Everything posted by Edwardkenway
Thank you Mark for your encouraging comments.👍 The scrap box will never be empty on this and subsequent builds. Anyway back to the cross section and I'm celebrating as I've finished cutting the frames.🍾👍As soon as my deck structure wood turns up I'll be cutting all the components of those out but I can see more than a lot of pieces of walnut now that the frames are glued. Just a "bit" of sanding and I'm ready to start putting it together. I just realized why I'm still waiting for my wood, I forgot to click ORDER😠
- 94 replies
- Triton
- first attempt
Whilst looking for someone in the uk who supplies differenttypes of wood to use for my triton build I came across the Wood Veneer Hub who have cherry veneer sheets 345cm × 18cm at 1.5mm thick for £11.91 so I wondered if any uk members have used this site for this and wether it would be suitable for planking. Any input gratefully received. Cheers
Cracking job LS, those ratlines look great and as for the anchors well what can I say except fantastic 😀👍 Cheers
- 104 replies
- sherbourne
- caldercraft
Excellent work Norway!! Nice neat little ship. Cheers Jon
- 53 replies
- pickle
- caldercraft
Hello LS, yes I bought these plans from NRG for $5 = £4.34. I hope to make everything but the cannon, rigging yarn, blocks and deadeyes but we will see if I can manage this. It's going to be quite a challenge but I have no time constrictions on this build, it will be as and when. Thanks for looking in. Cheers 😀
Hi all, The borrowed jigsaw did the job and then had 2 or 3 hours with old trusty cutting the b/h . I've dry fitted them to the keel former and there is quite a bit of tweaking to do. I must say although it's still using a saw it made a change from cutting the components for the x section frames. I'm gonna need a bigger table!! If I'm going to do more of this type of build I got to get a band saw or a scroll saw, it was a lot of cutting.
Hi LS That little extra you've just done with the anchors is just great. Good work. He told you !!😋😅
- 104 replies
- sherbourne
- caldercraft
Hi all, had 2 or 3 hours on my cross section mainly cutting frames and assembling them. I've only got four more to make, but as my decking timber has not arrive yet I'm not going to rush them. This is because I've found that when rushing thing go wrong, and that's why my last two frames were cut out twice with one of them going in the scrap box. Well till next time, Cheers
- 94 replies
- Triton
- first attempt
Very nice LS, she's looking very ship shape. Great work. Cheers
- 104 replies
- sherbourne
- caldercraft
Hi LS, looking good, I agree with you, I found rigging can be a very enjoyable part of the build. I think your masts and spars look neat and sharp with their paint job. Keep up the good work Cheers
- 104 replies
- sherbourne
- caldercraft
Proxxon jigsaw or a scroll saw
Edwardkenway replied to Edwardkenway's topic in Modeling tools and Workshop Equipment
@vaddoc I have come to the conclusion that if I'm going to buy anything it will be a scroll saw. As to all the other toys my other half would raise more than her eyebrows. But till my budget is healthy enough to get said scroll saw I will persevere with my coping saw and for smaller more delicate work a jewellers saw. Thanks for your input it is greatly appreciated. Also thanks to everyone who has contributed to this discussion. Cheers -
Hi all, Could not find the time to get any more frames made up, so decided to have a crack at the gun carriage axles and wheels. I racked my brain thinking what to use for the wheels but then I looked at the pencil I'd been chewing, it would be perfect as it was 5mm diameter and the lead ran exactly through the centre. So I drilled the lead out and then sliced the pencil into as many rounds as it would make as I was bound to break some.I could not cut them to thin as they just broke apart so there was a lot of sanding to make them look passable. All in all I had an enjoyable couple of hours doing this. Oh well back to the frames next time, although there's no rush as I'm waiting for the wood for the deck structure to arrive. Cheers
- 94 replies
- Triton
- first attempt
