Posts posted by Vladimir_Wairoa
congrats to planking Gary. nicely done.
very sad upon hearing. RIP Bob.
welcome to the bunch Brad . enjoy the journey.
Thank you folks for kind words and encouragements.
@ClipperFan Rich, exactly. I particularly chose this scale for this reason, to show other derailed aspects of ship, and nowadays there is possibility to to with astonishing details specially in rigging event with clippers due to better materiáls than in the past etc...
Therefore my rigging will be very light compared to Robs astonishing knowledge and miniature mastery, its not my strong side really so I will to very light on running rigging, showing no sails most likely to state cutty sark IS rigged today and event that will be enough of force fór me.
AS far as fuzzy lines thanks, but i believe i finally found simiarly usefull way with prvá glue mixed with water...i will show outcome...:)
Thanks much Grant, Im thriller by your works with machinery indeed. ...
Thanks you Alex.
There is no Massive update at this point, I last time returned to whats left to secure at deck. With recuperation traces and hole under catheads from Rising deck.
To update. I will use black lanyards fór deadeyes not light color. I realised IT only draws atention and its not true to tarred weathered lanyard anyway.
I still need filler to make those wedges under catheads. impossible to see....
Thank you.
As far As blackening. AS múch AS I hate painting and painting brass, I will never ever try to chemical blacken glued brass. Impossible of course...
I am reaching tweezers and magnifier territory of 1 mm chain eyes. This size IS new fór me though :))) Decisions decisions.
This IS Macro closeup magnified enormously. So. - asi far as Bowsprit rigging and so on, I believe im not bothering with trying to make any shackles od ridiculouspu amaller size just to suffer with no scale accuracy. Wired eye will IT be AS at the pics below
Here we go with circumference divided its 1 mm thickness for mizzen mast.There is slight fuzzines on served ropes, not sure how to eliminate it yet. Lines are not yet fastened indefinitely as i leave them to settle. Poly ropes are very stretchy compared to cotton. But amazing to work with. Mizzen mast is getting first beating.
Im glad i shifted rail inwards.so that lanyards Could follow straight line up.still toucjing rail a bit though.....
- BANYAN, berhard, Paul Le Wol and 2 others
- 5
10 hours ago, rwiederrich said:
I agree Rob. Thanks for honest opinion, your experience of rigging many of them pays off clearly. Im Also bothered visually that thickness of ropes IS inapropriate in respect of everything else.
Silly of me i only now realised that size or ropes IS in circumference not diameter. I have to divide IT by 3.14 to get diameter.
All will be different and all IS making múch more sense now.
Will i fór Once read that book carefully and not making fool of myself ?
Gosh, how stupid. V.
56 minutes ago, rwiederrich said:
Vlad, Glory's Shrouds/Backstays and Stays were all probably steel wire rope...so I'd use very dark or black rope. Her deadeye lanyards as well as her ratlines were oiled or tared to protect them from the weather.
White ratlines and lanyards is not a prototype practice, However, some later clippers and large iron ocean carriers painted their lower shrouds white...to protect the steel cable.
Many Thanks for clarifying Rob.
In Michaels book its written shrouds were hemp but maybe later wire was most likely used. I remember back from CS shrouds there IS considerable difference in thickness from wire vs hemp of same size. 11 " hemp us ridiculously thick hemp nôt being accepted by any deadeyes of reasonable size so I diminished those sensibly. I am about to use black ratlines though natural lanyard byť nôt white at all.
I will use black seizing than.
Will post prototypes. Thanks much for insight.
Rob, I hlave question to ask, heading slowly to mast rigging...Was shrouds and possibly All seizing of big ropes tarred meaning Dark or white AS per english CS fashion?
I suppose IT was black IS IT correct?
Im looking ať some glorys photos nôt clearly visible though in detail.
Thanks much
V.
30 minutes ago, rwiederrich said:
Yes...Vlad..6 pumps within the hold. These pumps removed water and debris and expelled it out hull drain ports that were found along her second deck level.
Look closely and you will see the exit ports on these images and the staining caused by the expelled fish fluids(Top picture), and water in the bottom picture. The only pump on deck was the large flywheel bilge pump.
Rob
Great documentation as always Rob. Appreciated indeed. V.
4 hours ago, rwiederrich said:
Vlad, you ump construction is wonderful.
However, I’ve found no evidence of the 6 smaller single pump type were on Glory of the Seas. No photographic evidence shows them. I’m assuming you are using artistic license here.
Rob
Thanks for correction Rob. Not pure artistic license hovewer I briefly read thru boston article 1869 upon which we are building this mammoth and its a bit confusingly written at first sight counting pump boxes together which amounts 6with miselading sentence "thus she has in all six pumps for the hold" ... my bad I didnt pay closer attention to it ...but no harm whatsoever. right, 1 wheeled and two standalone pumps of iron. Thanks again for correction.
Pumps.
There was 6 Small ones around entire Boat, Up and downdecks and oné large wheeled around main mast.
I found several pics about design of single handed ones around 1850 of Americas design, but AS We really dont have pics there IS at least little place for fantasy. Not
in measurements but in design and shape. Even strange world in modeling. Seems wood got definitely substituted by metal and fancy ornamentals followed rigour of i Guess Victorian era in England, fashion that dip Down into technical world As Well but im no expert of states history. I found few beautiful pics of bilge pumpa in web. Still not blackened. I am waiting fór birch cassey substance.....:)
Will follow later on. ...
..thanks. v.
6 hours ago, ClipperFan said:
Vladimir,
It's painful to read about your solder skin poisoning accident. I wish you a speedy recovery. Your miniature crane fashioning is impressive. Thanks for sharing.
Its few years now Rich, it healed but i need to be careful with agressivr glues as skin is nie extra sensitive.
Thanks for likes folks.
I Continued with Anchor release working mechanism. Im not expert in this field nor history buff or aspirating one I hope and believe this is the correct pattern from the era as per similar vessels of that tíme.
Design relies not on pulling the release bar which i suppose would be impossible fór mens muscles anyway to pull Iron upon which hangs on chains weight of some 6000 punds. Its working by turning bar on its own Axis, bar that ends IS shaped like half shaft hollowed at which top of rests opposite simple Iron bar that moves around its Axis as well. AS release Turns. Bar slips from its mesta and chain with Anchor drops freely ať the other end of bar there was aj eye i believe to secure its end when necessary somewhat ať the deck so noone would attempt to release IT accidentaly or fór weather conditions sake... I hope ili got IT right though.
Its still not secured and blackened as few more things. I also made Iron tip of skid to prevent wood from damage from lifeboats. With this done and anchors and boats secured I will be finished with last deck works and its a milestone long awaited as rigging journey can start aplenty.
Thanks for watching comments, remarks etc...
- ScottRC, Seventynet and Prowler901
- 3
Small update from todays rigging preparations. I continue with making Howes cranes on topmast caps. These needs to be 3 made, each for every lower topyard.
Since my solder skin poisoning axident I derailed from soldering at All trying different methods of joining cut and shaped brass mostly by wires thru holes..thanks much for watching etc...
- wefalck, Prowler901, BANYAN and 1 other
- 4
4 hours ago, gak1965 said:
Well, it's been 12 days since my last update. I wished I could say that I have made massive progress, but I think I will have to settle for some progress. At this point, all of the mainmast futtock shrouds are in place, and I've rigged (but not anchored the lanyards) of the lower and topmast shrouds and the main forestay (which terminates on the foremast fife rail). As with the fore, I'm going to get all the lines in place and then tighten/anchor from the skysail down. Here are two pics of the main and foremast as things are moving along.
One thing I am thinking about doing before starting the 'fun' of the ratlines is attaching the tackles (I think mostly halyards) that terminate on deck around each of the masts. The six tackles on the mizzen should still be relatively clear since there isn't a fife rail blocking access, but I'm guessing it's not going to get easier to access after the ratlines are in place.
Thanks again for looking in and have a Happy Thanksgiving!
George K.
very neat George. all ropes tight and nice around deadeyes. It must hqve been quite a work. its interesting aproach to rise all stays first. my plan is to step up together with yards meaning lower mast atraching yard than topmast etc.... will see how it goes quite nervous. Keep great progress. amazing. V.
Thanks for interest and comments Folks.
@Rich, sorry to hear unfortunate setback, those are regretful occurenes where little helps ať least maybe that no injury was involved thankfully. I hope for the best with compensations etc...
AS far as last updates i only observe what folks are doing mostly in rather mediocre fashion ...
To follow
@ Dolphin Strike revision etc ...
I continue detailing after underhill..spent enough tíme with brass to get me entertained. Im glad i dont follow only usual 1:96 plans as there IS rather simplified solution with using simple hooks etc. This IS magnifier work applied.
I though have one problm folks. I really have issue how to blacken already constructed brass on wood surface lie topmast tops etc.
m not sure painting would be satisfying fór me at least. But i dont know of something from chemická Arsenal to blacken it AS already attacjed to wood. If you have satisfying solution i would be thankfull.
Nôt fully moving to both Axis but sufficuently enough to one for our need. Some pics.
- berhard, Prowler901, Seventynet and 1 other
- 4
I continue with something else.
Rigging of lower yards.
Tried with served rope of scale thickness for entire length for stability of roofrope will see if to continue with this fashion.
I believe this way will be doable fór me Up until upper topyard not thinking od topgallant and higher up as of now. I follow underhill general view...
Fantastic build Ian. beyond beautiful.
- Seventynet, hollowneck and Keith Black
- 3
Oooh, what read. feeling like a kid getting christmass month earlier. thanks for teasing us Chuck. There IS something really enjoyable and relaxing for scratch modelers with laser cut model. I Remember how over the moon I was joining together winnie stem. Good luck.
- FrankWouts and mtaylor
- 2
Deck Finalized.
I managed to offset cladding on deck. I used sharp pencil fór IT and Rubber to clear out the lines. Finally put coat of clearance lacquer. That All. Its so dense on clipper that laying individual planks of that length would be nightmare fór sure.Thank you fór viewing etc...this IS result.
Im speechless Jason, of what can be done by hands. Hat off Sir, watching along V.
- Beef Wellington and AJohnson
- 2
14 hours ago, BANYAN said:
It still amazes me how those masts retained sufficient strength after having a sheave cut through them; your piccy illustrates just how little 'meat' was left to either side. You're making great progress Vlad, I am enjoying following along.
cheers
Pat
Thanks for comments Folks,
I turned wood into steel
Primitive approach but easy one and functional. Boxwood IS godsend in this respect. Painted black will do intended.
V.
- Prowler901 and gak1965
- 2
HMS Winchelsea 1764 by Rustyj - FINISHED - 1:48
in Member Build logs for the HMS Winchelsea
lovely updates Rusty.
