Everything posted by Mirabell61
Elia, first my birthay greetings, enjoy your Special day and have fun.. Coming to your build, it is stunning to watch this ship growing on your slipway. A dream of a gloucester schooner with its wonderful lines, your single planking, your workmanship, this all makes ones heart beat faster..., Shall stay tuned very, very well done !!! Nils
Build log part 27 starboard side first metal Support bracket for step platform second bracket mounted and brought to alignment platform fit test and weight testing check out guns placed underneath and ladder inbetween (to be shortend accordingly) Still Need to do the same experience on port side Arrangement of chainpump crank handle and bearing supports view through quarter badge window. Unfortunately the first and the last two links of the Girlande broke off and unfindable got lost somewhere... I first wanted to decorate the cabins with furniture, but I think I`ll leave it as is (less is more) Build log part 28 to follow... Nils
Hello Peter, thanks for looking in and for your comments I like... In answer to your questions.., most probably no, I don`nt know if the ship had any pinrail on the bulkhead, this is free to the builders Interpretation and is set up only for belaying the aft-carriage guntackle backing ropes that come guided from the eyelets and blocks left / right of the small grating to give free Access to the doors of the bulkheads, without stepping into ropecoils. As for the Stern this again is the builders Interpretation... I`m not sure what you mean with the "lower Counter", but trust you mean that the hull planking should have been rounded upwards to form a Little "***". I was seeking for stand hight all along and also in the entire great cabin, so I did`nt want to loose space in the aft lower Corner deckline. I was expecting that comment from the other 1/64 Swan class builders as well, but as you have seen already I do`nt take the historic correct look of the Stern too seriously as Long as I am pleased with it myself. Take it as my special note For example, I do´nt know if there were any gasoil lamps in the rather dark space under the poop, but I simply liked to do some.. Peter, please stay tuned and feel free to comment at any time, I like it, it brings life and interest for all into the builds, even if off the correct way a bit. Cheers Nils
build log part 26 the forecastle underdeck will be next Shows what share is cut away of the poop deck here view into bottom cargo deck with shot locker, lower well area, storage rooms and staircases, and middle deck with upper well area, pantry and staircase. Forward decks with Crew quarters, staircases. Righthand the sailroom on the middle deck aft Portion with officers quarters. Masters cabin starboard behind the middle deck stairs, an rum barrel the guns under the poopdeck will Need to be rigged before the deck gets mounted shall use figures with 26 mm height (26 x 64 = 1664 mm ) considering the average actual sailors height with 165 cm that seems OK The upper bulwark / Stern angle brackets are only preliminary, they shall be replaced later Build log part 27 to follow... Nils
thank you Popeye slowly its getting somewhere, a pitty the decks shall be covering a lot of it, at least the halfdecks shall be cut away Nils
Looks beautiful Mike, wonderful lines, wonderful authentic build, Looks featherlight and must have a sparkling Performance when rowing the master to the shore... Nils
- 137 replies
- finished
- model shipways
Nigel, yes, there are 6 of them included in the etch set. Have now completed the two bulkheads and the intermediate wall in lengthwise direction (with door) between those bulkheads. Also some extra belaying Points and the oil-lamp lights and door hinges. Wish there were more hight in These Areas, but then I would have to Change the Amati plan completely. It was quite a fiddeling work to get those bulkheads in place, the larger one had to be separated in two parts, and then mounted in place, due to the trapez-like shape. I would reccomend that These bulkheads are planked equiped with all necessary Fitting out and mounted in place before the hull is planked, it would be much easier. Nils also two outer clamps port and starboard to the twin double door bulkhead the intermediate space between the bulkheads great cabin Forward bulkhead the upper Portion of the first bulkhead Need to trimmed off Flush when glue is dry
Thank you Buck, it is so many years back when I first saw that Bohuslän kit, and I fell in love with that old Lady, simply a must to build, and a good scale too (1/50) Nils
- 70 replies
Build log part 25 Fitting out of the aft two bulkheads, that will allow a later look into through the half cut away poopdeck from above the first mast channel Support brackets are still missing here the doors for the gundeck aft bulkhead, and the great cabin bulkhead. Because I started the starboard bulwark inner planking in oak, here again oak is used double doors to the great cabin. The doorpanels are of ply Color framed with Mahagoni rear side view. Here I`ll leave the Mahagoni Framework for the double doors away, and the brass knobs are only handles this bulkhead with the two double doors is the aft end of the gun deck, here in raw process... Nils
nicely built ship Steve, beautiful lines on that model... Nils
- 569 replies
- shenandoah
- corel
Congrats Mike, a very impressive looking brig... Well Done ! Nils
- 153 replies
- badger
- caldercraft
Alex, you have set the bar sky high. Although this skill, knowledge, and your model-building Performance of yours is unbelieveable and representing your Level of authentic accuracy and precision, it seems to me a model-build of the century. #Thank you so much for sharing your work here art MSW Very well done !! Nils
- 227 replies
- cumberland
- 74 gun
SS Vinal Haven by TBlack - FINISHED
Mirabell61 replied to TBlack's topic in - Build logs for subjects built 1851 - 1900
good work Tom, she Looks great ! Nils- 326 replies
- vinal haven
- steam ship
Bob lovely to read your own comments on your Trial and then mastery built deadeye straps. They look great and besides that you dicovered and used the silver solder procedure again.... Well done ! Nils
- 420 replies
Thank you B.E. was a flash idea with the brass Support brackets, unfortunately I ran out of material for those, and spent over an hour for looking for a new source on the web (was successful at last) Nils
Wonderfull warm looking Wood tone and lovely deck planking Drazen Nils
- 86 replies
- royal caroline
- yacht
Thank you Nigel. I remember when we communicated about how Fixing the channels (safely) on to the hull. This idea I had this morning when I wanted to cut out some wooden angles, but those would need to be glued on and probably ruining some of the brass decor with CA traces. Now the two bolts per Support give me confedence for sufficiant hold, and I also think it is not bad looking either. Shall now have to repeat the procedure to all other channels, but I`m running out of semiroundbrass bar with 1 x 2mm section. Nils
Starboard main mast channel attached, and brass supports from above... Position check with chainplates to end before the wale... Nils three supports chainplate length fits
nice sail making Tadeusz43, thanks for sharing.. Nils
