Rik Thistle
Everything posted by Rik Thistle
  1. Hi all, A few more picture and notes below, to later be followed with a final post of pics of the 'paint job' and thoughts. Below, the Eccentric Strap having it's 5/8" dia hole bored out. Towards the end of the build I came to realise that boring and then reaming a hole was probably overkill ....boring seemed good enough. Reaming was suitable for smaller holes that my 8mm square section boring bar wouldn't fit in. Even then I do have an old 1/8" dia hand made boring bar from back in the day, so I could probably bore out quite small holes with it. I'm saying it is the Strap being machined on the lathe below, but it might be the Conrod....it's moving too fast to be sure, but my money is on it being the Strap. Back to the mill with the Eccentric Strap to drill a 7BA clearance hole through on one side. The Strap is then cut on that side (using a Dremel cutter that happened to fit the mill's 3mm collet). The 7BA screw can then 'close' the hole around the Eccentric Sheave that revolves in the hole till it is a nice sliding/rotating fit. Seen above is the miniature Faithful set square that I bought shortly after getting the mill. As it turned out this was an excellent purchase and has become one of my favourite multi-purpose tools. It's quite well made nestling accurately into my larger Moore & Wright set square. Below, tapping one of many holes in the engine. using my trusty Eclipse No 245 tap wrench (1/8"-1/4", 3mm-6mm). This is the best tap wrench I have ever used since the dimples on the end encourage finger tip gripping only and the flat shape aids visual horizontal alignment. I also owned it's little brother, the No 244 but it disappeared years ago....however....it miraculously turned up at a friend's house the other day....so I'm very happy about that 😉 However I was saddened to see it described on eBay as 'Vintage'...gulp. Below - Starting to finally fit parts together , checking alignment etc. I lost count of the number of times I fitted/removed the fixing screws and nuts. I ended up buying a set of BA box spanners to speed that up and to complement my BA spanner set. Finally, test fitting the gaskets and adjusting the valve setting. Towards the bottom of the picture is the oft mentioned but never spotted Eccentric Sheave (circular, silver coloured part) which is locked by grub screw on to the Crankshaft. The Sheave's purpose is to drive the valve up and down as the Crankshaft rotates and in synchronisation with the piston movement. I've tested the finished engine using a power hand drill clamped on to the Crankshaft - it seemed to work fine. But really, it should be the piston powering the crankshaft - not the other way around. I'd like to at least 'properly' test the engine with compressed air which leads me to thinking about purchasing a model airbrush + compressor + tank for painting, with the compressor + tank part also being suitable to drive the steam engine. I did some rough calcs the other week about air flow rates -v- engine consumption etc but if anyone has any thoughts/advice/experience on a suitable UK item please feel free to fire away. Catch you soon, Richard Edit: Air compressor now ordered, so a more life like test will be possible. And the compressor will one day drive an airbrush also 😉
  2. Mark, The grooves are actually flush and even running my finger over them can't tell they are there. I'm quite happy to leave them there as they add a bit of 'character', or so I'm telling mself. And yes, the wheel has had P1000 Emery run over it. My lathe doesn't have Compound or Cross slide power feeds, sadly. Well, it does have a lead screw that I can engage but I don't trust the slop in it at the moment. Also, the slop in the saddle was ridiculous when I first got the lathe so I fitted a lock and that really tightened things up. Bangs for bucks the lathe is very good but it's still at the low end of the market. But for my purposes I'm very happy with it. Richard
  3. Thanks Roger, I suspect that if you can machine small brass parts then you can pick up general workshop practice pretty quickly. Shadowing someone (an Elmer with a home workshop?) for a few weeks whilst they use their workshop tools is a great learning method. Then they can start gently letting you have a go on the various tools. And I'm sure you know this, but ALWAYS wear safety glasses, and avoid having any dangly clothing that can get caught up in things. With new machines I do a good 5 mins of dry rehearsals using the Emergency Stop buttons, to train memory muscle. Sorry, if I sound like 'teacher' 😉 Richard
  4. Hello again, Some more snippets from my Stuart 10V build follow. As I mentioned earlier, the build order may seem it is a bit haphazard but was influenced by such things as turning all the 10mm dia parts in the lathe's 10 mm collet since that was already set up, leaving a part half finished whilst I awaited the delivery of a tool (eg (3/4" reamer), having to go back to an earlier part since I had not appreciated how well it needed to fit a later part etc etc. First, facing off the Standard's top surface in the 3 jaw chuck. I used the same Ikea 'mandrel' from earlier, this time showing the anti-rotation peg/screw I had fitted. Below - I then mounted the Standard on the Faceplate to bore out the 5/8" dia hole. That went quite well and resulted in a smooth enough finish. There was a little spring on the boring bar but repeated in-outs at the same setting shaved off a few tenths of a thou" each time. Just to make it super smooth and to size all the way down the bore I used a 5/8" reamer driven by hand power - that worked fine. On to the cast Crankshaft Bearings, which arrived as one piece to be later cut in two. The top surface of the casting was filed smooth as much as I dared since there was little extra material on that face. The Sole Plate 'U' channel was also hand filed out to accept the bearing. After cleaning up the bearing surfaces with a file and cutting it in to two pieces (one bearing each side) I had read that the bearing would actually fit centrally in a 3 jaw chuck with a little bit of packing, which it did. The hole for the Crankshaft was then roughed out and circular bosses added. Below- Next was to clamp the two bearings in the Sole Plate and pass a 9/32" reamer though. At that time I hadn't appreciated the underside of the bearings that sat on the Sole Plate mounting faces should have been machined flat (and together) rather than gently hand filed. Centre pops marked what bearing went on what side of the Sole Plate. As mentioned, the undersides of the bearing should have been machined flat....the toolmaker's clamp highlights how out of line they actually are ...it's actually quite subtle, but when it came to tighteneing up the nuts on the bearings, the Crankshaft went from free running to locking up with the last half turn or the fourth nut...darn! I later machined the offending faces. The Crankshaft assembly was fabricated from two 9/32" rods, two Crankwebs and a Crankpin. This was a sligtly tricky process but turned out OK - all parts were pinned and Loctited together. Earlier Stuart kits supplied the Crankshaft as a one piece casting. Below are the two Crankwebs (for the Crankshaft) being drilled out to size to accept the rods. I had to use my bench drill since it had a deeper reach and could take the large drill. The micro mill only goes up to 3mm dia. Yes, a larger mill is on the 5yr wishlist. Below- marking out the Conrod. Brass is a lovely material to work with but it doesn't half produce tiny little spears that home in on my finger tips. The Conrod connects the Piston Rod/Crosshead and the Crankshaft at the lower half of the engine.. Above - the hole centres need to be reasonably accurate, but there is adjustment in other parts that can compensate for a 0.5mm error, say. Sorry about switching back and forth between Metric and Imperial ....that's how I was trained and I can generally keep track on these values in my head. Below- The Eccentric Strap, which works the Slide Valve assembly, which in turn allows steam to enter the Cylinder. I think the pic shows me fixing a mistake....I had centre popped the hole for the Eccentric Sheave hole, cut the Strap end in half and then realised the centre was in the wrong place. So I'm about to face off extra material to bring things back in line. Below - The Bottom part of the Sheave that was sawn off...it will be faced, clamped to it's mating half and then two fixing holes drilled in both to hold the two halves together whilst the 5/8" dia Eccentric Sheave hole is drilled/reamed. Below - the Cylinder's bottom end cover being drilled on the MF70s Dividing Head....that worked fine. And now using that Cover as a template to spot the fixing holes through on to the cylinder. My small toolmaker's clamps hadn't yet arrived so I improvised 😉 The Cylinder is peppered with drilled holes. Here we are drilling through at an angle from the cylinder chamber (on both ends) to one of the three apertures on the cylinder Valve Chest face. The little vice was more than strong enough to hold the Cylinder in place during this operation, thankfully. And... a Cylinder with a Coke bottle cap finish at one end of it's 3/4" bore. This was the result of not leaving well enough alone. I had bored the hole out to a good finish, but it was time for another reamer (3/4") delivery so I used it, badly. It's not pretty but lets just say the lighting make it look waorse than it really is and leave it at that...cough. Below - Starting to see the home straight now. Here is the flywheel being turned to almost finished dimesions on the 4 jaw. Once the centre was drilled out it was fitted on a mandrel and finish machined. I had read that the dominant visual feature of a flywheel when it is rotating is usually the part you can't machine ie the inside of the cast rim....hence the 4 jaw for centering on that feature. I did file the inside rim reasonably smooth but not to a turned quality. Below- It's starting to look a bit more like a vertical steam engine. Still loads of fixing holes to be drilled and tapped though. Above - Interesting to note the narrow bands on the Flywheel perimeter....I think this is due to the lathe's Compound slide lead screw having a slight bend in it....each of the bands is 1mm apart which matches how far one complete rotation on the Compound slide's handle moves the tool point. This was another reason for building the Stuart 10V ...to unearth any lathe/mill parts that weren't quite right and needed fixing. Below - The Valve Chest, the brains of the operation. The little hollowed-out brass cube slides up and down over the three openings on the Cylinder only ever connecting two openings at once. More thoughts on the above may come to me over the following days/months so I will tweak the posts as necessary. I think that's it for today then. Hopefully tomorrow I'll be able to show the finished engine. Richard
  5. Mark, I can only be inspired. The skills and abilities of these folks are to be admired....eg If only non-technical folks understood what is needed to produce those works of art the world might be a better place. That's not to say other disciplines lack merit, but I do feel that there has been a trend over the last 30 - 40 yrs to push younger folks towards the less hands-on careers. Anyway, I'll have a good read through that link over the weekend, thanks. Richard
  6. Hi all, A short post to start the day with, focusing on three of the main castings. Below, L>R, - the Standard, which is the structural link between the reciprocating stuff (the piston) and the rotating stuff (the crankshaft), - the Sole Plate, which fixes the relative positions of the Standard and the Crankshaft - and the Box Bed, which is attached to the ground, and adds stability and strength to the structures above it. It may have other functions (vibration dampening?) that I'm not yet aware of - I'm thinking real world scenario. From the above.... - the Standard has been cleaned up by eye on the sanding belt to add approximate squareness and also to remove some of the hard casting surface layer. - The Sole Plate has had it's top and bottom surfaces machined to size on the lathe using the 4 jaw chuck. The hard casting surface is nicely highlighted (the shiny perimeters) on the Sole Plate...in places it is up to 1 mm deep. I had started off by using HSS cutting tools but quickly switched to carbide tipped tooling to cope with the hard layer. The Plate also features cast-in dimples to indicate where fixing holes should be drilled. The positional accuracy of those dimples should generally be taken with a pinch of salt! - The Box Bed had it's top and bottom surfaces (and mounting lugs) milled flat using the tiny MF70. I was keen to experiment with different finishing methods (lathe, mill, filing etc) to get experience and see what worked best. The milling was quite a long process taking tiny cuts at a time...probably the hardest part being winding the table back and forth. I also drilled and tapped 7BA holes in the top surface along with 'I forget' sized holes on the mountimg lugs. Below, the Standard (unmachined but sanded) being visually checked on the Sole Plate and Box Bed. The circular hole running through the Standard is important in that it needs to be aligned correcly with the components it interfaces with...more in later posts. Below, the Standard being held in the lathe courtesy of an Aluminium tube running down it's (roughly cleaned up) bore. The tube was from a piece of old, dismantled Ikea furniture (lamp stand?) which was stored in the 'that might come in handy one day' bin....well it did 😉 Luckily the tube had a threaded end and matching countersunk screw which forced the Standard against the jaw surface. IIRC, I also added a peg to the tube to stop the Standard rotating under cutting loads. Above, the Standard's two feet cleaned up nicely. As I was making the 10V engine I was only occassionally taking pictures mostly for my own reference rather than for a Build Log. But with 20:20 hindsight I may have taken just enough pics to form some kind of haphazard log. So apologies now, if I tend to jump back and forth between items as I post. This was meant to be a very short first post for today, followed by a longer post (ie more pics) later today. I'll see how I feel 😉 All the best, Richard
  7. Bob, Thanks for the info; I'll have a good read Yes, there seems to be a thriving market for quality steam models. Keith Appleton not only makes and sells his own superb models but (I think) acts as an agent for other modellers ... 'SOME SUPERB MODEL STEAM PLANTS - NOW SOLD' - https://www.youtube.com/watch?v=Najs8o412Oo&t=348s Even Bonhams are in on the act .... https://www.bonhams.com/auctions/25163/lot/310/ I doubt if any of the modellers are in it to make money, but rather for the sheer pleasure of building and operating the equipment, and of course, learning. In addition to Keith Appleton, a couple of my favourtie YT sources are Andrew Whale and Tinker John Both explain clearly what they are doing, the mistakes they make and the equipment they use. I'll mention others as I go along. So far, I've spent (too) many hours watching YT builders and reading websites. I suspect my small but growing 'model ship building library' will soon have some new companions from the 'steam model' world eg Where the Rails Meet the Sea which I saw mentioned on a different thread in this forum the other day. I'll try to post some more pics of my build later today. Richard
  8. Funny you should say that Bob .... https://www.mainsteam.co.uk/mainsteammodels-gallery 😉 I've spent quite a bit of time reading through Keith (Appleton) website, and there are many glorious examples of what can be done with steam engines. I find it a fascinating subject. Richard
  9. Hello all, In June 2021 I bought Stuart Models 10V steam engine castings set.... https://www.stuartmodels.com/item/39/stuart-10v-unmachined Plan being to get me more outdoors ie in the shed with the door open enjoying the great summer and nature flying and buzzing all around. The build took about 12 weeks using a Sieg SC2 lathe, Proxxon MF70 Micro Mill, bench grinder/sander, bench drill, hand tools .... and a calculator. It's many decades since I did 'metal work' professionally but after a few weeks a lot of it 'came back to me'. So did making mistakes and then figuring out to remedy them ;-). This was a totally fun project. I have since bought the Stuart 'Reversing Gear' kit of castings, what with this being a 'ship' website and steam engines on boats/ships needing a reverse gear. And that will be next summer's project. Also, there is the tiny seed of an idea in my head that one day I'll add a boiler, build a waterproof model boat, fit servos etc ....add the lot together and go RC sailing...but that's in the future, maybe. Anyway the Stuart box arrived in late June.... A simple but sturdy cardboard box, with the metal contents held in place with a strong, transparent sticky covering....they weren't going anywhere! The 'paperwork' is a single large sheet with the parts' detail drawings on one side, a Parts List, Exploded View and very basic instructions on the other side. It could be argued that the drawings did kinda dimension all aspects of the parts that needed machining, but it was prudent to study those drawings closely and also consult other sources. An inventory check showed everything was present..... One of the 'other information sources' is shown above - the booklet by Andrew Smith. It has gone through a number of revisions and gone as far as converting BA thread sizes, dimensions etc into Metric... hmm. Below a first look at four of the main castings...clockwise from top left, Sole Plate, Cylinder, Standard and Flywheel. Castings sometimes have a very hard outer surface (due to cooling) that makes machining difficult. So I proceeded to skim as much as that hard surface off as allowable, using files and a sanding belt. Note: I say 'allowable' since some of the casting surfaces were right up against the borderline regarding what the finished size would be. Above, a slightly blurry pic of the Box Bed having it's top and bottom surfaces machined flat and parallel, and square to the rest of the item. (Edit: It looks like I was actually drilling out the mounting lugs rather than milling flat the top and bottom surfaces....that milling had been done earlier) The mill above really is 'micro', with the largest diameter cutter being 3 mm. However going slowly and taking no more than 0.25mm (10 thou) cuts max, a reasonable result is achievable. I had spent some time fettling the mill on arrival eg adjusting the gibs, adding ball thrust bearings in the Z axis and a Z axis digital readout. So it all worked fine...for a while (...blunt tooling tended to 'grab' quite easily). Below, centre drilling the two main fixing holes. I later bought stubb drills which were the proper tool for that job and have a slightly longer reach (I think the stubb drills might be shown in the pic above). OK, that's it for today. I'll post more over the next few days. Spoiler alert. I have already finished the engine and successfully 'run' it using an electric drill attached to the crankshaft. Which is putting the cart before the horse, since the power is meant to come from the steam in the cylinder, which in turn drives the flywheel (attached to the crankshaft). But building a boiler, or even sourcing compressed air is for a later day. Catch you soon , Richard PS: I really do plan to now get back working on HMS Flirt.
  10. Popeye, A great read, and also the 'plastic model kit' history link to John Loughman. As a kid I lost count of the number of aircraft windscreens I messed up with the kit glue. Not the glue's fault...just my ham fistedness 😉 Richard
  11. GranpaPhil and Glenn, Thanks for the comments. Dallas sits about 4' above and to the right of my shoulder looking down on me...as does Lady Eleanor. Both are keeping an eye on me I feel 😉 I've been side-tracked with a model steam engine build during the great summer we've had in Scotland and therefore have spent many days (and evenings) in my shed/workshop. The model steam engine is a generic version of the kind used in early steamers so there is a maritime connection. As usual it's the 'oh, that looks a quick and easy part to make' parts that turn out the opposite. But I hope to get back on Flirt soon'ish since the nights here are starting to draw in. Richard
  12. Lots of very good creative detail there Ras. She's going to be a feast for the eyes, as well as the hungry mouths waiting back on the mainland. Richard
  13. I felt the tension in this video .... 'Ship in a bottle foremast placement' - I don't know anything about 'ship's in bottles' but this seems to be quite a challenging hobby. I wish the builder had a lot more videos on 'how to' on his YT channel. But there will be others. Anyway, off to do a bit of learning on the hobby. It's above my pay grade but quite fascinating. Richard
  14. Erik, I think that because Tom is such a likeable character and knowledgable presenter it all helps make his content that bit special. As for having to go to sea in a Fifie (or similar) in bad weather to survive, well it sends a shiver down my spine. But needs must. Richard
  15. B.E., "...great value to the modeller. It informs both scale and use of the many fittings, as well as being of general interest." It certainly does. I now have a much better appreciation of the full sized Reaper and the models based on it. Also, I'm slowly working my way through the other 6 episodes ....'Episode 2 - Pts 1 & 2 Phoenix' explains square riggers in a very practical fashion ... I'm learning so much. Richard
  16. Hand, Reef and Steer by Tom Cunliffe Being relatively new to model boat and ship building I'm only now realising that Tom Cunliffe has made such a great contribution to sailing. Here he is, in 2010, with the first episode of 6 on the 'Boats that built Britain' series, The Reaper .... Richard
  17. I just had an image flash through my brain of the four Vanguard fishing vessels, all in approximately the same paint scheme., lined up on my sideboard....it was a very pleasing image ...oh, oh. 😉 Richard
  18. Glenn, Those pics are hitting the spot! Well done. And these days with so many pixels to play with, cropping can be a reliable assistant. Richard
  19. Glenn, I am going to experiment with using the Canon's .... Like most things worth doing it takes a fair bit of effort to become competent, so you are doing the right thing in exploring the camera funtions and getting hands-on usage. And there's lots of websites and YT posters and folks on here that help provide all the know how we'd ever need. I'm far from competent but know enough to at least know when I'm getting a poor result 😉 And from that I learn. When cameras were analogue the 'menu system' was pretty much common across all brands of camera makers ie once you learned what the the knobs and buttons did on one brand you could use another brand with minimal learning curve. But now we have touch screens and software menus, sometime with useful functions hidden way down in a sub-menu....grrr, and that's all compounded in difficulty by each manufacturer using their own software menu systems....it's one of the tricks they use to lock you in to the brand. From what I understand modern Canon cameras have the best interfaces, followed maybe by Nikon and with Sony at the bottom of the pile. But all menus are learn'able ...it just takes time. Richard
  20. Glenn (UK), Yes, all as Glenn says .... and you've noted using the matt side of the backdrop will help prevent reflections. And I think you've already got the diffusers fitted to the LEDs to spread out the light a bit more gently. Also have one or two white reflector boards (roughly 10" / 250mm square - anything white will do eg Polystyrene packing) at hand to bounce the light from the LEDs onto the parts of the ship that are too dark or need extra highlighting. Here's a clip from one of my favourite YouTubers getting involved in lifting a heavy light to help illuminate the set on a Commercial shoot.... https://www.youtube.com/watch?v=Hwzlk-0SQDU Note the numerous LED panels and reflectors, all there to totally control the lighting...natural sunlight is great but it works to it's own schedule 😉 Richard
  21. Laggard, I've tried most methods of plank bending including the 'soldering iron' version you mention. So far, it's my go-to solution.... it's compact, can do bends in two ot three planes with a bit of practice and luck. I sprinkle water on the wood and the proforma (to improve heat transfer) before putting the hot iron to the wood. A drawback is that it doesn't have an auto-time off feature, or warning light that it is On. So one needs to keep skin etc clear of the hot tip till it is cool, and to remember to switch it off when not in use. Richard
  22. Derek, What a build...so much to take in and to such a sky-high standard! Richard
  23. Glenn, Your finished HM Cutter Alert looks great - very well done 🙂 And thanks for all the detailed pics and explanations which will come in very useful for me. Richard
  24. I'd love to ride in Scotland someday. I'd love to ride California one day 😉 . I've always bought Trek or Marin bikes so Marin County is also on the list, but I think my travelling days are over. One of my favourite Scottish road + scenery circuits was to set off from Aberfoyle with a group of friends and do a circuit around Loch Katrine. It's Rob Roy country so very picturesque with quiet, small roads, tiny villages and hamlets with mountains on one side and Loch Katrine (with the Sir Walter Scott steamship) on the other side. Having been to quite a few countries on business and holiday I think I'd probably pick Lake Louise are a choice cycling destination. Skiied there but never cycled. Anyway, take it easy with the cycling for now and just enjoy the fresh air. Richard
  25. Man, the pavement is unforgiving! My left knee, hip pointer, wrist, elbow and shoulder plus road rash have all healed up but my left rib cage is still very sore. My head actually bounced on the pavement. Ouch! I hope the rib cage eases up soon. It's probably bruised cartilage between the ribs, not that I'm an MD. I find it shocking that a lot of cyclists don't wear safety helmets ... a typical excuse is... "it messes up my hair". I have a (gory) response to that which makes them reconsider their position. My mountain biking days are behind me now, but I still try to get out on the country roads as often as the Scottish weather will allow. Richard
