BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. Hi Mike, sorry I missed your build here. That section model looks great- very nicely done., cheers Pat
  2. Great to see you back at this build Keith; sorry I missed your return. The build is coming on very nicely. cheers Pat
  3. Okay, okay I get the hint - I'll see what I can do. Eberhard, I may end up having to do the really small spars such as studding sail booms, and maybe even the gaffs from metal as you have suggested, but painting them to match the wood will be a real challenge. cheers Pat
  4. Hi again all. I have been slowly working on the booms since my last update as you can see in the attached photo. I have still to add the parrel ropes and a couple of blocks for the guys, as well as leather the inside of the jaws. The spiderbands and end band are made from thin wall brass with the eyes and ears soldered in, then blackened (as shown in an earlier post). The Jaw bands are black paper card as I need them to conform with the ovoid shape of the jaws and indentations - the thin brass I intended using just would not hold shape properly and gluing them was getting messy. About 3 remakes later.... see the result (acceptable I think). it took a few tries to find a wood that matched the wood I used for the spar proper. The spar is Kaurie, and the furniture Ballarat Pear - the Kaurie kept splitting when trying to use it for the finer detail. I am also still not that happy with the cleats but they are so fiddly to make, and I do not want to use small plastic ones as they will be difficult to paint (to match). I have not put pulleys in the slots of the reefing combs yet; still thinking on how I will do that (to keep them looking realistic). for some reason (camera perspective I think) the jaws look shorter and wider than they actually are. I am now trying to figure out how to make the mast partner wedges/collar. This will be done on the lathe and textured to look like canvas (the individual wedges do not need to be scribed as they will be covered). The problem I am now trying to solve is how to keep the collar horizontal (to fit closely to the deck), with the mast holes at rakes of 5, 10 and 15 degrees for the fore, main and mizen masts respectively. My current plan, which I hope will work, is use some oversize stock (in diameter), drill out the core to the mast diameter, then turn the outer dimension to size. My plan is then to put this in a jig of some sort (still being thought on) to allow me to cut/slice it off at the mast rake angle. Hopefully this will result in a collar that is close fitting at the deck, accepts the mast at the correct angle and will retain a uniform size all around the mast. cheers Pat
  5. Welcome back Eberhard, have been missing your updates (as if I have been posting ) Those extra details really add to this wonderful model. cheers Pat
  6. Hi Allan, to me 'A' looks a bit like the pedestal for a swivel gun (fitted much like they were in HMB Endeavour). The shape looks octagonal, which is right, and the bulk is fitted behind the bulwark which explains the red. But my concerns for this suggestion are that it appears a little deep (long) but then again could be the support/strength they needed; and, I cannot fully reconcile the item at its head, which is similar to that of 'B', - but perhaps these are intended to represent iron rings/hoops driven on to strengthen the top ends? Just a though and bracing for incoming fire cheers pat
  7. Keep at it Gunga Din, you'll get there. I have the same issue with the booms, so many small parts to add but I am almost there cheers Pat
  8. Nice find, and thanks for the info; another tid-bit to file away. cheers Pat
  9. Thanks for your response Ian; your response highlights that I may not have been as clear as I should in my wording. I think your answer was definitive, but just in case, what I tried to say, was that while two oars are fitted, only one was typically used at time? From your response though I gather that both oars were either united or manned? Just interested cheers Pat
  10. Coming along well despite the set-backs Ian. An interesting video. One small point, while I am unfamiliar with this period of history, many oar steered vessels only used a single oar at a time. Were these vessels using two? Perhaps a trial with a single oar may offer different effect? cheers Pat
  11. Well Glen, there is always the 'dancing (Bundy) bears' cheers Pat
  12. This is an extraordinary bit of modelling Glen; very nicely executed and presented - and added entertainment in the build log to boot . The sea surface turned out really well, you have a gift for making water look realistic. cheers Pat
  13. Love your process and determination to get this right Ian; an interesting log to follow. cheers Pat
  14. Hi folks, chains were indeed used, but it appears more so in the later wooden ships (replaced the ropes). While written in 1919, Desmond describes these as being in use in 19th century wooden ships, in his "Wooden Ship-Building", page 101: "In wooden vessels these passageways consist of openings cut across outside of frame timbers (these openings are clearly shown on Fig. 212) and as it is necessary to have some method of cleaning out the openings, should dirt fill them, it is usual to either reeve a chain through all openings from bow to stern, leaving the ends in a convenient place for crew to take hold of them, haul chain back and forth and thus clear [the] limber openings of obstructions, or to leave removable boards over the frames and thus by removing a board [the] crew can reach any obstruction in [the] passage and clear it away. The best and most satisfactory method is to use both the chain and loose board. The passage cut along outside of frame timbers is named the limber; the chain that is run through [the] passage is named a limber chain, and the boards placed over opening left between ceiling and keelson are named limber boards." Also, Charles Davis, also writing of ships built in the latter half of the 19th century onward, in "Building a Wooden Ship", 1918, page 96 describes the chain as: LIMBER-CHAIN-a chain running through the gutter or limber along the bottom of a vessel inside the planking, and used to clean out the dirt and free or clear the limber, so that water will drain freely to pump well. As Bob pointed out earlier these were probably made of a non-corroding metal and of light construction. I think another author also describes these, but I have not been able to find that now cheers Pat
  15. A very neat solution and beautifully presented SIB diorama Glen. You do realise that you have set a very high bar for yourself now don't you cheers Pat
  16. Thanks Grant, that would be great. cheers Pat
  17. Ummm, guys, DMM may be referring to the propeller? On reading the title - perhaps not. As Allan says later, a better description would certainly help. cheers Pat
  18. Nice work (as usual) Greg. Thanks for the feedback. cheers Pat
  19. Hi Grant, as promised. I have now done testing on two products and researched many more. The product I have currently settled on, but needs a little more testing is Technoflux. Another I will try is Kool Jool. Both of these are Jewellers soldering aids but I prefer Technoflux as it is water soluble (for cleaning afterwards). I have not tried with a flame/torch but that is what it was designed for. When using with a flame you need to put a fairly thick dab on apparently, so that would preclude its use in very small/fine work like I am currently doing. However, as I use resistance soldering, I am finding a smaller dabs on both sides of the worked joint (to be protected) is working fine. There is a fair bit of further testing to do using an electric iron etc, but I am deferring that for a while as I need to progress with the build, and the Technoflux, where needed, seems to do the job. I am also waiting to see if there is any longer-term corrosion issues, but I very much doubt it as Jewellers would not use it if it did - and they have used it for quite a while now.. There are a lot of thermal cooling/protection products that come up on a quick search, but closer investigation shows these are a usually a grease used to isolate and/or to conduct electrical computer chips (such as the CPU) and totally not suited to our use. A couple of other products that initially came up in the search lists were not water based and therefore harder to clean, and may have caused corrosion downstream. There is one product I am trying to find (but for some reason can no longer find) is used by welders and has a name something like Blue Cool. When I di find it some time ago it was only sold in very large volumes and needed to be applied quite liberally - so may not be suited. For the time being the Technoflux seems to be doing the job, so I will continue to use that; but, I will also trial the Kool Jool at some point. I got mine from Australian Jewellery Supplies (AJS). here is a link to the product Technoflux Cool Paste - 150gram - by GEMWORLD online store cheers, hope this helps? Pat
  20. Cute bubs, congratulations to all, especially Mum. cheers Pat
  21. Looks good Greg. How are you finding those SMS paints to use? What thinner do you use with it? I have tried Tamiya 400 and it seems to work okay. cheers Pat
  22. That wall looks great Glen. Now I see that I had the mistaken idea that the wall going to be inside also Pity the first attempt at the hollow didn't work, but knowing you, the solution will be elegant and no-one would have been the wiser if you hadn't told us. cheers Pat
  23. That's incredible work Ian; that appears to be a very effective mechanism. cheers Pat
