Everything posted by Retired guy
Thanks for your comments Wally and Dave, these are the drawings from LB Jenson book the Bluenose 11 (these are to help with my build if not allowed please delete) He shows a drawing of the Bluenose which I have used for stove and chimney and the other two show the inside of the Schooner Caroline Rose. This is part of the Captain cabin This is where I am now and will paint it white inside. Will be adding some curtains where their beds go Also got the cove painted and also the bowsprit painted and installed Until next time Regards Richard
Getting close to a year without a post 🤔 where does time go 🙄 A while ago I started making some parts inside the main cabin, used the information from LB Jensons book but they are not from the Bluenose, they are based on photographs of the Schooner Caroline Rose. Just wondering if the inside would be painted white Regards Richard
Brilliant rigging Joe do like your baggywrinkle do have a few to make for the Bluenose, do you have a drawing how you made them. Did you use the rope from the kit or did you buy or did you make your own. Regards Richard
- 139 replies
- benjamin w latham
- model shipways
Not nice to hear pinging, could you put a small bow in the bowsprit so you don't need to tighten the rigging as much 🤔 you might get this pinging again 1 month or a year or two later, just a thought. Regards Richard
Hi Keith all is well and staying safe, I know Bluenose is sitting there waiting for me to re-hire Mo & Jo they quit on me saying I was not paying them enough though the pandemic !! See you are giving us more eye candy with your latest pic's, your daughter is going to have one very special keep sake when you give it to her Regards Richard
I had a lot to catch up, the machine work and how you orchestrate your pieces through them is just brilliant Keith, learning another level or two 👍 Regards Richard
Just catching up with your WIP Dave wow, well done on the brake beam and pumps 100% better than the supplied pieces and I know how small these are Regards Richard
- 389 replies
- bluenose
- model shipways
Hi Wally just spent an hour catching up on your brilliant build, you are doing a fantastic job on her well done mate. Regards Richard
- 949 replies
- syren
- model shipways
Very nice Dave 👍 isn't it nice to figure out how you are going to build something and then go and build it. Regards Richard
- 389 replies
- bluenose
- model shipways
Thanks Gary it was a small update but time consuming but I do like how they came out just way better than my first attempt, see right of picture Yea the clamps work great for handling small stuff got many of her small tools which again use a lot Thanks Per as you see from the pic above the re-do was needed, you should try it, was a lot of fun but it was also a lot of filing Hi Keith thanks for your kind comment, I have been told this before on other sites, and I am not quite sure why! did follow the instruction in the manual, used the supplied brass flat bar and then miss interpreted how the chain plate should look, and then I look at a lot of pictures, so it needed to get reworked will look like the picture now Thanks again for all the comments and also for all the likes Regards Richard
Brilliantly done mate she's close to the finish line eh 👍 Regards Richard
- 139 replies
- benjamin w latham
- model shipways
Wow just brilliant Gary every piece looks so real and your weathering is something I would love to accomplish. Regards Richard
Hi Eric, bit late with the reply but thanks for looking in and your kind comment do apricate it. So have done a little more to her but not so much in making but redoing, it started with the lower chain plates, which I had made from the brass strips .016" thick supplied with the kit found this out once I removed them, thought I had used some .010" brass sheet. So now I remade them out of .005" solder small tube to the ends then made a jig to drill the mounting holes and now have the lower chain plates more to scale. Then was not to happy with the black paint job so sanded that down and as per Robin letting me know that I had not painted the sides right I masked the hull up to include black up the sides of the main rail and Monkey rail, board and buffalo rail. Put some semi gloss on Next up was to remake the eye bolts for the deadeye strops which I had made from wire and did not look to good, tried by making out of thicker wire and then soldering a small tube to the ends, but this did not work to well when I went to bend them to go around deadeye 🤔 So decided to use .016" brass flat bar worked out where I needed the holes, drill them first then filed to shape then bent to shape, came out way better than my first try. Casey blacked all parts and will use a small bolt and nut Well not much to show these past few months have to figure what I am going to do with the scroll around the hawse holes then paint the cove, then the name plates. Thanks again for all who have looked in and commenting on my on going build. Regards Richard
I am also catching up on your brilliant project Keith and wow what eye candy that was just love the detail you add 👍 Regards Richard
Just to let you know I followed the instruction manual starting on page 10 and 11 Fig 1-3 and Fig 1-4 regarding bulkhead stanchions, I beveled and cut the stanchions as it says to do and then once I had the waterways installed made up the main rail and used fig 1-14 to install fake bulwarks stanchions, these I made with inboard bevel were needed to suit the shape of hull, not sure why you would need to cut them off 🤔 These bulkheads are not plywood so they do blend in well with the fake stanchions and also they help a lot when time to start planking. Hope this helps Regards Richard
Just caught up with your build Dave all looking very nice great job, you have come along way 👍 and I am glad you have taken to the machines, and each piece you make will just get better once you learn the skills, as my Dad always said to me Rome wasn't built in a day 🙂 Regards Richard
- 389 replies
- bluenose
- model shipways
Just caught up with you build Joe shrouds look brilliant and well worth the doing and all look to scale. Regards Richard
- 139 replies
- benjamin w latham
- model shipways
Just looked in the book I have by Arthur Bugler O.B.E and he has the drawings of 12 pounder Short 8'-2", 12 pounder Medium 9'-2" and 12 pounder Long 9'-8" 24 pounder 10'-3 1/2" and 32 pounder 10'-3 1/2" 32 & 24 pounder gun carriage 6'-2 1/2" long, and both the same width, 12 pounder gun carriage long and medium are the same at 5'-6 1/4" and short 5'-0 1/4" all the same width 12 pounder (long) 30 in number upper deck 12 pounder (medium) 2 in number forecastle deck 12 pounder (short) 12 in number quarter deck 24 pounder 28 in number middle deck 32 pounder 30 in number lower deck I also have a drawing from the book on the 68 pounder Carronade and the carriage This would be as the refit of 1805 (Trafalgar condition) If you would like anymore info send me a pm I am no expert on this subject just giving you some dimension from another books information. Regards Richard
