Posts posted by BANYAN
A great (and nice looking) little project Steven, enjoyed the catch-up on your log. If doing multiples 3D printing some of the items such as the chairs, gates etc may help and be a lot cheaper/easier when considering the time you would spend if making them? then again if just providing the stock the cost would not be a concern but may put some budding modellers off?
A great idea and what a great way to preserve some local history, I doff my hat.
cheers
Pat
Love the colour of those planks Keith. The planks are sitting really nicely.
cheers
Pat
- Keith Black, FriedClams, KeithAug and 1 other
- 4
This will be one very finely lined model Keith; your preparation, as with your work, is simply outstanding.
cheers
Pat
- KeithAug, FriedClams, Keith Black and 1 other
- 4
There I go and not pay close attention to the forum and you sneak another wonderful build under my nose - how dare you! I don't know how I missed the log. At least it gave me some interesting reading when I found it today (only a month late but I'll put that down to encroaching 'old fella' symptoms). Great to see that you were able to satisfy all those 'stalkers and their penguins' in this build log .
Again you impress with your dioramas providing a very interesting setting and nicely presented SIB. You should create a 'coffee table' style book of your work mate, it will hold up to any scrutiny.
cheers
Pat
- FriedClams, Canute, Glen McGuire and 6 others
- 8
- 1
Hi Bob, agree your reasoning WRT using such coils. These coils may have been a bit more commonly used than perhaps thought. Further to Bob's comments, even in this day and age (well when I was in the service at least) where synthetic cordage is commonly used (and more prone to the effects of UV), these decorative coils were in common use for rope whenever the ship was in harbour/at the buoy or at anchor. When underway 'proper' working coils were always used. These coils are also evident in images of HMCSS Victoria (1855). It appears this may have been the general practice in RN ships (or military type ships) back then also, as can be seen in the following photograph (c.1858) of the gun tackle working parts being cheesed (or more correctly - Flemish coiled). The vessel was in harbour (moored) at the time.
On 4/28/2024 at 3:08 PM, Bob Cleek said:This requires that the working end of the line is pulled from the center of the coil.
However, I must offer a point of difference in opinion WRT to how they were unwound. When reforming the coils, or taking the coil in hand, we would 'unwind' it from out to in by grasping the rope/line near the block or securing device, then walking the line out. This was the opposite to the way it was made up, which minimised the risk or tendency of the rope to kink, and allowed the rope to unwind with its lay. That said, other Services/ships may have done it differently.
cheers
Pat
- Bob Cleek, mtaylor, Scottish Guy and 2 others
- 5
Hi Vossey,
I will try to describe the technique I use for 'cheesing' the tail ends of tackles. Not my original idea, but it works well for me. First soak your rope/thread, cut to an appropriate size (if doing separate) in a diluted solution of PVS/water ( I use about a 60 water/40 PVA). If using the actual tail end of the tackle, this still works but just soak the required length of the tail (working end of the falls)
I use two small squares (or round) of clear plastic (from shirt boxes or the like). I punch a pin (usually a tack with raised plastic head) through both (See Photo). Separate the two leaving the upper plastic square/round on the pin, and put the outer/tail end of the rope/thread through the centre hole of the bottom square with about 1 to 2mm protruding to the bottom side. Put the pin back into this such that it holds the end and makes a sandwich with the thread between both plastic squares. Now rotate either the assembly or wind the thread around the centre pin to start making a flat cheesed coil to the desired diameter. Allow the finished coil to dry before removing; the plastic does not let them stick too much but still take some care when separating the coil from the plastic. These 'jigs' are so easy and cheap to make you can dispose and remake as required, especially when the centre holes become too large from wear/use.
Just one way to do it.
cheers
Pat
What a great result Eberhard; thanks for stepping us through the process. It looks very effective/realistic, especially at that scale.
cheers
Pat
A stunning build Richard; an exemplar of how to build such a model. I have very much enjoyed this build log so far.
cheers
Pat
You continue to show us just what is possible with your metal smithing Keith; impressive results.
cheers
Pat
On 4/11/2024 at 9:12 PM, Gregory said:
Apparently there was variation, so you should feel good about how you choose to go forward.
Agree, the following is from Capt. Boxer's (RN) 'Diagrams of Guns' (1853) which still shows the use of bending the breeching rope to rings in the mid-19th century.
cheers
Pat
Great to see this update Jason; your build continues to impress.
cheers
Pat
- Beef Wellington and mtaylor
- 1
- 1
Impressive finish Richard; looks great.
cheers
Pat
- Glen McGuire, Keith Black and mtaylor
- 3
23 hours ago, Ian_Grant said:
I was thinking decal or label paper if I could buy small quantity of sheets.
Hi Ian, I cannot recall where now, but I managed to buy just a few sheets from an online supplier. If I find some time, I will dive into my records to see if I can find the supplier - but I am not hopeful.
cheers
Pat
- Glen McGuire, mtaylor and Keith Black
- 3
Ian would not a self-made decal work to maintain the uniformity of the eyes. The decals, once applied, can be sealed with a spray-on or brushed varnish /clear coat for protection. I have had success printing my own decals for small toys etc that I make for the grandkids. The decal paper is relatively cheap and readily available online. I printed mine using a laser jet printer, but I think there are decal papers for other types of printers also. That said, hand painted adds a sense of realism.
cheers
Pat
- mtaylor, Ian_Grant, Keith Black and 1 other
- 4
Incredible detail at that scale, and well painted I may add.
cheers
Pat
- mtaylor, Old Collingwood, Canute and 1 other
- 4
Hi folks, does anyone know if Donna has returned to the business yet? I have tried contacting her several times (two different email addresses) but have not heard anything back. Grieving can take a while to come to grips with, and I fully understand if she has decided not to return yet - simply asking. I do not wish to pester her with emails until she is comfortable.
cheers
Pat
- thibaultron, mtaylor, Canute and 1 other
- 4
Eberhard, I think a lot of this can be deduced from the various issues of the 'rules' from Trinity house.
cheers
Pat
Folks, there may be a bit of a mix of terminology being used here? If not, apologies in advance. As most of you know I am researching the rigging for HMCSS Victoria (1855) which may help shed some light on the question.
Victoria's Specification, and her Rigging Warrant, both mention wire rope vertical jackstays (separate to the shrouds). As far as I can establish, the vertical jackstays (also sometimes referred to as horses I think) were (in Victoria at least) used to lace the leech of the storm sails. In Victoria, the fore, main and mizen (driver) fore-and-aft sails used traversing hoops. I have read that the jackstays were also used in some ships to lace the leech of all fore-and-aft sails rather than using hoops.
From what I have found so far (and I would still welcome further info about the subject) is that these were either rope (early versions), wire rope or even iron rod (later ships). I have not established how they were secured on their upper and lower ends. In Victoria, I think these were only rigged when the storm sails were bent on. As such the vertical jackstays did not have footropes. While Paul is referring to the shrouds, vertical jackstays may also have been used in Flying Fish which may be the cause for the mix of terminology - @paul ron do your rigging/belaying plans also refer to vertical jackstays?
cheers
Pat
- allanyed, mtaylor and Keith Black
- 3
I'm with Roger; I prefer the use of fine pointed irons, but in my case I use resistance soldering. WRT silver solder (the item not the technique) I use products that are for different melting points with no issue. However, as some have pointed out/suggested, these may not be true silver solders but rather solder with silver rather than tin content. Either way and pedantics aside, I find them much stronger than normal soders, and the differing melting points in conjunctioon with the ability to dial up or down the level of resistance (heat), I find I can deal with very small parts effectively.
cheers
Pat
HMS Victory Painting
in Nautical/Naval History
Enjoy the build Grant and a very happy birthday. Your sister is quite talented, a very nice painting.
Will you paint this one in the revised colour scheme the actual ship is now/will be sporting?
cheers
Pat
