Everything posted by Mirabell61
Build log part 23 I would so much like to carry on with the bow area, but realize that there is a lot to still be done underneath the forecastle deck first. Think I will have do the stove and other Details in near future the portside guns will be rigged Standing on the Support rails under the carriage wheels all te svivel gunposts are only in "raw" condition, may want to get them 8-sided in upper portions Status overview just Setting the new guns in place for Dimension checking I tryed to get the rudder coppering only, shiny again, used Lemon concentrate Juice, it works very easy but I don`t know if I should have done that. I love the greenish Patina look like some others have tryed already Nils
Build log part 7 here the baseplate for the casing, the standplate and the two pedestals have been made (pedestals again made from old candleholders) foredeck completed together with the selfmade anchor winch the steering chain leaves the wheelhouse, is turned 90° over a block, under the Little bench, and heads under the lifeboat towards Stern over the boats deck in guided stanchions Stern flagpost and capstan added, and two life-raft Containments in their launching racks on the boatsdeck. The ruddershaft in its sleeve-tube goes through all decks anchor winch who saw the mistake ? (Sternlight should be White instead of green) Build log part 8 to follow.... (part 8 + 9) shall be the last two intended parts for this build Nils
- 70 replies
Doing the guns in repeatable mode saves some time, once the method is on track... My work desk is quite a mess, since I have my own room and do`nt have to clean up during the day, and I still have 4 more to do. Am thinking of adding small wooden splints to the axis close to the wheels, but shall do that as last Action Nils Trial #1, small wire Pins secure wheels on axis Trial #2, small wooden splints hold back the wheels (I prefer this Version) Gun builders desk have 10 done so far, 4 more to go..
Bob, nice method of doing the deadeyes, respect, but lots of spanning, drilling and Fixing work.... Question, why do These yourself, is it because of "throughout scratch build" ? Nils
- 420 replies
Congrats to your completed build Peter, the Irene is a wonderful built Little gem Nils
- 109 replies
- zeeschouw
- billing boats
Thank you Popeye, The use of These turnbuckles is a great help to strumm set the cables and stays Nils
- 70 replies
Well done planking Ken, your neat built model in all is looking wonderful Nils
- 455 replies
- fair american
- model shipways
Beautiful cutter Peter, very nice Fitting out of the deck and all Details, lloks great Nils
- 28 replies
- cutter
- lady nelson
(and 3 more)
Build log part 6 wheelhouse with hinged door, Bridge grating, port nav. light, bell and 90° Lever for operating the steam whistle (per wire Connection to the funnel) starboard side with lifevest chest here a nice brass anchor, modified a bit, will be blackened later on here again one of These Little benches on Bridge deck Crew and Gothenburg passengers boarded for a next roundtrip, lifeboats rigged up Build log 7 to follow.... Nils
- 70 replies
Popeye, Dragzz, and Crackers, Thank you so much for your Kind words, it honors me very much to receive all these praises Nils
- 70 replies
Frank, Understand your Intension with the dark Background... can`t wait for you to get started with the Alert(one of my favorite cutters) Nils
- 389 replies
- supply
- caldercraft
Hi Michael, I`m presently just working on the same Detail, and intend to do it this way,,, drill 0,5mm to the axis, carefully widen up with 0,8mm drill and shift in a small wooden Splint. In your sample it Looks like you are also using washers, These I will leave away. This is what the assembly Looks like.... Nils
Frank, congrats to the Launch of your Supply, we heard all the horns as she browsed down the slipway... But what hapened to your cameras Flash ? this fine model is worth and desperately crying for having bright and colorful Photos. It is a beautiful model you can be proud of... What is your next ? Nils
- 389 replies
- supply
- caldercraft
Aah, you have a good eye Popeye, it is the Billings "Cux 97" and it is still waiting to be completed, for that one I also did not purchase the Fittings kit. The Boat kit is as old as the Bohuslän and out of that early building period. I also have the Billing Boats "Marie Jeanne" thunny fisher but that one is fully completed and in a glass case. Nils
- 70 replies
Bruce, I just had a look at your build page 1-6 and am very impressed of your Clipper Lightning. Are there any previously posted parts of the Framework, hull, plating sequences, etc, that perhaps went lost after the MSW 1 Crash ? Have I missed anything ? In all a very nice and clean built model, shall love to see the coming parts Well done! Nils
Build log part 5 the Bohuslän has a very nice slim Stern, and the whole waterline appearance in birds view Looks like she is designed for Swift coastal travel prop and rudder are well protected against unpurposed ground contacts in shallow waters the handrails are from Mahagoni but laminated with thin aero-ply from below to avoid Splitting when shaping and Drilling them the Little clinker planked lifeboats are models of their own for the boats strappings I cut some stripes from black Roof-Skin plastic material I still had the Integration of the three trims into the metal plating worked out quite well Gothenburgs town badge-flag set at the bowpost, and rigging of the Forward mast and load Derrick under way Build log part 6 to follow... Nils
- 70 replies
Correct Popeye, the wooden parts were all printed on Wood, those were the times the modeler had one or two good old jigsaws and lots of thin blades in different tooth sizes Handy. I don`t even remember if the Frames had to be cut out or not. But I can remember that there was a perfect straking of the Planks to the Framework, it was really enjoyable and easy to plank in single mode. Nils
- 70 replies
Thank you Nigel, when I bought the kit it was so Long ago, and good kits of steamships were quite rare on the market. It is a pitty that Billing Boats did not Keep up with it in their program Nils
- 70 replies
Thank you Nigel, I am glad the guns worked out quite well for the scale size, allthough I learned now that the hoops (makes sense) will be scratching the decks, but that would be my individual note.... I thought about chemical blackening hoops and gunbarrels for many times, but I find the brass contrust to the carriages in cherry- stained color tells you they are not of resin or of plastic. Nils
Thanks Mark, nice words, yes it is wonderfull to be in contact with world wide modelers, and to get the Impression what challenging project others are doing.... For me also it is a nice exercise (please excuse grammer and spelling)to communicate now and then in english language after I have retired from business Nils
Hi Peter, sounds Logical what you say about Wood wheels on Wooden deck, but taking in account the wrong historic Approach here, I find it Looks better with hoops in brass contrust, the wheels would otherwise look quite boring.. Nils
