Posts posted by bolin
Falconet sells a Slavic warship kit. It looks very much like a Viking longship. Is this the kit you are inquiring about?
I have also been curious if there are any archeological or other sources behind that kit.
- Ryland Craze, mtaylor and BenD
- 3
Eight months ago I had four builds ongoing. Two scratch builds and two kits. Since then I have finished all but one. I found that I actually got a bit stressed of having several projects going in parallel. I do have a couple of kits in the stash, and several ideas for scratch builds I want to do. Maybe I’ll be distracted by one of them, but as many as four in parallel is too many for me.
My work space is also quite small, so it is easier to have a single build active at a time.
- JeffT, Ryland Craze, mtaylor and 3 others
- 6
I have had a fair bit of time to spend on the model, so the progress has been good. I'm now halfway on both sides.
I'm quite happy with the result. There is a small gap between the garboard strake and the next one on each side. I obviously missed clamping it tight enough. I will need to add some filler from the inside to fill it in.
When lining off the hull, I saw that it would need a couple of stealers in the deadwood area. I made a simple sketch on paper to see how they could be arranged.
Then when I laid the next stake I edge bent it so that the gap at the stern post is just wide enough for one plank (7mm).
... and with the stealer fitted.
- Peanut6, petervisser, baskerbosse and 1 other
- 3
- 1
A quick update on the progress of the planking. Not too much to show, actually. The planking will take some time as I try to do it properly and as good as a can.
The picture shows the second strake at the keel on the port side. Starboard side has already gotten this far. I will plank downwards from the wales and upwards from the keel on each side in rotation. In this way, I can let the glue set one one strake while I start to work on the next one. This will at least be possible until the planking meets in the middle.
I use 7 mm wide and 2 mm thick strips of beech. It is much better than the kit supplied obechi strips, which are practically unusable.
Something that is not unusable is surprisingly some of the fittings. I went through what was provided and found for example nice belaying pins of turned brass. The wheel, lanterns, chimney and some other parts also looks nice. The picture blow shows the parts that I have not discarded outright, like the plastic blocks and dead eyes.
I will not use the boat as such, but I consider using it as a mold when I build a new one.
Well done! A nice little boat, it has been a pleasure to follow your build. I have learned a thing our two from your work, thanks for sharing.
- Wintergreen and mtaylor
- 2
18 minutes ago, Nirvana said:
Something that caught my attention was the poster on the wall.
The Rolling Stones played in Lisbon 2014.
It probably fits well with when the kit was constructed 😃
7 hours ago, Nirvana said:
Bolin,
How do you like HobbyZone modular combination?
Looking like you got off with a good start. Was the ship a christmas gift?
I only used the HobbyZone building slip to try to get the hull to straighten itself. I took over the model from a man that had had it in his basement for 40 years, so it was a bit twisted when I got it. I later abandoned the building slip, when the hull is stable enough it is impractical. I prefer my home made keel clamp with feet attachments. It is much more versatile.The drawers etc from HobbyZone on the other hand are great. It is so nice to have Avery tool I need within closes reach. And with my small work space it is essential that every tool can be easily stored in its right place to avoid clutter.
After the transom has been replaced, I could finalize the fairing of the hull. It turned out that some shims were needed on two bulkheads.
With that fixed, I installed the topmost strakes on each side. I opted to make them full length and full width, to have a fair curve to base the rest of the planking against. In the picture I have temporarily installed the false deck from the kit to have a reference for the strake.
With two strakes on each side, I went on to divide the hull into bands. At the widest, bulkhead 5, there is room for 15.7 planks. With four bands, that gives about 4 strakes per band. I used the obechi wood from the kit for the battens. The old wood was very soft and brittle, it is barely usable for this task.
In the deadwood area the lowest band widens so that more than 4 planks are needed. My widest beech strip is 7 mm wide. I will need to use stealers there to cover it. At least two will be needed.
Hi Marcus
Polaris should be an excellent choice as a beginners model. Even better if you got a good deal on the kit.
Good luck
- Keith Black and mtaylor
- 2
Welcome to MSW!
What kit did you get?
- 2
Cute kitten 🐱
… and very interesting tutorial on medieval rope making.…the plow is also nice
…and the planking looks great!
You have been busy 🔨
- mtaylor, Brinkman and Keith Black
- 1
- 2
Looking good, it comes together nicely.
My best well wishes and hope for a quick recovery.
By the way, I found the "Kågen" book on an on-line bookseller today. I could not resist it, and ordered it. Maybe I will follow in your footsteps 😃
- mtaylor and Wintergreen
- 2
Thanks Chris 😀
Before I can start planking, I also want to replace the transom. When I got the started model the kit transom was already mounted.
I first considered planking it with thin strips. However, since I'm considering to leave the hull unpainted, I would need thin beech strips. I don't have that, so I built a new transom.
In the picture below, I have also test fitted the external stern piece.
Now back to beveling the bulkhead edges and fairing the hull.
This build has been gathering dust for a couple of months. I ran into some problems, took a break with another model, and got distracted by it. Now the other model is finished, and I can get back to this one. This is the result of my distractions...
So back to the difficulties I encountered. When I started to prepare the topmost strake by edge bending, I didn't seem to get it to run fair along the deck level. I thought that it was an issue with my edge bending technique, something that I have not done too much earlier. So I was considering if I should spile the planks from a sheet instead. And while I was considering ordering more wood, or try once more with edge bending, I got distracted...
Before coming back to this model, I read some other build logs, that discussed problems with edge bending. I started thinking, maybe I was trying to fit a strake to a curve (the deck level) that wasn't fair to begin with. First I checked with a batten to see how it wanted to run. It indicated that bulkhead 1 and 2 could be a bit high.
I then measured the height of each bulkhead at deck level and plotted it on the plans.
Sure enough, bulkhead 1 and 2 are indeed mounted too high by 2 to 3 mm. Since I have already installed the garboard strake I think I will need to modify the bulkheads in place. Otherwise, I could have tried to debond the glue and reinstalled them lower.
- Nirvana, Peanut6, chris watton and 5 others
- 8
Nice start! The Swampscott Dory was my first kit as well, I found it to be an excellent introduction to the hobby. Good luck with the rest.
Today I got a package from MassivHolzWerkstatt in Germany with replacement wood.
Beech strips for hull planking and a piece of thicker (7 mm) beech for keel, stern and stem.
Maple for deck planking and for hull planks for the lifeboat that I will need to scratch build.
I have no experience with either type earlier, but with the good quality I got I look forward to learn how they work.
With the hull much stiffer, I can start with adjusting it to my liking. The first thing is to cut away the keel and stem. They are in plywood, and I want to replace it with nicer solid wood.
I have also made some experiments with painting the wood strips provided in the kit. It seems to be Abache, a soft wood with rather visible grain. It doesn't look good, and there is risk that I cannot cover it up with sanding filler and paint. So today I have ordered some better wood for the hull planking, the deck and the lifeboat.
- Nirvana, Peanut6, GrandpaPhil and 4 others
- 7
If you have not checked the Wood database I can recommend it as a good source of information.
The wood you show could be Abeche, but it’s not clear from your picture.
Meta by bolin - Billing Boats - 1:40 - original fore-and-aft schooner rig
Thanks 😊 Yves
The tram and diorama kits are by Spanish
Occre. They have a line of different trams in scale 1:24. This one from Lisbon also had the diorama as an option.
The figures are by Tamiya. I think it was called “Collage friends 2” or something similar.
