Posts posted by Mirabell61
Hi Jond,
you did a great job there, the exchangeable rudder for RC and the extra keel for lateral balance. Can imagine her on the way over the lake or pond
Nils
2 hours ago, Blue Ensign said:
Thanks for looking in and for your interest B:E.
I`ll do my best to get this project through.....
Nils
11 minutes ago, LEFEBVRE said:
Many thanks for your kind words LEFEBVRE
with interest I`ll be looking forward to you Bohuslän-build pictures
Best regards
Nils
Update
the first 3 planks per side are on now. looks like there are not enough red cedar planks for the whole length, so I might need to use the cut off ends and stick / shaft them together.
Nils
planks are 1,5 x 6 mm
this is one of the pedestal spindle counter press in nuts
the frames deckside beams will need some trimming and adjusting in order to get a smooth deck lay on
Bob,
many thanks for forwarding the vidio you found on u-tube. After that I found quite a couple of other clips relating to the ship.
Frightening to see were the kids on board, having their childhood playground on a length of appr. 25 meters, and all without lifejackets nor safety harnesses in the masts and the rig. But you`re right, there are many good samples for the schoners historic fitting out. Being built and launched as a pilots work ship I`m not sure if there were an engine fitted in the beginning, probably not. The restored current vessel has been equiped with 2 props.
Nils
Update.
the hull is under way, the frames fit and glued to the keel, stringers are placed and now it is ready for planking....
The frames are made after glueing on the tranparent paper templates to the 2,5 mm thick 5 layers aero-plywood. per good old jig saw cutting
preliminary keel and stringers are for aligning the frames in centerline corresponding to the mounting board
the third last frame had to be replaced ( here cardboard template)
the outcuts for the stringers are 2 x 3 mm and possibly need to be slightly adjusted to straking and fitting the stringers flush with te frame outer contour
the wooden baseplate is a leftover of my Pegasus build, provided with new distance logs for the ELBE 5 frames
stringers fit to the frames, they are staking quite well and leave minimal touchup trimming. The keel will be brought to shape at a later time
there are two slots in the keel that take up the spindles of the pedastels later on. To allow sufficient countering of the spindles above the keel there are logs glued in between the appropriate frames
I fitted 14 frames at a distance of 40 mm. Here can be seen how filigrane the contstruction is. I use watertight white glue
the two brass pedestals made for old candle holders (flea market) and the zinc galvanised M3 spindles
The braced on short U-profiles take up the keel.
On 2/6/2022 at 9:52 PM, KeithAug said:
thank you Keith,
for your words and enjoy the buildlog as it goes on.....
Nils
On 2/5/2022 at 9:39 PM, Bob Cleek said:
Hello Bob,
with geat interest I read your lines about the schoners history under name Wander Bird. Many thanks for your input here, and for the nice pictures you provided. Its been a pleasure in building the model so far to date, and you will see I`m just beginning with the planking. The hull is a lightweight contruction, and the red cedar planks I`m using are leftovers from my earlier Chebeque build
Best regards
Nils
On 2/5/2022 at 3:39 AM, Jim Lad said:
hi John,
I agree with the paintings atmosphere, that was the final kick off to start with this model
Nils
On 2/5/2022 at 3:44 PM, wefalck said:
Hi Eberhart,
I am aware of the history of the ship. Regarding to the chosen scale, this is relating to the total outcome of the final model`s length (point of bowsprit to end of the lower large beam)
Nils
On 2/5/2022 at 3:44 PM, wefalck said: -
On 2/5/2022 at 1:42 AM, Roger Pellett said:
Hi Roger,
many thanks for looking in and for your remarks / question....
I`m unfortunately not knowing if there was a sister ship to the Elbe 5, but the Elbe 5 is a wooden built schoner originaly built in Hamburg
Nils
I`m starting a new project on this forum.
I fell in love with a two masted pilot schoner, that operated on the Elbe river, Elbe-mouth and german bay. The period about 1890. I`m adding some pictures I researched on the web, and information from marine paintings.
The enclosed print of an wonderful oil painting, was created by the marine painter Carl Becker, who died in1926.
The picture, adopted from one of my own books shows the pilot schoner "Elbe 5" before the elbe Estuary. The small pilot transfer boat brings the pilot back, now that the steamer in the background has presumably completed its journey down the Elbe river and is just about enter the Elbe mouth and onwards to the open sea.
The model will be scratch built and POF, equiped with gaff sails and appropriate rigging
The chosen scale will be 1:50 and the estimated build time 12 months from today. The displaying shall be on brass pedestals in a glass casing .......
the models rating will be:
length over all 725 mm
hull length 524 mm
breadth over frame 117 mm
Hight main mast from
decks railing 504 mm
copper cladding below the waterline
The original schoner has already changed it`s owners many times in life since the 1890 days, has been lovefully cherrished an equipped with up to date nautical- and safety equipment. After sinking to the river bed some years ago after an accidential crash wih a trader motorship it has been raised, restored and is now being operated by much enthusiated members of an association of maritime oldtimer ships and live museum craft. in Hamburg. They are also offering tourns on the Elbe river when the weather is suitable again.
Nils
print of an oil painting by Carl Becker (died 1926)
Elbe 5 in moderate breeze on Elbe river
below is showing the template of one of the 13 frames for the model. The frames will be cut out of 2,5mm thick multiply with 5 layers
Wow !
congrats, what a beautiful build Bob....
I love those open quaterdeckes enabling view to the many wooden joinings and the lower decks, all is neat and accurate indeed
Nils
very nice hullbuilding Sterlingclements,
looks like you have chosen a good and recomenable kit, congrats
Nils
Very nice build Jorge,
am looking forward to further build sequences to come......
Nils
- Jorge Diaz O and FrankWouts
- 2
Amalio,
wonderful looking cooking and baking stove !!
Nils
- Keith Black, Obormotov and mtaylor
- 3
On 8/31/2021 at 10:08 PM, mtaylor said:
Translation: I would like to thank you very much for this opportunity to look at it. There is hardly anything to add to the admiration for the perfection in craftsmanship, text, documentation and your pictures. A huge thank you, Gerhard
Gerhard, Dies ist eine englischsprachige Website. Bitte verwenden Sie Google oder andere Websites, um zu übersetzen und zu posten. Dankeschön.
Many thanks Gerhard,
I`m very pleased you liked the build, thank you for your kind words...
Nils
20 hours ago, Blue Ensign said:
Thank you Nils,
They are an eclectic mix of sitting figures purchased from Deans Marine.
Having separate arms and torso helped the 'conversion' to Royal Watermen of the early 18th century.
Unwanted detail was removed using the Dremel, and the tunics were added using Artists modelling paste, Milliput, and styrene strip.
These stage photos give you the idea.
3257
3388
3283
Regards,
B.E.
20 hours ago, Blue Ensign said:Thank you Nils,
3257
3388
3283
Regards,
B.E.
Good job B.E.
and thanks for your explaination....
Nils
beautiful model B.E.
are the oarsmen self made, or "tuned" regular available figurs ?
Nils
- Jack12477 and Blue Ensign
- 2
First build POF model.........
what an understatement NO IDEA ! , this is a performance that a very skilled builder would privide. love to see more as it comes in
Well done
Nils
- Hubac's Historian, No Idea, mtaylor and 3 others
- 6
Dove by jlefever - 1:48 - Pinky Schooner
Beautiful work Jim,
I very much like the Pinky....
Nils
