348.thumb.JPG.22133ca24f97dd0cb5ec48bea6d74a9a.JPGIMG_3349.thumb.JPG.3373efd73d87bfd6e89e188fa3d92a17.JPG
    The completed anchor on the model:
    I asked earlier about whether or not the anchor rope would have been tarred or not and there are opinions on both sides so I decided to follow the direction provided for the Model Shipways Armed Virginia Sloop and considered it to be lightly tarred (brown).
    Thanks for checking in.  As always, helpful advice is appreciated.
    Jeff
  4. Thanks Allan and Bob.
    Thanks for pointing out my mistake with the gratings, Allan.  The mistake is mine.  The plans are correct.  Unfortunately, it's too late to change it now but I know for next time.  The reason I bought this model was to learn and practice some of the basic techniques I need to know when tackling something more complex.  Plastic models are often criticized for their inaccuracies and hard to follow instructions but they don't hold a candle to these models.  It is helpful advice from members of this forum and the growing number of references in my library.
    Bob, I usually have more than one project on the go at the same time and will switch back and forth when I hit a wall.  I use to time on one project to contemplate the challenge presented by the first and build up the fortitude to return to it.
    Here's a few more photos:
    I'm about to start on the anchor.  The rope for the anchor included in the kit is dark brown.  It seems to me that the anchor rope should be beige.  Am I correct?
    Thanks for following along with me.
    Jeff
  5. I haven't posted for a while; my apologies.  I seem to have hit a wall when I got to the rigging and worked on some other things for a bit while I contemplated the rigging.  This forum has been a great resource to get me up and running again as I slowly, oh so slowly, carry on with this build.  Here are some progress photos:
    IMG_3296.thumb.JPG.9fdad2fc5c1c8c4f46e6559122ca447d.JPGIMG_3298.thumb.JPG.04cbf736ccddb936573c40daf446dd55.JPG
    I've finished the standing rigging at this point and I have to take more photos for an update.  This is great fun.
    Thanks for checking in.  Any helpful comments/advice is appreciated.
    Jeff
  6. Thanks to those who have liked and commented on the build.
    Thanks Phil, for directing me to your thread.  Wow!  I started reading it and realized it's going to take more than a casual sit down to take it all in!  I appreciate all the work you put into it and then sharing your learnings.  I will definitely being using it as a resource for rigging this model as well as future builds.
    Jeff
  7. Thanks, Bob!
    Things have been progressing slowly in the shipyard.
    I've finished the masts, gaffs, booms, and yards.
    There's likely differing opinions on this but I went ahead and stepped the masts before rigging.
    One of the reasons that I stepped the masts before rigging was the way I did the mast coats.  After doing some research and reading a number of build threads I thought it would be more authentic this way: I made a wooden ring at the deck level around the masts.  I then took a strip of cheese cloth that I painted black and glued it over the ring around the mast to appear like tarred cloth around the base of the mast.  This is the result:
    I have a bit of cleaning up to do where the bowsprit rests on the stem and a few touchups and its on to the rigging.
    Jeff
  8. Thanks, Bob.  Continuing on with the build, I have made some progress.
    I have mounted the model on a stand and have started on the masts.  The bowsprit and jibboom are not permanently mounted, just set in position.
    IMG_2799.thumb.JPG.941189625a8f2736feb3e96fdfd3c697.JPGIMG_2801.thumb.JPG.0d78bd818415033969552242a903e25e.JPG
    IMG_2800.thumb.JPG.9812e1bb3d946514be025b4f13561088.JPGIMG_2802.thumb.JPG.458e1fe62c82a96542c557548a20dbba.JPGIMG_2803.thumb.JPG.f8aeb32d63550e15f76fc4588a36324f.JPG
    I have also started on the foremast.  It is set in place for the photo.
    That's all for now.
    Stay safe.
    Jeff
  9. 20 hours ago, Dr PR said:
    Jeff,
    Nice work! I had missed this build in the past. We are both working on similar ships. I am currently designing the rigging and sails for the ship.
    I am curious, how long is the model (hull)? Do the plans give dimensions for the actual ship?
    Thank you, Phil.
    I've just had a look at your build and it is impressive.  I will go back and read it in more detail.  There is a lot of things I would do differently after seeing yours.  Its all about learning from the building process of others and myself with each model being better than the previous.
    As for this build, the model is 1/48 scale, the hull is 15 inches and the beam is 4 inches.
    The dimensions on the plans are length BP: 56' 1" and beam 15' 3".
    The model is not one of an actual ship but is a representation of a small private armed schooner typical of the War of 1812 period.
    I hope this is helpful.
    Jeff
