Posts posted by Mirabell61
many thanks Phil,
I would be pleased to see other metal plated model ships at the forum. I wish you much fun and success with your projects in planing
Nils
- Keith Black, Canute, mtaylor and 1 other
4
Thank you very much Andy and John,
The more feedback I get, the more I learn about these old steamers...
Andy
yes you`re right, I was too fixed on the centerkeel of the Ferris type ships (where I have the frameplan from).
The aspect of less draft without that keel allowing increased tonnage load makes sense. I can imagine there is a slight disadvantage without a keel standing out for lateral less corse holding reason.
I decided to leave the version I have as is, but shall allways carry the "Andy-Version" in mind for the future
Keep these good comments of yours coming in, they are much appreciated.
John
Thanks very much for your comparison scetches of bar- and flat keels, this rounds up the design versions very well
Nils
4
Andy, many thanks for your comment.... I appreciate very much that you know so much of the design of these lakers.
I`m not sure if I understood you right there, do you mean the ships bottom along the keelline should be flat, and flush with the hull skin ?
The keel in centerline is in the moment only standing out about 1,5 mm, wich I would`t mind about. Bilge keels and center keel are horizontal at the same level.
Nils
- realworkingsailor, Canute, mtaylor and 1 other
4
1 hour ago, steamschooner said:
coming along very nice. Nils
Thank you steamschooner
Nils
- Canute, Keith Black and mtaylor
3
Many thanks for your comments B.E. and John,
B.E.
the idias for solving some of the tricky sequences come with the progress....
John
Yes you`re right, I do`nt know either, as I have no pic on this detail from the movie.
Thanks for your detail showing the make / function of the compression stoppers. Great input, I`ll save this for another ocasion and they shoud`nt be difficult to make in brass or so, even the swivel handle and the locking pin
- Canute, Keith Black, FlyingFish and 1 other
4
- Ian_Grant, gjdale, FlyingFish and 8 others
11
I love this build !
A beautiful rigid lightweight POF design mate. A true boatbuilder skill is showing here. The lines are very impressing, and your measures to make her watertight for radio controlled sailing are wonderful, well done.
Nils
Update
I`m working on the anchor gear, today I made one of the two workable mini chain stoppers, the anchor tubes at the forcastle, and the anchor fairleads
Nils
for documentation (all decks) where the frames and supporting structure are situated I attched a scale before mounting the closed decks
the anchors are from cast metal, one can see where I plugged off hole in the skin made by an error
the anchor fairleads are from brass-coated steel
forecastle deck outlet of the anchorchain tubes
the raw forecastle deck is on
one of the two chain-stoppers
- steamschooner, FriedClams, druxey and 13 others
16
good job so far SHJ,
its going to be a fine ship after restoration. The sails are well and neatly sewn, you have bolt ropes sewed on all around, and your cleaning procedure looks great, well done. The hull shall require some special care and I`m sure you`l manage that as well....
Nils
- yvesvidal, GrandpaPhil, Valeriy V and 10 others
13
Many thanks Peter and John,
Peter, good to hear that you are back on track, keep the pics coming...,
I remember when once my chebec, in build stage, fell off the table and right onto the bow sprit. The sprit could be shafted and the rails replaced, nothing to be seen of the broken parts any more.
John, yes I dicovered those winches from a Hamburg based web shop, and also found they need a little deburring and cleaning up, in generel they have a good cast quality.
I have an idea what the poop bulkhead face covers will look like. The color is "desert sand". The door bulleyes ar slightly smaller in diameter and the silicone "glassing" worke well
Nils
- Valeriy V, Keith Black, Siggi52 and 11 others
14
Many thanks Peter,
I`m pleased to hear from you again, hope you are well.
hows your Bellerophon getting along to date...., or did you interrupt the build ?
Nils
- Keith Black, mtaylor and Canute
3
Hi Andy,
thanks for your kind comment .......
I am continuing with the vertical panels to the bulkheads for poop, forecastle and middle island. Here starting with the doors. Each door gets a bulleye.
Also the aft bumper rail is mounted and I`m preliminary positioning some of the load geer winches in dry fit. Also the rudder has been plated.
Unfortunately I have no building plan for all the super structure, and so I have to download lot of stand pics from the Sea Chase movie and to evaluate how things fit together. The hull itself I adopted from the Ferris type wooden Steamer, just about the same rating and tonnage as the Ergenstrasse aka the Corsicana Laker
Nils
I found these nice steam driven winches in scale 1:100, I wo`nt build them again myself like I did for the Heinrich Kayser model. They come in size to match for 1:87 scale as well
the rudder is plated
these will be the first doors. The low cost bulleyes are made from hollow rivets and the "glassing" is made from 3mm round extruded silicone sealer
Thank you Gary,
most self adhesive aluminium foil (used on ductwork, etc.) is too thin for good results. For poncing the best results were with 0,125 mm thickness.
Nils
- Canute, Keith Black, mtaylor and 2 others
5
Very nice build Gary, you`ve chosen a great boot....
Nils
- Glen McGuire, Canute, Keith Black and 2 others
4
1
ERGENSTRASSE by Mirabell61 - FINISHED - 1:87 - steamship
Many thanks for you`re compliment John....
I just came from the copy shop and placed an order for the shipnames and homeport (aft rounding and forecastle sides). The lady said it would be best to print in white on black self adhesive foil. See what comes out when finished...
The pics are showing the cutting of the 30 x 50 mm plating pannels with the paper table-guillotine, while the siliconed paper protection foil is still on. The gluefilm is acetat and it sticks like hell. A tool is actually required to remove the plating again
Nils
