Mirabell61
Posts posted by Mirabell61
  1. Update
    now the semi round nutwood outer deck rails are mounted, and also the beech foot rails attached to the anchors. The larger and smaller deadeye are ready for rigging the masts. The deadeye fastening screws are still to be shortend a bit. The bow sprit spar has to be made fastend to the deck and rigged. The poles for bringing out the Zeesen network (Fishing gear) will be made later on
    Nils
    rails mounted
    deadeyes safely mounted to the deck anchors
    There are 4 smaller deadeyes for rigging the mizzen mast
  2. Update
    For the deck I had removed the intended pine planking again, changed the pattern arrangement and now mounted a new planking in straight larch wood, planks 4 x 0,8 mm. It went faster than I had thought
    This looks OK in my opinion and gives a good contrast with the beech wood comings
    The main mast with gaff and spars and the mizzen mast with boom and spars is also done, but yet without the rigging blocks that are on order
    Nils
    the first rough sanding is done.  The outcut on the front deck is for sight acess to the storage compartment and the anchor chain
    The brass anchors at the deckside shall be for mounting the footrail, the dark stained anchors are for taking up the shrouds
    the gaff to the main mast is rigged preliminary without blocks
  3. Update
    today I concentrated on the over night catch, Ì`m still looking for some eels in scale 1:24. Made the masts and main gaff,as well as mizzen boom
    Nils
    I used a thick viscosity primer both sides to get some "flesh" onto the flat etched fish....
    and turned them into Hering, plaice and cods. Am still looking out for some eels in scale 1:24
    The fish boxes are also from etched brass sheet
    the plaice remain white on the bottom side
    the mizzen mast can be layed down, when the shrouds are released
    The mizzen boom is hooked in for easy removal
    The main mast upper gaff is equiped with with a glide shoe, in order to slide up an down the main mast
  4. Daniel,
    I like the deck with the flush gratings and the sub-deck just below that with the triangle scuppers to the outboard, great details
    I wonder how the rather long containments beneath the gratings were regulary cleaned and rinsed, it must have developed a smell on the actual ship (seagrass, seaweeds, tang, etc). Maybe the gratings could have been taken up for cleaning
    Congrats, In all a masterly build
    Nils
