Everything posted by Edwardkenway
Hello everyone, @AnobiumPunctatum thanks for looking in. @ChadB I'm glad you like them as they are the 3rd edition knees as 1 and 2 just didn't cut it! WOOHOO!!! another deck to do! I've done it a different way this time, I've used a spot of CA glue just on the edge carlings to make the framework and then filled the rest in using white glue. I didn't have any teak oil left so bought some Danish oil, tested it on some scrap, (Hanging knee edition 1 haha) liked it so put a coat on the lowest internal planks also on the hatch coaming. That's it for today, thanks for the likes everybody 👍 Till next time Cheers
- 94 replies
- Triton
- first attempt
Hello all, thanks for looking in and the likes 👍 So just spent a stressful couple or four hours cutting, shaping and sanding only to scrap them and recutting and reshaping!! Welcome to the quest to produce eight reasonably similar hanging knees, I think I've managed it and have fitted them to the underside of the lower deck. Also fitted gunport sills and dry fitted lower deck centre supports. The frames need a bit more fairing on the outer side but I'll do that next time. Dry fitted gun deck beams and cut the beam arms. That's it for this post. Till next time Cheers
- 94 replies
- Triton
- first attempt
Very very nice LS she compliments Ballahoo beautifully. You got some great touches in there and they have elevated her out of the ordinary. Well done 😃👍 So on to the next project with a whole lot more skills than when you first started with Ballahoo. Keep up the great work.
- 104 replies
- sherbourne
- caldercraft
Hi LS, what can I say but great work!! You've done a sterling job with the rigging and Sherbourne looks fantastic. I hope you had fun along the way? Whatever you choose to do next I shall be following with interest. Good luck Cheers
- 104 replies
- sherbourne
- caldercraft
Brig Eagle 1814 by ChadB
Edwardkenway replied to ChadB's topic in - Build logs for subjects built 1801 - 1850
Hi Chad, Eagle is looking amazing!! I am in awe of you and other full frame ship builders as you put so much detail into the ship. Please keep up the good work and I'm watching avidly. Cheers Jon -
Hi Chad I'm in construction as a bricklayer and they don't lay well in the wet!! Also when the temperature drops below 2 degrees Celsius work grinds to a halt, so over the British winter I can get quite a bit of time in the shipyard. I'm mainly a housebuilder but do get to build other things from time to time.
- 94 replies
- Triton
- first attempt
Hi, been at work today so only had couple of hours on X section this evening. Still at work on the lower deck structure, lots of components, the knees take a bit of cutting and shaping to make them fit. I think there is at least another 2 or 3 hours work before this deck is done, then it's more of the same for the gun deck. Thanks Chad, Eamonn, Phil and Blackviking for your interest 👍 Til next time. Cheers
- 94 replies
- Triton
- first attempt
Hi Peta, I've been following this build and it's looking really great, you have exceptional skill.
- 315 replies
- master korabel
- avos
Thanks again Chad, I'll try the teak oil on some scrap as you suggested, if it looks good I'll get the hanging and lodging knees done then give the planking an oiling. Cheers Jon
- 94 replies
- Triton
- first attempt
Thanks Chad. I was just going to put a matt varnish on it. I wouldn't know what oil to use. I have some teak oil for the outdoor chairs, would that do it? Cheers Jon
- 94 replies
- Triton
- first attempt
Hi, RAIN AGAIN@#@÷!!, so not at work. Started on the lower deck structure, it's so intensive, I have nothing but the utmost respect for those people doing a full framed scratch build, all those frames and decks. But I'm getting there (faster with the weather as it is). Got let the glue dry so till next time😉👍 Cheers
- 94 replies
- Triton
- first attempt
Good to see you back Eamonn, it will be nice to see your Ballhoo out of ordinary! Sherbourne is a nice boat to build, and another in the fleet is always welcome. I'm glad you got a brand new shipyard too😃👍 Cheers
- 1,039 replies
- ballahoo
- caldercraft
Beautiful galleys and your music is sublime sir. Thank you.
- 73 replies
- mediterranean
- galley
Hi again, more rain today so more time on Triton X section. More planking on the inside and beam arms cut and attached to the deck beam. If it keeps raining I shall have this finished😅 Thanks for the likes and looking in👍sorry about the strobing effect of the planking but I'm mainly using whatever wood I have and just buying what I haven't got.
- 94 replies
- Triton
- first attempt
Thanks for looking in Eamonn 👍 Hi, we got a lot of rain here where I live so got myself a few more hours on Triton X section. As I knew they would the deck beams I fixed yesterday had to come off, well one of them. Started to plank the inside. Shaped the limber stakes from some basswood as it was the largest strip I have in my stock. The thick stuff over the futtock joints is beech. I'm liking the beech wood, I may have to use it on my Triton POB build. This X section is coming along now, still slowly but I can see what I'm doing now. Well that's it for now, because I have to let the glue dry. Till next time Cheers
- 94 replies
- Triton
- first attempt
Hi all, Just small update, my wood arrived just about 24 hours after clicking order. So marked lower deck clamp and glued planks to sit deck beams on then dry fitted two beams as test. As they fitted I glued them in place, but no doubt they'll have to come out again!!! but it is only white glue. The rest of the beams are now laying out pinned to put the required camber on them. There's a lot of cutting notching and measuring to do now so till next time. 😅 Cheers Thanks for the likes.👍
- 94 replies
- Triton
- first attempt
Hi all, Another short stint on the cross section and it has seen me attach the frames to the keel and then fix the keelson. Now waiting for the glue to dry before doing more. Till next time Cheers Thank you all who have looked in.😉
- 94 replies
- Triton
- first attempt
Bob thanks for the advice, I have bought some very fine blades, they are Japanese and are a spiral so I can cut in any direction without having to alter the saw frame. That said I will look into upgrading my coping saw, so many thanks for your interest and encouragement . Cheers
- 94 replies
- Triton
- first attempt
