Wahka_est
Members-
Everything posted by Wahka_est
Real nice work on rigging. Do you have picture or something what kind of knot you use to attatch blocks to yard?
- 358 replies
- occre
- santisima trinidad
Your planking is good for 1st layer. Now you just have to fill those holes. Just a suggestion - maybe try not to push all those nails in. Many of us removes those before sanding and 2nd planking. Sanding wise is a nightmare. For sanding you can also try small delta sander. i have used that for major part and then difficult parts by hand.
Some update. Have been focusing on hull. Railings now sanded and painted. Bow fittings glued. Some minor paint corrections needed. I disassembled some bow details and painted them black. Looks much better as i dont line plywood edges. Paintscheme-i like it. And nice is that i havent seen same one yet(not that there is many blogs ). Dry fitted deck equipment. Pumps and one grating still to be done. Rudder is also close to installation. As general in pleased with outcome. Have redone some parts that got “hairy” with painting. Still wondering when i should start with varnish. I guess the right answer is now. Eyelets about 40pcs have been painted black so i cant start with those also. Cannons have been complitely off the table so far. Most pieces have been removed from sheets but need sanding etc. QUESTION-as im using admiralty paints, should i varnish painted details. It seems that varnish is allready there as its little white before mixing.
Im little worried about only using CA as it might not last for years. Maybe before you totally close the hull add PVa to inside where planks meet the frame. I started with CA also but then turned to PVA only. Now i use it only in really difficult situations like glueing 2nd planing stern and bow parts etc. Otherwise good job!
- 19 replies
Got mine also few weeks ago and im supper impressed with it. It reduces the time for masts and yards, also boosts my quality on them. I dis not use knives for shaping but instead sanding sticks that worked better for me. Only issue is that 4mm piece does not really suit if its too long as it starts to vibrate. Here comes handy that you can put it trough the main socket and partially shape the wood. I recomend.
I would need little help. As the shipping from US is quite expensive for small order then can you suggest me Admiralty or Humbrol paints similar to Model Shipways. here is list of paints that i would need equal ones to: Bulwarks Dark Green – MS 4801 Bulwarks/Gun Carriage Red – MS 4802 True Blue – MS 4964 Hull Yellow Ochre – MS 4829 Black – MS 4830 White – MS 4831 English Oak (stain) – MS 4975 Pale Yellow Trim – MS 4804 Primer - MS4839 DeepBrown–MS4818 Yes its Essex paint scheme.
Tnx! Yes I am. Makes life much easier and boost my poor quality by hand. We had amazing discounts here as all hardware shops are competing for clients so i bought allmost all i need with 40% discount- didnt see myself not using that. Also most needed accessories. Discount ends tomorrow but they dont sell on web
