Everything posted by AnobiumPunctatum
Chuck, yes that's exactly what I am missing. This part makes me in the moment some problems during the reconstruction of the Alert. Do you have some otehr pictures of this cutter model which you can share?
- 1,051 replies
- cheerful
- Syren Ship Model Company
Chuck, I've a question to your planking. If I look at the planking sheme of your cutter, I found a vertical triangle under the counter. As far as I understand will the planks end before that. You've also drawn this but you did not use this in the praxis. Is there a special reason or is it a simplification? Your planking looks really brilliant.
- 1,051 replies
- cheerful
Lee, last year as I started with the project, I had the same idea. But I had problems to match the dimensions he has given in the first part of the book with the drawings. At this point I started to use a simplified frame model. Then I started my build but was not happy. His line drawing differs from the original drawing which you can find on the NMM Homepage. And I couldn't find the reasons. In September I bought the original drawing and started again ... the rest of the story you know. Meanwhile it makes a lot of fun to search and compare the different original drawings. I think I will do the same steps on the next models I like to build also. There is also nothing wrong with your approach. I will follow your log with great interest.
It's time to show a short update of the frameing. The frames and the fore cant frames are finished. In the moment I work on the after cants. There I have a big problem, because I don't understand how the construction really works. All drawings I found do not show any details. Is it right, that the fashion piece has the same angle as the last cant frame? Perhaps someone can help me out, to understand this detail right.
Mobbsie, now it's clear, but I don't have any idea why the author of the drawings choose this solution. It is in my knowledge not common. I've had a short look at the prototype build of Mike at MSB, but could not find a picture of this area. I would suggest to build frame 12 and check if it is on top of the rabbet ot your model.
- 255 replies
- granado
- bomb ketch
Wow, your model becomes nicer and nicer. I like your precise work very much.
- 3,618 replies
- young america
- clipper
Mobbsie, thanks for your explanation. But I can't follow you. If I have a look at the original drawing at the NMM (see here) the rabbet doesn't have a curved line. You're sure that you do not misinterpret a line on your drawing?
- 255 replies
- granado
- bomb ketch
Mobbsie, the curve of your keel rabbet confuses me. I thought that it is nearly a straight line midships. Your frame is looking nice.
- 255 replies
- granado
- bomb ketch
