Everything posted by cog
I'll follow at a safe distance ... if you do not mind ... even if you did
- 263 replies
- nave tonda
- round ship
geisha ...? someone needs to poor the liquid when the hands become unsteady ... to spill is a sin ...
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
the details you added are very fine. Haven't seen such very often on kit builds. Well done
- 48 replies
- first build
- bowdoin
You gents seem to forget those are Japanese subs ...
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
it's the one I'm building. I will do the Huron too. I wanted to do a G class but could't find a kit. should have looked under tribal class At the start I didn't yet know which one to build, then Lou came up with the Glowworm ... what can I say ... I'm a sucker for underdogs
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Gawd, that sub must be the cleanest in the fleet OC ... and spoiled rooten for all the rubbin' she's gotten so far!!
- 229 replies
- trafalger class
- airfix
Following kit instructions ... you call that fun ... ? So far there has been one challenge: Getting the hull plating to show at this scale. Before that,:To glue or not to glue ... now ripping things up, and adding components, makes it start to look almost like a scratch build a bit of a basratch build It starts to cool down - I know Greg: Tain't 'alf 'ot 'ere - so tonight I'll get my rattle can of flat varnish out and give Vendetta and the two Japanese subs a coat. After drying, the subs get a gloss coating on their balast tanks to make them look whet-ish for some realism when I get on a diorama ... I'm visualising palmtrees , a sandy bay, white beaches, tropical drinks ........ and two moored subs ... whats wrong in this picture
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
Again thanks for the likes and the comments! CLeared the deck with the molds to stick the platform on. primed a couple of parts, funnels, base of the forard "super"structure, 4.7" guns (inside, and bottom), replaced the bollards, and fairleads. I'll try tomake a picture with the difference kit vs detail up. I'll need to build a searchlight tower, and change the bridge's rear section. Going to have some fun ... that's for certain
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
(For Lou ) Bringing the aft raised gun platform into proportions for Glowworm ... (glad I have two of this kit, so I can mess up ) ripping it up .. Putting it back together again ...
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
You meant whip, of course, from a whipping with yer fathres belt Strange but effective setup Piet. Look forward as to how you will finish it ...
- 378 replies
- java
- pacific crossroads
Thank you gents, for the likes, and your positive feeds ... those keep me going for another day
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
and you wouldn't want to disappoint me ... naturally ... you did, as usual, trigger my curiosity though ... cannot wait for the sequel on the bridge's decorations
- 405 replies
- tamiya
- king george v
Don't drag, use the bin icon on the image itself. Very nice, and crisp detail. You really did a wonderful job there
- 48 replies
- first build
- bowdoin
You have a strange building streak by keeping us in suspense ... you know what happens with cunning plans ...
- 263 replies
- nave tonda
- round ship
Piet, He means the colour scheme from 1942 to 1944 ... ( ) It really does make a vast difference, Greg, so much better. Is it a tripod mast?
- 405 replies
- tamiya
- king george v
Would that be logical ... It is odd as they seem to be the result of the mezza lune technique. But how would you make a fluent hull shape if you did use them ...
- 263 replies
- nave tonda
- round ship
HMCSS Victoria 1855 by BANYAN - 1:72
cog replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Looks good for the size it has Pat.- 1,013 replies
- gun dispatch vessel
- victoria
When you have them double in your edit box at the bottom where you upload the images to show in your post, you should throw one out, it will disapear from the posting, at least, I presume that is the matter
- 48 replies
- first build
- bowdoin
I have one against the forward bulkhead of the rear gun platform, as good a place as any. You are making nice progress, getting used to 1/350 scale ...
- 1,090 replies
- showcase models
- vendetta
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
For a first timer, you do a marvelous job, even if you had build before, you are doing a wonderful job
- 48 replies
- first build
- bowdoin
The hull plating I applied with primer over the length of the ship is just 3mm wide ... I'll be needing a brush with a single hair
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
The point is, when I look at the model in her present paint covering, I can distinghuis the hull plates quite well. What will be the result after the final colour coats have been applied ... will the plating still be visible ... I can try it on this one, and if it isn't pronouced enough, I can add the highlights and shades on the HMCS Huron, which I'll be building too ... decisions, decisions, decisions ... (Never knew plastic models could be so hard to build)
- 292 replies
- g class destroyer
- trumpeter
(and 4 more)
