mcb
Posts posted by mcb
  1. Hello Again everyone,
    Thanks Keith Black, mtaylor and Canute.  Thanks everyone for the likes.
    Work on 'Isis' slowed down recently due to a busy August.
    After a little clean-up the marine legs will be ready to paint.
    Then perhaps final clean-up and assembly at last.  I thought that this would have been finished a long time ago, but I seem to always underestimate the time required.
    Thanks Again,
    MCB
  2. Hello Again,
    Thanks Keith, G. L., Kevin and Canute and thanks everyone for the likes.
    Well I thought that this project would be finished by now but I found a couple of things to correct.
    I discovered that the bottom of the hull had developed a significant bow a while ago and put it out of my mind, to be remedied later (mistake).
    I should have taken care of this before I put a lot of details on, especially the discharge tubes.
    So now the bottom of the hull has been sanded, I only have to clean up some clinging styrene dust and re-rig the extended discharge tube.
    I think that the styrene bowed  when I glued on the superstructure.
    The other problem was I was never happy with the previously assembled marine legs.  They did not hang right from their support arms and since they were built I have seen some photos suggesting how the bottom of a marine leg really appeared. Some slight adjustment of the proportions seemed necessary as well.  The pic below shows the old version and new under construction.
    Anyway I had hoped to show the completed model by now but I suppose now  it  might be a few more weeks.
    Thanks,
    MCB
  3. Hello Eurus,
    As Roger said above you should be able to find something to use for the wheel such as N scale model Railroad brake wheels (see below) in photo etched metal.  I thought I had something that could work in plastic but I didn't find it in a quick search of my inventory.
    If I recall Gold Metal Models may have offered water tight type doors (USN), but don't hold me to that.
    Good Luck,
    MCB
  4. Hello everyone,
    I thought I should report in as it has been a while since my last post.
    I have installed three of the discharge tubes with somewhat simplified rigging.  They were not as difficult as I was expecting.  I will leave the last one until after the marine legs are in place to avoid interference.
    After the marine legs: clean up/ touch up and perhaps add some details, then finished, I hope.
    Thanks for looking,
    MCB
  5. Hello Again,
    Thanks Mark, Wefalck, Kevin and Keith.  Thanks everyone for the likes.
    The aft compartment  that must be shallow to allow for the top of the boiler appears to contain extensions for the discharge tubes.
    Some of these tubes must be rubber or similar since they are flexible.
    Here attached is a crop from the same photo shown above.
    1648992307_X0398FloatingGrainElevatorISISprobatgrainpierCroppededit1(2).jpg.fb4f72c4a851aafc12a6410c8a056db4.jpg
    The opening in the forward part of the elevator is a mystery since it is blocked by grain barges in all of this series of (5) photos. Perhaps gear is stored in there?  You can see that most of the windows and doors are open for ventilation though it does not appear to be summer.
    Next up should be the discharge tubes.
    Have to go to work now.
    Thanks Again,
    MCB
  6. Hello Again,
    Thanks for the likes.  I put on the support brackets for the top of the stack, they don't look as bad as I thought they might.  I will probably keep them.
    There is not a lot left to do on this I think.
    Only the discharge tubes, door handles, marine legs and then a lot of touch-up/ clean-up.
    This thing is starting to get fragile.  Not everything is glued.
    Four posts in 2 days, I am not usually this talkative.
    Thanks Again
    MCB
  7. Yes Wefalck,
    I could not see any stays forward, only the bracket at the top.  There are other lines faintly visible in the photo above but I am reluctant to add them when I am not sure.
    For instance there appears to be a block at the top of the stack.  What could its purpose be?  Flag or anchor light?  We already have a mast for that I think.
    I may need to fatten those turnbuckles more.
    Thanks,
    MCB
  8. Hello again,
    The upper support bracket for the stack is unusual (see pic above) at least to me.  I was unable to find suitable brass stock at a few local hobby shops so I am trying to make do with 3/64th styrene tee (Plastruct).  I built a fixture to taper the ends and I thinned it down somewhat as well.
    The hoops were made with some flat brass wire.
    These will be mounted with brass wire pins and not permanently attached in case I can come up with something better.
    If these look to bad on the model I may simply use smaller flat styrene or brass and give up some of the 3 dimensional 'texture'.
    Thanks Again,
    MCB
  9. Hello Everyone,
    Thanks for the comment Brian and thanks everyone for the likes.
    I have been working on the stack for 'Isis'.
    On the first version of the stays for the stack I made some turnbuckles but they were grossly oversized (probably ~42") so I removed them and tried to represent them with blobs of paint.  I used fine Easy Line for the stay wires.
    I also hung the boat hook over the door.
    I will make another post to show how the top bracket support is working out.
    Thanks for looking,
    MCB
  10. Hello again everyone,
    Thanks Keith and Canute for the comments and everyone for the likes.
    There is a little bit of progress to report on the grain elevator.  I have added and rigged the ladders to the sides of the elevator.  I couldn't think of their purpose until I saw a picture of one leaning against a freighter that was being loaded, it should have been obvious to me.  I have also made up the flag pole (never saw a flag or lantern in any of my pics) but did not yet glue it in, as well as some other miscellaneous details.
    The last week I have been building the stack and vent for the relief valve in brass which in the pic are placed in position not glued.
    Remaining to do on the stack are turnbuckles and guy wires for the stack and the support bracket for the top of the stack.
    After the stack will be rigging the discharge tubes and the marine leg. Clean-up and then finished?
    The last pic included here should be a detail shot of the stack cropped from another William W. Barry jr. photo in the series as noted in the first post.
    It shows an odd lenticular sort of arrangement of structural steel joined at the ends with 2 hoops for spreaders.  Most or all of the other (few) pictures of 'Isis' and the other grain elevators I have show a simple set of 3 pipes or rods (p&s) which would have been easy.  But I said to myself when I started this that I would stick to these photos and a deal is a deal.
    Thanks for looking,
    MCB
  11. Hello again all. Thanks Roger and Canute for the comments and everyone for the likes.
    Three weeks and more seem to have gone by since my last update.  I must post some progress.
    A lot of the small detail parts have been added and of course some things that were good when dry fitted have had to be re-made.
    I have added ventilators, skylight, boat and whistle to the 'boat deck',  whistle, bell, awning and blocks for the ladders forward.
    One thing that I cannot see on these photos is a smoke jack for the galley stove which I assume to be in the rear of the engine house.  I will omit it for now.
    Remaining to do: Rigging the ladders, rigging the discharge chutes, aft bitt and flagpole, various deck litter (ropes , barrels, boat hook etc.), fabricate rooftop ventilator, (dreading this) rig the marine legs and lots of touch-up and adjustment.
    When I am finished with this project I will list the materials and commercial parts I used and perhaps some thoughts on my reasoning involved.
    I think it might be necessary to get a new camera so that I can get good images when this grain elevator is done. The pics I have been posting look the thing just rolled of the show room floor.
    Thanks,
    MCB
  12. Thanks Keith Aug and Canute.  And thanks all for the likes.
    Yes I am glad I got that issue of 'Transfer', thanks for the heads up Canute.  I do have Flagg's books with three color pics.
    They were barn red over a black hull in those pics and probably for most of their career.
    A small update:
    I now have the tower sheathed and some of the deckhouses on.
    The model is a little bit more heavily weathered than I usually like,  I am having difficulty touching up since I have no more of the Floquil paint in that color.
    The pics show the red paint brighter and the weathering a little more subdued than it actually is.
    Thanks Again,
    MCB
  13. Thanks Keith and Wefalck, thanks all for the likes.
    Those blocks are from Bluejacket. They are 'Iron stropped triple blocks F0384', they are white metal.
    They seem a good match to the photos.
    Making blocks myself is a little too much for me.
    The chutes and pipes in the tower are just so something might be seen through the openings.  In reality there was a lot more in there.
    Thanks again,
    MCB
  14. Hello everyone,
    It is again time for a small update.
    I have finished with the hull for the most part.  I added a hatch in the  deck at the bow, coal scuttles, water fills etc. in locations that are my best guess after looking at drawings and pics of other elevators.  I may add some cleats later, I think there were probably 4 at least.  The bitts and bollards should be close to their proper positions as I can see those in the photos of 'Isis'.
    I painted my representation of the top of the steam engine and plopped the rear deck house/engine room over it to look in the skylight at it--it is barely visible.  I am glad I looked otherwise I would still be making chairs and wrenches and calenders.... I am easily distracted.
    Before mounting the tower to the hull I installed the previously rigged triple blocks for the marine legs and 'parked' them on wire rods until I get to the stage where I can mount the marine legs.  I hope they don't come off or tangle too much,  I would be in a lot of trouble.  I don't know how you folks do it on this forum, the rigging you do is astounding.
    Since these photos I have put on the tower and started to sheath it.  From here it will mostly be assembling parts that are already made.
    Thanks for looking,
    MCB
  15. Hi,
    You are doing  a beautiful job here mbp521.
    Those 'pre-heaters' and 'auxiliary engine'  (or one might say heat exchangers and pump) seem analogous to the later feed water heater systems found on locomotives.
    This of course is to get the feed water temp as close as possible to the boiler temp using waste heat, minimizing steam pressure loss among other things.
    Keep up the nice work!
    mcb
  16. Hello Everyone,
    It is time for another update.
    Thanks to MSW member Canute for pointing me to another source (RMIG--'Transfer' #40 ) for information on these vessels.
    I found that by making my hull longer I am actually close to the correct length now.  I discovered a few details that I should probably add on as well.
    Also found that many of these floating elevators were not self propelled, some had barge like hull forms.
    And I got some confirmation that essentially no two of these things were alike or that one would retain its appearance for long.
    I am now near the stage of assembling the parts and sub assemblies.
    Here are various parts and the rebuilt marine legs.
    The last picture (if I can manage to get all the pics in order) shows a plastic structure protruding from the area of the engine room.  That piece is meant to support the stack which otherwise would be too heavy and vulnerable.
    Just behind the support for the stack is the top of the steam engine (in primer) which will be under the skylight.  For some reason I seem to put these details in where no one will ever see them.   I do this in model RRing as well .  Now I am starting to think of other things to go in there.  It must be one of the reasons I never get anything done.
    Thanks for looking,
    MCB
