cog
Everything posted by cog
  1. IWith a grainy-ish paint you could get the desired effect on smaller scale as well, i.e. to a certain degree
  2. No, I'll definitely make HMS Glowworm, but I'll probably make the kit's intended ship too. Then I only need a Kiwi ship to make the commonwealth series, since I got Vendetta as Aussie representative, maybe Hoff00 can help me on a Kiwi destroyer
  3. although assumption is the mother of all FUs, you are right. only two sets my friend. That has got to do with the way they set up their spues, as little deviation as possible ...
  4. Good progress Denis. You could paint the forwar gun dark grey, even both, when you look at the run of your camouflage. I replaced the "peddestal legs" with brass rod. Nice an strong, even at 0.3mm
  5. You can always continue after you retire, I heard you should have enough time by then ... at least, that's what is said ...
  6. Now that would be near impossible to believe ... Never seen you very lonesome matey ... besides I keep on visiting the Vendetta log ... often in vain
  7. Ahhhhhhhhhhhhh, GOOD MORNING VIETNAM!!! ... no pictures. Still waiting on the books I ordered. Got the camouflage book on destroyers, sloops, corvettes, and other smaller vessels. Interesting picsies. I might make a second one of these G & H class's ... or keep on changing the camo until I've got what I like ...
  8. I've used Vallejo varnish, but was advised to use a rattle can. In my build of a Fokker Dr1 I found that Vallejo paints mixed rather easily even after drying(!) so I presume they have a likewise effect when varnished ...
  9. Ah someone from the dark ages I saw somewhere you are going into P&P like MFD - come to think of it that's a bit like MFU ... the Man From Uncle ...
  10. Hmmm, never seen those series ... before my time, but I've seen Simon Templar ... and The Avengers ... probably before your time
  11. Frank, exceptional, you even got Popeye stumbling over his words!!!
  12. Denis, You can find railings in PE for USN ships, or RN, etc. You can also buy stanchions in PE or metal and thread them yourself (like I did on the O16 build here), and Greg did on Yamato and a few others of his Japanese home fleet. The railing you can do with either very thin copper/brass wire, or thread, e.g. like I used on the Vendetta for the rigging ... you shall certainly work something out to make the Arizona shine, like she should and not be a cheap lookng model
  13. I think he's run out of batteries, Denis ... far to silent for The Man From Downunder (something like the Man From Snowy River ) Have you noticed he uses the wrong letters: RGL => MFD
  14. Scott, They'll probabl only learn the hard way, so good on you. Take care they'll not push the shipping down your throat(!)
  15. It's always a pain to get the wrong materials, I hope the supplier made the slip, and sent you the wrong one.
  16. Nice saves, Denis. As you see, you'll be needing some additional PE ... strictly a kit bound set doesn't work ... Progressing steadily!
  17. Wonderful, Michael. You make her shine. Funnels look good. I was afraid you might pull some paint off with the masking tape, glad it turned out so well
  18. Out of sight out of mind ... I think not spinach-man you come with your questions, we'll give you an answer - if it's the right one ... you may wonder ... and eventually find out
  19. Michael, Greg (RGL) has had some problems too with Vallejo primer on brass and plastic. He pointed me towards the Tamiya, as it dries very quickly and you can spray immediately after if needs be. Naturally it's better to let it cure for a day. Although, I have been quite impatient with priming, and the results are good.with my neglected curing period. It is better to spray outside or a ventilated room with a fan to suck the vapours out. I have an attick above the garage where I have my spray booth, so I won't get the stench into the house. With Vallejo I could pull whole sheets of primer of and lay bare the brass again, even after a month curing ...
  20. Well, as long as do not need to keep them open all night, because you are shaving something ... doing a fine job, whilst you keep your mind on it, and do not bother to much about me watching you ...
