EricWilliamMarshall
Everything posted by EricWilliamMarshall
  1. Wow, what a great prep for one of your retirement hobbies! I’ll say again, which is what everyone else says, beautiful beautiful work. If I do a Bluenose build, it will be cause of you.
  2. If Nirvana is correct, then you should have a rigging plan included. Also note that the current version of the kit is in the same scale and the instructions can be downloaded from https://modelexpo-online.com/Model-Shipways-RATTLESNAKE-US-PRIVATEER-164-SCALE_p_1016.html . If you are missing that plan, same company does sell the plans separately as well. The instructions state that they use the same scale plans as drawn in 1963. There a fair number of build logs here of the Rattlesnake (in the same scale) here, so you may wish to check out a build log or two (take a look at https://modelshipworld.com/applications/core/interface/file/attachment.php?id=563017 for a list of links). Good luck and welcome!
  3. whoa! I'd happy to finish all that in a decade, let alone all at once!!
  4. Welcome!! If Chris' suggestion doesn't pan out, post your question with the text in question and some photos! There is a fair bit of commonality in the construction of these models and there are actual experts here in MSW. What part of the model are you work on now?
  5. Stumped me as well. Supports for glass shelves? Neck bolts for Frankenstein’s monster? Etc.
  6. I’ve fixed rudder. I’m prepping the cloth for this model’s set of sails/experiments. I’m also now thinking about string. The kit contains two tiny amounts in two sizes in white only with instructions to dye white to a darker color as needed. Of course, I’m unsure how much to dye, since I haven’t figured what goes where and in what amounts. So I’m thinking making rope, although I’ve never done that. Since the photo on the cover of the box is my current go-to reference - I noticed that some is the rope is wrapped with smaller string (making it served rope). I’m curious about that as well. Where that is used, how to do it well (and labor intensive is it if folks feel the need for serving machines!)
  7. Nothing perfect yet. The current approach is a bit of ammonia and fine steel wool for prep. I also let the solution be in contact with the brass longer than suggested and I let everything alone for a day or two before handling. Something in that list makes the brass a little more resistant to touching, but I'm not sure what. <shrug> I'm still searching. Let me know if you figure it out.
  8. Bob, Just a heads up, I use Birchwood Casey Brass Black and find if the brass isn’t clean, the black will rub off as well.
  9. Question: On the Mardar and Panzer at the end of the second set, both have the look of wind-swept dust. How did you achieve that effect? Great collection/beautiful work! Thanks for sharing!
  10. Ha ha ha!! To be fore warned is to be fore armed!! I’ll attempt to meet the danger head on!
  11. That’s great!! If MSW had t-shirts, that should be the tag line!
  12. As a new builder myself, I would add the following: Take a look at instructions and practicums of the kit you are thinking of building. The better the instructions, the less mistakes and second-guessing. Having said that, you will make mistake no matter what and that is part of the adventure. None of mine have been show-stoppers (yet), but it can be tough on the soul some times. Take a look at the Model Expo site; the Shipways models have the instructions available for free download. Some of the manuals are practically books themselves! Even if you don’t want to build any of those models, just skimming will give you a sense of order of operations and the difference between scales, etc. I would suggest creating a build log as well, so questions can reach experts with full context, leading to better answers. Good luck and I look forward seeing what you create!!
  13. Yup, you were kind enough to answer my question about your library! I found a large number of those book are quite affordable used! Not all of them have arrived yet.
  14. Then I dragged the profile over the area I want to cut. I then added paint to cover the revealed wood. Ideally I would have done this earlier before assembly. So it goes.
  15. Chuck and Bill were discussing creating profile cutter or scrapers from scrap brass sheet a few weeks back at at one of Chuck’s workshop for the SMSNJ. (Thanks Chuck!!) And I thought it wouldn’t hurt to apply the idea to my little adventure. I cut a bit of tin with snips and then used a jeweler’s saw to cut a small negative profile.
  16. Wood finishes are messy too though. I would love to have such metal working skills! I have a mini Taig lathe that my daughter and I are trying to come to grips with. How many of those accessories (in the 1st photo) did you make?!?
  17. Deck or mast collars seem to the name of the “interface where the mast goes through the deck” and the mast boots “help prevent water leakage where the mast goes through the deck”. Quoted from https://www.rigrite.com/Spars/SparParts/Deck_collars.php
