Everything posted by AnobiumPunctatum
Very accurate planking job. I like it very much.
- 452 replies
- cheerful
- Syren Ship Model Company
Thanks druxey and Jan. @Jan This would a nice idea, but we don't have the possibility to place the half model on the wall. We live in attic floor apartement
- 102 replies
Ben it looks that the port is a little big and so the frames on the counter timber are a little bit small. If you plank the upper part of your hull I wouldn't change anything.
- 889 replies
This is the current stand of my reconstruction. As you see on the pictures I've need some putty after sanding. This has two reasons. I've sanded to much on frame 20 The lines for the transoms have some smaller mistakes. During the last month I've redrwan the transoms. Also I've corrected a small mistake of the maximum breath in this area. In the moment I add the counter timbers to my drawing and complete the half model to check the revised design.
- 102 replies
The transoms can not be derived directly from my reconstruction of the body plan.In the half breath plan of the orioginal drawing the form of each timber is indeed located, but does not fit properly on the corrected design. Before starting for the next step I have taken these lines and adjust them so that they match up with my design and also with the position of transoms in Sheer plan. Subsequently the transoms were transferred to 3mm plywood, sawn and glued on the control model. I 've filles the gaps as usual with poplar plywood. After sanding the area looks like in the following pictures:
- 102 replies
Thanks Johann, druxey, Mike and Nils for your nice comments and all others for the Likes Next I've installed all bulkheads until frame 20 and the filling pieces. Then my favourite pastime - sanding
- 102 replies
Then I've started sanding the hull. I've used 60 grid until 120 grid sandpaper for the process. After around one week - I can only work on my model in the evening or at the weekends- I've finished the front half of my control model. I am very happy with the result To check the curves I use 1mm thick stripes of maple. The found differences are very small. So I think that my reconstruction will work for the checked range.
- 102 replies
With the build of my control model I started at the end of March. The edges of all frames I've colored black. This will be later a great help by sandig the hull. The glued surface of the cant frames is very small, so I've glued first plywood stripes on the center board. To get the correct alignment the colored 5' marks on the frames and the center board are a great help. First half of frame 0 Six frames have been installed. At this time I've started to glue the filling pieces of polar plywood between the frames. I've used a chess board pattern to avoid the distortion of the frames. Until the mid of April I've installed all frames and filling pieces from the center to the stem on the stem. The next two pictures show the result of the work. It's looking very horrible
- 102 replies
Danny, your anchors are looking very beautyful. In my opinion this was not a good choice, because you did not stain anything else on your beautyful model as I remember right. If box was to light, why didn't you use some of your pear for the fluke? But you are the master of your shipyard. So it's your decision.
To check the lines I started to build a half model. For the frames I use 3mm birch plywood, it's for a model in 1/32 perhaps a little small, but I've had a bigger batch at home. All space between the frames I fill with poplar plywood. It's easy to shape but stable enough for the purpose. I glue the drawngs with rubber cement on the ply woord With a sharp knife I mark every 5' line. The picture shows frame 0: All bulkheades and the center are cutted out. The hull has a length of around 1m, which is not as big compared with the new 1/200 model kits of the WWII battle ships.
- 102 replies
Part 1 Reconstruction of the hull lines David Antscherl wrote in his wonderful series about th Swan Class Sloop, that there are a lot of smaller differences between the ships of the class, for example the knee of the head of Fly. As first decision for my new start I decided not to use the general lines, which David has published. I want to do my own reconstruction. The naval cutter was a first exercise for this project. In January I started with the reconstruction. At the end of February I had a first version of my body plan, which matchs the lines of the historical drawing very well.
- 102 replies
Docmuents (I will update the list during my build): NMM drawings: ZAZ4667: Line & inboard profile, decoration of 'Fly' ZAZ4669: Lower & Platform Decks of 'Fly' ZAZ4670: Quarter and Upper deck plan of 'Fly ZAZ4691: Disposition of Frames of 'Cygnet' Books: David Antscherl, "The Fully Framed Model, HMN Swan Class Sloops 1767-1780", Volume 1 - 4 David Antscherl, "Swan class sheer and profile, scale 1:48", corrected frames Allan Yedlinsky: Scantlings of Royal Navy ships David White: Understanding ship draughts David Antscherl: Understanding Eighten-Century Admirality drafts
- 102 replies
The Swan Class Sloop and I have as some of you know a longer history. Two years ago I started my build log for the build in 1/48. A few month later I had to stop the build because I got some problems with my eyes. At the beginning of this year I started again. I decided to change the scale of my build to 1/32. I hope that some of you are intersted in my build and like to follow my log. So let's start again
- 102 replies
ancre La Salamandre by tadheus - 1:24
AnobiumPunctatum replied to tadheus's topic in - Build logs for subjects built 1751 - 1800
Paul, it's allways a pleasure to follow your log. -
THE 74-GUN SHIP by Jeronimo
AnobiumPunctatum replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
Moin Karl, I wish you luck with your new project and will follow your build with great interest. Are the new frameing set of Ancre the money worth?- 194 replies
Very interesting construction method. If you paint the outside of the frames black before you glue in the filler pieces, you will have a very good reference line for shapeing the hull.
- 191 replies
- young america
- clipper
